Member # 11939
Willys Wagon Steering Help
I've got a willys wagon and I'm trying to figure out where and how to run my steering linkage. I've got a high-steer D44 front, a corvette column, an LT-1 motor, and im not sure what power steering box to go with. I don't think that i have the clearance for mounting a box inside the frame. So I think i have to run it outside using a GM or early Ford box. If anyone can offer any advice, it would be appreciated.
Member # 144
Why dont you have clearence inside? You putting it behind the grill? Or out in front?
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
Member # 11939
I'm planning on running it behind the radiator. It looks as though the steering shaft is gonna run right into the manifolds when i put the column and stuff in. I've seen the box put outside the frame with a big hole cut in the side of the fender well. I'm just trying to make it as clean as possible.
Member # 9222
my 59 wagon has a saginaw box in front of the grill.no clearance probs with 327 vette motor. got my steering column today.
i looked at all kinds of boxes most were too big,outside the frame is too ugly IMO. if you really want one outside the frame you might take a look at an IFS toy box. |
#5 (permalink) | ||
Member # 6582
I have my Saginaw inside the frame in front of the grille and it works great. If you want I'll try to take a few pics tomorrow.
N.R.A. Life Member |
Member # 11939
Well, I'd like to show you all pics, but my jeep is at a shop getting wired. I think I know what you guys are talking about with the saginaw box being up front. I've got one out of a wagoneer that i was planning on using. I've got a SBC 307 in the beast right now and it looked like i might have problems once i swap that vette motor in. I would like to see some pictures of your rigs to get an idea.
Jackstand Wheeler
Member # 12152
If you've got the clearance for the box, but concerned about the steering shaft, put a joint in the shaft and run a pillow block next to it for support. Use good quality steering joints. like flaming river, not tractor PTO crap, steering is good.
'46 CJ-2A, '47 CJ-2A, '48 CJ-2A, '50 M38, '52 M38A1, '62 CJ-3B, '62 CJ-5, '65 CJ-5, (2) '66 CJ-5's, '67 CJ-5, '69 CJ-5, '69 J-3000, '70 CJ-101, '74 DJ-5, '74 CJ-5, '77 CJ-5, '78 CJ-5, '78 CJ-7, '78 Wagoneer, '95 YJ, '97 XJ...None of them run. |
Jackstand Wheeler
Member # 12152
Guys do it all the time, it's not as scary as it sounds, as long as you use good quality parts, and definately a pillow block or rod end supporting the joint. Anything is better than the Willy's factory "hunt & peck" steering system. As much as I hate Advance Adapters, they do have some pretty good Saginaw steering conversion info.
For what it is worth..... I'm building a 59 willy cj5... I used a manual steering box out of a 1984 ford ranger.... It works sweet!
Here is a link to the picture..... http://groups.msn.com/tHEwIDEwORLDoF...to&PhotoID=611 Pottsy
bbpfab.com |
#12 (permalink) |
Member # 8133
heres a pic of my dads setup, The drag link is a stock YJ tierod, we built our own BIG steering arm , and the box is out front if ya can see it in this pic ................. box is from a newer 1ton cheby
http://us.f1.yahoofs.com/users/39d24...hb4G9A_1D6xaT4 BIG PICTURE
LCQ / KOH 09 Co-Driver #62 Midwestwheeler / Hardline Custom |
#13 (permalink) |
Member # 11939
Hey PDaddy, you're link didn't work for that picture, but I think I get the idea and can figure it out. Anyways, thanks everyone for your help.
Recreate Responsibly |
