Member # 167564
1946 willys CJ2A
I picked up this trail rig and I am thinking the guy used the original frame for the build. He put in a sbc 350 with the holly projection, 14 bolt rear, dana 44 front, pto winch, 4 wheel disk brakes, my real question is how weak is the stock frame if that is what he used and what do I need to look for.
skullfuckery
Member # 29016
ive seen more than a few 2/3a frames busted up and a shit load of cj5 frames that would make scrap metal look nice.
its really more that they are 50 years old minimum and not nearly rated for what we do to them in the first place.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Is the frame boxed in? If not, you can look at doing that. It should last you quite a while. I have 42, and only part of the frame was new, the rest was boxed in, and it's been beat to death and still going strong.
Tearing it down to build a new frame out of box tubing probably wouldnt be to big of a deal if you build the new one to the same size as the original. Would be a lot of work for not a huge amount of gain concidering the rig is still running trails just fine. If it aint broke, don't fix it Unless of course your OCD then by all means have at it
I worked through the same thing with my 51. I really wanted to wheel it but having an old frame kept resurfacing in my head. Boxing the frame looked to be a lot more work that starting from scratch in my eyes. I almost picked up the material up but found a TJ frame for cheap so I'm going that route.
I cut the original frame up without regret, now I just need to start transferring stuff over. You can get by with strategic boxing (around the spring hangers, crosmember, etc) for a while but you will still want to look at other options for long term.
51 CJ3A future trail machine 88 Range Rover Truck Cab |
#6 (permalink) | |
Ford Bigot
Member # 31227
Your stock frame will break. It's only a matter of time.
Plus the 80" wheelbase will get old quickly. I had mine out 2 seasons and then got tired of having to pull out the strap everytime there was a ledge or a sharp breeze.
Project Flat F***er (Fender) Project SR5.0 |
Member # 127313
Don't get rid of it unless there are cracks. Don't fix whats not broke.
Nobama, I don't mind working for my money, you shouldn't either. Willys Build http://pirate4x4.com/forum/showthread.php?t=824952 “If you don't have time to do it right, when will you have time to do it over?” - John Wooden RIP "Let every man have a pistol, instead of one man have a tank." |
#12 (permalink) | |
Ford Bigot
Member # 31227
This is newbie at most. Look at the TOTM posts, read my thread, try searching. Building your own frame is almost a given with anything before a YJ.
It is more work and money to adapt some other frame to an early CJ, MB or GPW than it is to build your own frame. There. I just saved you a shit-ton of time looking at the frame. The stock frame is weak - don't bother with it.
#13 (permalink) |
I agree building your own frame, (If you are able to do it yourself) is the best route. I built mine from 2"x4"x3/16" steel tube, alot of guys say thats overkill and use 1/8" steel. I have a bad habit of overkilling shit though.
I am feeling very nice and will help you in your searching: http://www.pirate4x4.com/forum/showt...ame+build+cj2a http://www.pirate4x4.com/forum/showt...ght=willys+m38 http://www.jpmagazine.com/featuredve...m38/index.html http://www.pirate4x4.com/forum/showt...t=family+build http://www.pirate4x4.com/forum/showt...812&highlight= http://www.pirate4x4.com/forum/showthread.php?t=775559 http://www.jeepingoffroad.com/Willys%20the%20start.htm http://www.pirate4x4.com/forum/showt...t=flat+stretch /forum/jeep-willys/714553-project-sarge-buildup-thread.html learn to search and get a red star! Last edited by 1946CJ2; 09-02-2010 at 08:37 PM. |
#14 (permalink) | |
