What frnt diff 4 my willys? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2011, 09:13 PM   #1 (permalink)
Got Willy?
53Willy's Avatar
Member # 186284
Ive got a 53 willy cj3a. Tryn to pic a vehicle to rob a front diff from to narrow to my stock width. Planning a d44 but from what? Pass drop, with yj bolt pattern to match my 8.8 im narrowing for rear. Any help would be awesome. Im a newbie be gental.
53Willy is offline   Reply With Quote Quick reply to this message
Old 03-19-2011, 09:23 PM   #2 (permalink)
sammyg's Avatar
Member # 98177
I've looked heavy into this and I'll end up going with a 75-81 CJ Dana 30...Discs and 5 on 5.5 and it's only 2" wider than my stock rear end from a 1970 CJ5.
Are you narrowing the 8.8? That should be 5 on 4.5 bolt pattern.
I'd find a YJ and cut the knuckles off and flip the tubes, HP and all that fun stuff. Are you keeping the stock springs?
sammyg is offline   Reply With Quote Quick reply to this message
Old 03-19-2011, 09:31 PM   #3 (permalink)
Got Willy?
53Willy's Avatar
Member # 186284
All good questions. Wana jus make it tough for its size. Had not thot of flipn a d30. Itl b 2" lift on 31"s is all the biger shes goin for now. Will b narrowing the 8.8
Old 03-19-2011, 09:31 PM   #4 (permalink)
Member # 83976
are you doing spring over or under????????
the1208 is offline   Reply With Quote Quick reply to this message
Old 03-19-2011, 09:33 PM   #5 (permalink)
Got Willy?
53Willy's Avatar
Member # 186284
Under prob.
Old 03-19-2011, 09:51 PM   #6 (permalink)
sammyg's Avatar
Member # 98177
I'm running a fairly warmed up 283 V8, SM420/Dana 18 with 32's and 3" lift right now, and have wedged the front dana 25 up, dumped the clutch at 2500 rpm just to see if it would kaboom, and it didn't. How heavy is your foot and how big is your power plant?
Old 03-19-2011, 10:02 PM   #7 (permalink)
Got Willy?
53Willy's Avatar
Member # 186284
Will be running a Vortec v6 with a 465 mated to the d18. My foots not that heavy, but my leg cramps once in a while.
Old 03-20-2011, 06:02 AM   #8 (permalink)
Member # 3511
You're one lucky guy. I was exploding D25's with 33's and a buick 225.
My .02 Use a CJ D30 and use some adapters or after market shafts in the 8.8 to get 5 on 5.5.
I ran a narrowed scout D44 in mine for a while and it was a pain, wound up switching to a narrowed Chev with the standard mix of chev and ford outter stuff.
Chuck P
A man can do all things if he will
oldjeep is offline   Reply With Quote Quick reply to this message
Old 03-20-2011, 08:35 AM   #9 (permalink)
Got Willy?
53Willy's Avatar
Member # 186284
Guess that answers 1 question. if the scout idea was good or not.
Old 03-27-2011, 02:11 PM   #10 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
What is involved in making a Toyota 8" axle working under a stock cj3a ?
Hard to beat the strength vrs weight and cost of the toy axles.
I have no idea what either the stock or toy dimensions are.
camo is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 02:30 PM   #11 (permalink)
sammyg's Avatar
Member # 98177
Full width springs +running a yota rear.... Unless you can come up with some funkay wheel adapters to run the stock 5 on 5.5 vs the 6 lug.
Gearing doesn't match up with the stock 5.38:1 either
Old 03-27-2011, 06:10 PM   #12 (permalink)
The Piratenite
camo's Avatar
Member # 4
If I used the toy front I would also use the rear and run 6 lug , so that is a non issue.
What is a stock cj3a WMS to WMS ?
If you were to run a dana 5.38 rear gear you could run a toy 5.29 , close enuff for government work
My main point of curiosity is really the width and how close a toy matchs.
Old 03-27-2011, 11:23 PM   #13 (permalink)
Member # 89539
IIRC they are 50 in..
[QUOTE=gmcxt;11050174]The glorious life of a nomadic dent man....I am jealous.[/QUOTE]
PDR John is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 11:57 PM   #14 (permalink)
sammyg's Avatar
Member # 98177
51" with a 28" spring perch width. Pass drop so that's a non issue. Also run into issues using the yota rear since all the early stuff had the offset rear diff
Old 03-28-2011, 11:04 AM   #15 (permalink)
superdooty's Avatar
Member # 103746
I'm running Scout II 44's front and rear, 30 spline. Slightly wider than stock, slightly. You gain disc up front and a larger drum in the rear. Win-Win. Parts are plentiful.
"...you win. I have a very limited number of facts, and you have an unlimited supply of stupid." ...Boortz
Here :
superdooty is offline   Reply With Quote Quick reply to this message
Old 03-30-2011, 10:06 PM   #16 (permalink)
Member # 18320
FJ40 axles would be a better choice than toy truck since then the front frame width is the same at 27". If you are keeping the D18 tcase the rear is also passenger drop.
I have also narrowed scout & waggy axles for folks who want to maintain a narrow track. For a wider track without out boarding springs narrowing chevy D44's work well.
elarsen is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 03:08 PM   #17 (permalink)
Member # 9991
Oh my god, I can't even consider putting AMC Jeep parts on my rig, and you guys are talking about using parts from the people we designed it to kick butt on.
I wonder what Mccarthur, Eisenhower, Truman, and Roosevelt would think?
I'm sure it's just me getting older, and I'm not trying to fault anyone here. I just buy American, and Union when I can.
Sorry, just felt it needed to be said.
MrWillys is offline   Reply With Quote Quick reply to this message
Old 03-31-2011, 05:43 PM   #18 (permalink)
Got Willy?
53Willy's Avatar
Member # 186284
Is the fj60 front an easy axle to narrow and get axles and lockers for?
