M38A1 engine swap info - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2011, 08:08 AM   #1 (permalink)
Member # 181678
I recently picked up a '54 M38A1 and I am looking to swap in a 4.3 chevy engine with a 5 speed.
Does any one have any info on doing one of these swaps?
Noah LaForge is offline   Reply With Quote
Old 04-21-2011, 07:16 PM   #2 (permalink)
Member # 36767
More about swapping a 4.3 into an early jeep than almost any other swaps, keep looking. Start on the Novak site.
Good luck
ssims is offline   Reply With Quote
Old 04-21-2011, 08:55 PM   #3 (permalink)
jjeep71's Avatar
Member # 110523
Not exactly what you are looking for but lots of good info here.
http://www.earlycj5.com/technical/en...3-sm-420-swap/
71' CJ5, 87' 231 V-6, SM465, D-18 w/Warn OD, D44-Detroit, D27 Powerlock & disc brakes, Warn 9000# winch.
jjeep71 is offline   Reply With Quote
Old 04-22-2011, 04:29 AM   #4 (permalink)
Banned
Member # 188016
Remember,the 4.3 is the same as the Chevy V-8 from the motor mounts back.Leaves more room up front cause it's shorter.
Best thing to do is look for a local Jeep with a Chevy V-8 or 4.3 swap and see what they did.
I got the Willys is offline   Reply With Quote
Old 04-22-2011, 05:11 AM   #5 (permalink)
Tinkerer
oldtimingman's Avatar
Member # 75774
easy swap. Except for the 5 speed. which one have you got? an SM420 is likely a better swap if you plan on using it off -road
oldtimingman is offline   Reply With Quote
Old 04-22-2011, 09:54 AM   #6 (permalink)
Member # 141981
Send a message via ICQ to 1946CJ2
and for length, depending on lift.
1946CJ2 is offline   Reply With Quote
Old 04-23-2011, 04:55 AM   #7 (permalink)
Banned
Member # 188016
You're talking about taking the engine,tranny-transfer case from a 4x4 S-10 ?
Old 04-28-2011, 06:44 PM   #8 (permalink)
Member # 181678
What I wanted was to put some sort of overdrive trans in when I do the 4.3 swap, and I was thinking since a s10 5 speed would be already mated to the engine it would be the easiest, but the spline count doesn't match the dana 18 t-case and the s10 t case wont work with the axles it has. So I've now decided it would be easier just to find a buick bellhousing and mate it to the t90 trans, then buy a bolt on overdrive later on when I have some more money(I'm working on a high school student budget).
Old 04-29-2011, 01:46 PM   #9 (permalink)
Banned
Member # 188016
I think you're going to need a Chevy bellhousing.V-8 and 4.3 is the same.
Does the Jeep run now? Might be better to gather up all the stuff you need to do what you want,mock it to what needs to be modified and swap in all in together.
Old 06-23-2011, 09:37 AM   #10 (permalink)
Member # 181678
For right now I'm just gonna run the stock engine for the summer, then swap in the 4.3 using a novak adapter(http://www.novak-adapt.com/catalog/kits_cx.htm) during the winter.
Old 06-23-2011, 10:10 AM   #11 (permalink)
Member # 181678
Here's a current picture
[IMG][/IMG]
