Member # 129535
Would it fit?
I'm fairly green with my amount of willy's knowledge but I'm equally green with envy wanting one. For my next vehicle I really need a tow rig. I've seen online where a guy put a 4bt into a wagon. I was wondering if it would be possible to shoehorn a 6bt into a wagon or truck. I have the means to make a frame and I have a set of 1 ton axles I could use to compensate weight and power I was just curious as to whether it would be possible with one of these vehicles. I can get 6bt measurements this evening if that would help.
Thanks |
I am not sure you could fit enough radiator and intercooler in there even if you could fit the motor. When I had my wagon it was tough to fit the 4.0l from a jeep in there. Same problem with radiator and fan. I am sure you could trim the firewall, grill, and squeeze one in, but the other problem will be wheelbase. The wagon has a pretty short wheelbase for a tow rig.
