#2 (permalink) | |
tub is 67" outside of body at the rear wheel wells.
donor axle depends on what your plans for the thing are.
☠ Quote:
#8 (permalink) | |
Member # 161731
So, the wagon has a 104" wheelbase? I just sold my BJ60 and am looking to build something different and cool. Saw my first Jeepster wagon when I was 13. My dad and I pulled over on our way up to our cabin in WV. It was for sale so we poked around a bit. Small block Ford it seemed and it was a complete rot box. I have wanted one ever since. Im not a rock crawler or anything like that so Im not looking to do anything extreme. I mostly fish and camp so I am looking to run 33s like what I ran on my 60. I have access to a Range Rover Classic chassis in the LWB form which has a 108" wheelbase and completely boxed that can be cut down. The track width is about 58.5" to 59" and I am very familiar with the suspension system and how well it works. Couple of questions: - Whats the width of the stock Willys axles? - What do you think of this? Its a longer chassis and is often times cut down to go under Series trucks so it has the extra material to be cut down a couple of inches. I really want to build a wagon to be my camping/ wheeling truck and this chassis gets me good axles, a good suspension design and power steering...if it can be made to fit. I would rather start with a strong frame than spend many hours trying to make the original frame stronger. Plus, I get coils which I would try and add to the Willys chassis anyway (could be a DD and although leafs can be made to ride well, coils are SO much nicer). |
Member # 161731
Damn, that looks pretty freakin close to perfect. Whats the difference in width, as in frame rails? What axles are you running on there right now? Looks like 1 tons? This would be so much easier for me than having to dick with a LWB Range Rover Classic.
#11 (permalink) | |
Its an abortion of a project.. 1955 willys body, 2005 wrangler unlimited frame and suspension. 1989 camaro TPI 350, dodge/ford 1 ton axles Its been a while since i've worked on it since i am in texas and its in california http://www.pirate4x4.com/forum/showt...ghlight=willys check out this thread, lots of resources piled into one thread. Dimwatt also did a wrangler/wagon conversion, except he used a regular length rubicon, and used everything from the frame/suspension, motor and even electronics. /forum/jeep-willys/867585-willys-all-things-relevant.html
"Your life is one giant redneck moment" |
#12 (permalink) |
Member # 190987
I know this thread is a couple of weeks old, but will the willys fit on a scrambler frame? I have heard TDK makes cj frames and also yj so i figure i can spend the 2500 for a new scrambler frame
If it ain't broke it WILL be Don't follow me I'm lost too Jason |
#13 (permalink) |
Member # 151432
I think the axle width oem was 51.5 front and rear on wagons.
I used a scout front when I was building a willys and it was stock width. Ive got a set of currie ford nine inch axles out of my jeepster that would fit in a willys wagon for sale if your interested in just upgrading your axles. Im going to tons. |
#14 (permalink) |
Member # 201116
I am doing a wagon with an 89 wagoneer frame and found this link in another thread to be helpful it gives you most dimensions of frames and such for donor vehicles.
http://wx4.org/to/wagons/usefulstuff/usefulstuff.html |
