aftershock question - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Johnson Valley
Old 05-08-2008, 11:40 AM   #1 (permalink)
Member # 78377
aftershock question
planning to go run aftershock for the first time. i know it used to be considered the easiest but ive heard thats no longer the case. would like to know the condition of the trail by someone who has been out there recently. thanx!
jeeplt1 is offline   Reply With Quote
Old 05-08-2008, 11:52 AM   #2 (permalink)
mjlogan88's Avatar
Member # 23553
When i was up there 6mo ago it was pretty washed out- seemed harder than a few years ago. If you are running it uphill the waterfall at the end is kinda gnarly. I made it up about 3/4 of the way in a stock ranger with a welded rear and bald 33's before we turned around because it was about 4am.
I've been told claw is easier but havent run it
Whats your setup?
[QUOTE=davey2451;8082797] i just looked at mjlogan88's ranger and it sucks [/QUOTE]
If all else fails, immortality can always be assured by spectacular error
mjlogan88 is offline   Reply With Quote
Old 05-08-2008, 12:17 PM   #3 (permalink)
shoyrtt's Avatar
Member # 28878
I would ask someone who went on the Tin Benders run for the most up to date info.
When I ran it a few months ago, it hadn't changed much. The waterfall and notch near the end of the trail were in the same condition. Maybe some of the rocks in the middle seemed to have changed due to erosion, but again not much.
IMO: If this is your first time out to the Hammers, I would run Claw or Lower Big Johnson first.
shoyrtt is offline   Reply With Quote
Old 05-08-2008, 12:20 PM   #4 (permalink)
Trailer Guy's Avatar
Member # 49181
Aftershock is a fun trail. If you are running a rig with 33's to 38's take a few rigs with ya. The major obstacle towards the top is a tough one unless you know the line. Also depending on the rig, there a couple spots on the way up and one spot after that one that could be tough. Overall, it's a pretty simple trail.
We were just there for the Benders Jambo. On Thursday afternoon we went and ran Claw and then Aftershock. Total time with stopping, bsing, and everything else we do, it took about 3 hrs.
IMHO, Claw is the easiest trail, followed by Aftershock. But I think that Jack front side of Jack, then to the mailbox and out is the quickest.
AJ's 4x4 (530) 227-2969
BSW Racing, CalRocs, Super Mod #12
Driver: Aaron Whitehead
Spotter: Adam Kovarik
Thanks to:
Raceline Wheels (800)529-4335
Hutchins Auto Repair (530)221-5113
Check out PARAphernalia GEAR for 550 Paracord and items
Trailer Guy is offline   Reply With Quote
Old 05-08-2008, 03:35 PM   #5 (permalink)
Hammer Hog's Avatar
Member # 24269
Location: Way closer to the Hammers than you!!! Was Montrose, CO
The upper waterfall on Aftershock is the only thing harder than Claw. Claw has a few of it's own issues, but easy nontheless. Lower Big Johnson is the easiest in my opinion, next to Tac-Hammer as the easiest of all.
But why play on those, when you have such cool trails as Hwy 20, Wrecking-Ball, Outer Limits, Resolution and such?
When are you going?
Official OG13-2013 KOH Recovery Team.
Formula Toy #11 is For Sale... PM me.
Hammer Hog is offline   Reply With Quote
Old 05-08-2008, 04:09 PM   #6 (permalink)
Member # 78377
the plan is to go on the 17th. (so far)
im running lt1,60 rear 44 front on 38.5's. not worried about the alloys out back but the front stock shafts scare me. ive got spares but i just wanted to know what im getting myself into. thanx
Old 05-08-2008, 04:43 PM   #7 (permalink)
Hammer Hog's Avatar
Member # 24269
My buddy did it in his Jeep w/ stock d44's and an open front w/ 35's...no prob...but a darn good driver! ...or maybe it was my spotting
We'll miss you by a week...24th-26th
Have fun.
Old 05-08-2008, 05:50 PM   #8 (permalink)
Member # 50177
unless something major happened in the last couple of years you will be fine. I did it in a sami on 33"s and had no problems, also had a few tj's with us on 33's and 35"s and they did allright, I think one needed a tug in one spot. The bigger waterfall is fun but should not be a big deal for your setup.
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
www.MayhemMetalWorks.com
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
http://www.pirate4x4.com/forum/showt...e33fc&t=488938
am4x4 is online now   Reply With Quote
Old 05-10-2008, 10:14 PM   #9 (permalink)
HOG JOCKEY
Member # 54114
we just ran it today, Sat may 10. the trail is probably the easiest of the Hammer trails, with several different lines to take in a lot of the trail. the trail was in pretty good shape and we had a leisurely kick back cruise through. for those that have never been to Johnson Valley, none of the trails can be considered easy.....just some are easier than others.
herbycj5 is offline   Reply With Quote
Old 05-11-2008, 03:56 AM   #10 (permalink)
Member # 78377
thanx for the updates! i will definitely be heading out next weekend
