Dana 30, 44, 60, 61 and 70 Nitro Xtreme Aluminum Diff Cover - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > JTS Parts & Accessories
Old 12-28-2014, 08:23 PM   #1 (permalink)
justdifferentials's Avatar
Member # 155366
Nitro Aluminum differential covers are extremely thick and have been thoroughly tested in Moab, King of Hammers, and numerous other locations, proving they will handle the rocks, roots, stumps, and anything else you can throw at them. Finned aluminum dissipates heat faster than steel reducing the operating temperature inside your differential and extending the life of your components. Recessed bolts completely eliminate the potential for bolt sheering when crawling over rough terrain. Aluminum can't rust and a Nitro aluminum differential cover will keep your undercarriage looking great all year round. Our wide selection of available covers makes it possible to equip both the front and rear differentials with Nitro covers on many vehicles.
  • Reinforced aluminum protects better than OEM tin covers.
  • Aluminum material helps dissipates heat.
  • Increased oil capacity.
  • Fill and Drain plug for easy maintenance.
  • Recessed bolts.
  • Rust-proof metal.
  • Wide selection.
  • Made in USA.
  • Differential: Dana 60, 61 & 70
  • Material: Aluminum
  • Differential Bolts: 10 included
  • Manufacturer: Nitro Gear & Axle
  • Warranty: 1 year*
  • Differential: Dana 44
  • Warranty: 1 year*
  • Differential: Dana 30
  • Warranty: 1 year*
(866) 525-4620 ---
Follow us on
justdifferentials is offline   Reply With Quote Quick reply to this message
Old 07-01-2015, 09:10 PM   #2 (permalink)
Member # 155366
We make differential covers for many different applications ranging from trail rigs to tow rigs and everything in between. Check them all out here:
(866) 525-4620 ---
Follow us on
Old 04-02-2016, 09:30 PM   #3 (permalink)
Member # 155366
Made in the USA Nitro X-Treme Aluminum diff covers look great, help keep your axle cool and are extremely strong (proven in Ultra 4 racing applications). Nitro makes them for all common applications and we stock virtually all of them in both our warehouses.
Starting at just $139.99, check them out here.
You can find all the various differential covers we stock from different manufacturers here.
(866) 525-4620 ---
Follow us on
Old 07-10-2016, 09:56 PM   #4 (permalink)
Member # 155366
NITRO differentials covers and durable and lightweight, we stock all the popular models too! Click this link for pricing or call 866 349 6801 and speak with one of our Differential Experts to learn more!
(866) 525-4620 ---
Follow us on
Old 07-19-2016, 12:24 PM   #5 (permalink)
Member # 155366
The first few of these new Nitro Alloy covers in red powdercoat have started shipping with a big batch in production shortly. Dana applications available to order now! Click here for details.
(866) 525-4620 ---
Follow us on
Old 10-24-2016, 01:53 PM   #6 (permalink)
Member # 155366
Most oils today are 'Multigrade' oils, which means that the oil is defined by 2 viscosity grades (i.e. 10w-40, 5w-30, etc). Multigrades were developed more than 50 years ago to avoid the requirement of using thick oil in summer and thin oil in winter. The W stands for winter, not weight, which means that the oil has a certain viscosity/flow at low temperature. A lower 'W' number means the oil performs better in cold temperatures. The non 'W' number indicates the oil viscosity level at 100C (212F).This is a fixed limit, all oils that end in the same number (30) must meet the limits.
We recommend using 85w-140 in differentials. Whether you are changing out a differential cover, or just replacing the fluid, it's important to use the right oil in your diffs.
(866) 525-4620 ---
Follow us on
Old 01-04-2017, 03:53 PM   #7 (permalink)
Member # 155366
Don't forget about a new differential cover when you're upgrading your gears or differential parts. They are cheap insurance against rocks and obstacles on the trail. You can check out all the differential covers we stock, HERE.
(866) 525-4620 ---
Follow us on
Old 04-18-2017, 08:08 PM   #8 (permalink)
Member # 155366
Differential covers are always in stock! Whether you're rock crawling, towing heavy trailers, or building a street car; we have the covers to suit all your needs. Check out all the different ones by following the link below:
Differential Covers at JustDifferentials.com
(866) 525-4620 ---
Follow us on
