Member # 11066
Sitting On All Fours(!)
Finally got the front coilovers mounted on Friday. It is a little tall in front, but I have the adjusters threaded down so the coils won't unseat at full droop. I have 6" tender coils and sliders coming so I will be able to drop the front down 3" - 4" to make it sit level.
I still have to fab the cross-bar between the hoops and mount the rad resevoir, the steering fluid resevoir, and a few other bits under the hood that had to be moved to make room for the hoops. Plus, I'll have to make some cuts in the hood for the hoops to poke through. But hey, everytime I remove sheet-metal, it gets a little lighter! ![]() ![]() ![]()
"Wrinkles Only Go Where The Smiles Have Been" - Jimmy Buffett |
Member # 16003
nice...
2001 D2 FZJ80 Front/ARB Ruffstuff axle housing rear w/ fjzj80 stuff, Detroit, 37" creepy's, 14" 9100 Coilovers (F) 14" FOA coilovers (R) 1.6 lt230 w/Ashcroft Under Drive PSC hydro steering Hellfire Hi Steer Knuckles...a lot of revisions and a lot of weldin' 1983 110 RHD Pick-up |
#6 (permalink) | |
Member # 11066
Member # 16003
Are those 14" or 16" co's and what springrates you running?
Member # 11066
Rears are 14" travel with 16" 200# & 14" 175#. Fronts are 16" travel with 16" 300# & 14" 200# w/ triple-rates coming so I can raise the adjusters to drop the front. I have some additional rates and lengths at home so I can play with them if the ride is not correct, but so far everything seems like it is OK.
What rates and travel are you running?
"Wrinkles Only Go Where The Smiles Have Been" - Jimmy Buffett Last edited by Greg Davis; 01-20-2012 at 08:14 PM. Reason: Had wrong rear spring rates listed. |
#9 (permalink) | |
Member # 68649
AG. |
#11 (permalink) | |
Member # 16003
Front is 14" 250/300, no tender...2.0" Bling's
#12 (permalink) | |
Member # 68649
To check clearances when building vehicles, I've found it useful to make a hoisting bracket that attaches to the wheel studs, so that you can articulate the suspension in the workshop by means of a chain hoist hanging from a roof beam. AG. Last edited by Agrover; 01-12-2012 at 02:46 PM. |
#13 (permalink) | |
Member # 12499
I lost your address though when I got my new phone, lemme look at my old phone to see if I still have your address.
Wrenchin' to riches! If you want peace, prepare for war. |
#14 (permalink) | ||
Member # 11066
Sent you a PM.
#16 (permalink) |
Member # 11066
Thanks John. To be honest, for some reason I thought you had left Charlotte. Gimme a yell sometime. 704-577-0532.
#20 (permalink) |
Member # 11066
All in due time my friend!
There's still ALOT of finish work and little nit-picky things to do. But it gets closer each time I work on it.
#22 (permalink) | |
Member # 11066
But in all honesty, this thing is moving at a pace that may actually make that a reality. I've made a dedicated schedule for working on it and so far it has gone according to plan, so there may be hope yet!
#23 (permalink) |
Member # 11066
Well, I didn't get as much done as I had hoped (does anyone EVER?), but I did get a lot of little nagging things cleaned up. Just think of having to take everything off of your wheel wells (since they are gone) and relocating everything(!).
Here's the front fully extended so I could remove my coilovers and install the tender coils. I was able to lower the front 4", so now it sits just right (for some reason that picture didn't show up!). ![]() Neatened up the D/S wheel well by getting the P/S resevoir relocated as well as re-routing some wires, and relocated a vacuum canister. ![]() And on the P/S I relocated the coolant resevoir, relocated the wiring harness behind the fuse box, and mounted some wierd vacuum operated thing just in front of the firewall out of the way, along with some other odd contraption (don't you just LOVE all this technical jargon? ) that I have NO idea what it does.![]() I got the tubing bent and cut for the cross-bar to go between the hoops, but ran out of time. All that is left under the hood is to mount the washer fluid bottle, finish making the crossbar, re-run my AC lines, mount the new PS pump, re-route my intake hose and MAF (again!) because of the shock hoop, and clearance the hood for the hoops to poke through. Then I will focus on installing shorter main springs and tender coils on the rear coilovers so I can have some adjustability, and then I'll work on the rear tin work (wheel wells, bulkhead behind the seats, battery box cover, etc. It's finally getting there!
#24 (permalink) |
Member # 139345
This thing has to be one of my favorite trucks Ive ever seen. Cant believe I just now found it. I looked up for more about this truck I seen he thread with it sitting in your drive right as you were getting ready to coilover it.
Do you have any build thread on this truck?
95 Land Rover Disco, 85 SJ410 Tin Top, 81 Isuzu Pup Diesel 94 Blazer 6.5TD, 69 Nissan Patrol |
#25 (permalink) |
Member # 11066
Try this thread. Unfortunately, a few years ago MontyPics' server crashed and I lost alot of the photo links. If I can ever find the disc with the photos, I'll try and rebuild the thread.
And thanks for the compliments. http://www.pirate4x4.com/forum/showt...470&highlight= Check out the date the thread was started(!).
