#76 (permalink) | |
Member # 42753
Which makes perfect sense, can't be arsed looking for a link though. |
#77 (permalink) |
Member # 212466
Sounds right.
The 300 isn't that big a departure from the 200 either, they share a lot of parts, even the same basic block architecture. I can see how cooling problems would be an issue in Australia, but in my experience (UK) they're fine, but will bite you in the ass if you ignore a developing problem. The lump in my 95 MY Disco has done about 240K miles now, and still going well. It had a head gasket failure last year, after it dropped the water pump (changed for another which failed after 200 miles) and finally blew out a bleed screw whilst towing 3.5 tonnes and drove home with occasional stops to top up the water. Other than that, it's been a solid motor, and has continued to be since doing the head. A good 300 with a VNT kit would likely be an excellent conversion, and probably able to break run at a fairly steady 35mpg. A mate with a 200 Tdi Disco reckons he's averaging 36-38mpg depending on what he's doing. I hadn't heard about the guy doing the diesel V8 in Australia, although I do wonder if he'd have had the same problems as Perkins had in the 80's when they tried to do the same? Google the 'Iceberg' Diesel V8 and you'll see what I mean.
Proudly supporting Black Jewish Gays since 2005. |
#78 (permalink) |
Member # 26821
The 200tdi has a completely different head, different intake manifold and turbo, different timing arangement....so yes there is some difference. I bet the HS 2.8tgv share almost the same amount of parts with the 300tdi as the 200tdi does...but they both are not a 300tdi
#79 (permalink) |
Member # 26821
yes I am aware of the Iceberg. Plenty of guys in oz and around the world for that matter dont bother with the internet. Some of these guys dont need it and are right at home designing and building stuff from scratch....to quite a high level.
#80 (permalink) |
Member # 26821
Thanks Dougal, I cant remeber where I got the Austria info, but the guy was fairly confident and had alot of other info on the 300tdi and HS2.8tgv....either way the main point is LR didnt do the intial design for the 200tdi...in a way this is why it was good. Look at all the LR engines before...and then the 300tdi. The 200 has faired alot better
#81 (permalink) | |
Member # 68649
Ag. Last edited by Agrover; 03-16-2012 at 04:16 AM. |
#82 (permalink) |
Member # 26821
Dont think thats the same guy Bill. The guy I am referring to was told to me by TDiRick. He was one of the contract engineers that did some of the development work on the Au Mil 110's....
#83 (permalink) | |
Member # 90047
A few vehicles from 0.7 litres to 5.7 litres.... 3., 6 and 8 cylinder options too. |
#84 (permalink) | |
Member # 90047
Cooling is the same/similar on both 200 and 300's, I've not know this to be a real issue, not on stock Tdi's anyhow. If anything many complain of them being undercooled. Indeed my 300Tdi D90 took a friggin age to warm up, much much longer than any other vehicle I've owned (and I've owned quite a few). One thing though, you are wrong about the power. 200 and 300's make the same power, both 111hp in a Disco. A Defender is rated at 107hp for the 200 though. But overall I agree, I think you'd have to be a special kind of nutter to spend a small fortune importing a Tdi to the USA just to save a pittance on fuel and end up with less power and less performance.
#85 (permalink) | |
Member # 90047
#86 (permalink) | |
Member # 90047
-they are lying -can't work out mpg correctly -are using dodgy inaccurate made up figures -Or it's parked in a field and slowly rolling downhill Fill up and sit at a steady 45-50mph (on normal road tyres) on a level dual carriage way and yes I believe if driven carefully enough you could attain this kind of mpg. Do anything that involves accelerating, stopping or driving on normal roads and you won't likely be averaging that sort of mpg. Remember the Tdi is rated at 27mpg in a Disco!!
#87 (permalink) | |
Member # 212466
He's originally from Huddersfield so knows a bit about being frugal.
I don't have reason to disbelieve him, but think what you will. As an aside, my 300 Auto Disco averages 26's, my manual 110 will average 32's. Quote:
At one point (when the 2.5 NAD was still an option) the NA diesels were basically 200 Tdi's with the older head and Lucas pump, as it worked out simpler to build the engines like that. Then they discovered it was even cheaper and easier to put the 300 Tdi in everything.
#88 (permalink) |
Member # 26821
300bhp/ton "HG problems do not seem prevalent in the UK on 300Tdi's, but maybe your climate extremes help cause this??"
Mate, where I live it is so not an extreme....many many places around the world that see a much larger temp difference from Min to Max over a year. On top of that my Max in summer would be say 35c this year and that was the odd day....think more along the lines of 28-32c here this summer (more on the 28c side of things..... |
#89 (permalink) | |
Member # 68649
AG. |
#90 (permalink) | |
Member # 42753
#91 (permalink) |
Member # 14136
My understanding is that the 200Tdi was a development of the earlier indirect injection rover diesel. I remember that the 200 in the name 200Tdi refers to the number of changes that were made. Tdi of course stands for turbo direct injection (as coined by VW).
I don't know if rover subcontracted design work out to an Austrian company or not. I do understand that Ricardo (world class engine designers from UK who contract to many large engine manufacturers and hold many patents) did the design for the direct injection changes and Bosch would have been heavily involved with the fuel injection side. I also believe that rover transferred manufacture of the later 300Tdi's to International in Brazil, possibly after they stopped using the 300Tdi in Europe, but not all other countries. This formed the basis of the 2.8 produced by the same Brazilian company. Any difference in stock power between 200 and 300 Tdi's is down to change in stock boost pressure. 300Tdi has 2 stage injectors, only for more refinement and possibly reduced NOx. IMHO both 200 and 300 Tdi's have issues (200Tdi less so). I wouldn't have one again for quids.
John |
#92 (permalink) | |
Member # 68649
I just picked up my refrigerator today after repair, and the proprietor of the company has a 110 defender 200tdi tray back that he claims has clocked up 600,000 km on original engine with just rings, bearings and injector overhaul. |
#94 (permalink) | |
Member # 68649
So the 2 engines must be completely different. AG. |
#95 (permalink) |
Member # 26821
Bill, my memory tells me from LR articals and publications that the 200 was for torque...like you said 195ft/lb. The engine code name was Gemini I think?
John, from what I know LR sold the rights of the 300tdi to International in Sth America. LR had them continue to build the 2.5tdi for their 3rd world country vehicles (this all happend when LR went to the TD5) as the TD5 would not be suitable for the fuel and workshops in these parts of the world. International then developed the HS2.8tgv for their own range. It has a different block, different crank, conrods, pistons, timing gears, timing belt (stronger, same otherwise) different oilcooler, different vacuum pump, differnt exhaust manifold and turbo, different injectors different rear main seal and different gasket and seals. But is still vary similar to a 300tdi. Sounds like Ricardo may have been the company that did the developing for the 200tdi. But that is still the same point I was making, that is LR go to said contractor and say we want X engine based around this exsisting structure and size....LR end up with a pretty ok engine by their standards....then LR decides to change/refine it in house for the 300tdi and takes as many backward steps as forward....now there is a familiar patern
#96 (permalink) | |
Member # 88052
#97 (permalink) | |
Member # 42753
We have guys here putting Lexus V8's into toyotas, but that's because the toyota 2.4 diesel is a slug and in turbo form a danger to itself. We have Nissan guys fitting nissan V8's or turbocharging their petrol 6's for competition use. Small block chev swaps aren't something I've heard much about since the 80's and early 90's. The small block chevs days appear to be a long time past. Last edited by Dougal; 03-20-2012 at 07:13 PM. |
#98 (permalink) |
Member # 20394
Jeebus people.
Pros- Everything minus power Cons- Not enough power. If you can live with 140hp, it's a fantastic motor. If you can't, don't get it. Done.
BUCK Wild Racing Team 911 Thank you all for your support Widia Cutting Tools www.widia.com PSC www.pscmotorsports.com/ Ruffstuff Specialties www.ruffstuffspecialties.com Artec Industries www.artecindustries.com Tom Woods Drive Shafts www.4xshaft.com www.facebook.com/buckwildracing |
#100 (permalink) |
I don't read all the thread but I own a 300 tdi defender with 4.11 and 35's, the engine has an vnt and allisport intercooler, and the fuel pump converted to 2.8's fuel pump. and it's very good. enought power for me and a lot of torque.
on the road with 1.4 transfer his speed it's around 110km/h and with 1.2 (from disco or range) 120 or 125 it's fine |
