#26 (permalink) |
Member # 115301
if your lock tab is ok - use a new one EACH time - and you are using decent quality bearings (eg timken) and you are still experiencing loose bearings, i would look at the stub axle for being worn.
do not buy britpart shite. Buy genuine. And yes, having loose bearings will push your pistons back into the calliper due to the massive run out of the disks when they're flapping about. It can be quite un-nerving!
300tdi Landrover Defender swb + lots of dents |
#27 (permalink) | |
Member # 57677
tks nick i ordered new washers and bearings (timken) and i will look into the stub axle wear also tks |
#28 (permalink) |
Member # 115301
Also ignore the manual about doing them up. Most of us brits just tighten them till they bind aand then back the nut off 45 degrees. Always worked for me and most of the landrover owners I know do em up that way too.
#31 (permalink) | |
Member # 42753
Is the OP folding the tabs over onto the lock-nuts? Is there still a hard washer between the bearing and the first lock-nut? I can't remember if this hard washer was keyed into the stub or not. |
#32 (permalink) |
Member # 212466
There is a washer (2nm thick?) between the bearing and the inner nut, this a plain washer that isn't keyed onto the stub.
Proudly supporting Black Jewish Gays since 2005. |
#34 (permalink) | |
Member # 12499
Learn something new every day. thanx!
Wrenchin' to riches! If you want peace, prepare for war. |
#35 (permalink) |
Member # 44283
Ok, listen ...
![]() I donīt have that much experience, but as for the couple of old-used axles I have taken apart all the stub axles had marks from a spinning inner bearing race. In fact sometimes a small step could be felt from the bearing milling down the stub axle if closely inspected. Even with new bearings and bearing preload adjustment in whichever way, the bearing play reappeared. One solution were new Stub Axles. But, accordind to a friend who runs a Rover-biased garage, this only extends the time until the problem reappered - the heavier the car the sooner. Could make sense, because if proper adjustment alone would be the cure to self-increasing bearing play, that shouldnīt have happend in the first place, given that Rover made the bearing preload right in the factory. >> The solution of my friend was to convert to the Defender TD5 bearing scheme. Basically this consist only of a small tube which acts as a spacer between the outer and inner bearing. When the two nuts then were tightened, all stayed well. A heavy camper 130" that used to come back for re-adjustment neednīt that service after the conversion. Only problem is, you have to have a selection of different sizes of the spacers at hand and trial-fit them to find the one that fits. But once thatīs done, that spacer can stay with that hub (should bearing exchange become necessary later on). |
#36 (permalink) |
Member # 44283
have a look there:
http://landypedia.de/index.php/Radla..._%28Technik%29 |
#37 (permalink) |
Member # 212466
I've lost count of the number of Td5's I've converted to run the 2 but and lock washer setup.
The spacer between the bearings with a locknut is an easier way to manufacture them, but becomes a pain in the ass when a bit of play develops.
#38 (permalink) |
Member # 57677
Ok the inner race was worn a bit. I put new bearings timken and land ROVER lock tabs. One of the stub axles was worn were the seal sits but seemed ok were the bearing sits.
I will try that and report back. |
#40 (permalink) |
Member # 12499
Genuine parts=low bidder, and a low bidder that will accept less for each part every coming year
#41 (permalink) | |
Member # 42753
A spacer that is tuned the correct length between the bearings will solve most issues, but it will require setting for each hub and pair of bearings. |
#43 (permalink) |
Member # 77768
Only if the bearings became loose before the first hub service.
Tom Rowe Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 95 D90 |
#44 (permalink) |
Member # 12499
You'd be surprised to find that most aftermarket parts are made in the same factories as the OE stuff. Often-times, the tooling is even from the OE supplier.
#45 (permalink) | |
Member # 44283
I vaguely remember the intervals between the spacers available are rather coarse. I do not worry when I will have to change a bearing (but I can only speak for myself. And I think a bearing, if given some fresh lubricant from time to time can live just as long as the vehicle itself). In my case there were only two different thicknesses of spacers necessary (three were of the same size). Last edited by landybehr; 05-25-2012 at 01:10 PM. |
#46 (permalink) |
Member # 42753
It's the offset between inner and outer races on taper roller bearings that I think could change.
You should be reasonably safe within the same brand, but between brands I'd expect some variation bigger than the usual range of preload or end-float. PT, yes the same tooling, but often completely different materials. I had a brand new britpart indicator switch that was the most brittle plastic I have encountered. It broke and was re-glued more than three times. Always a long way from home and driving back with no indicators. I have gone back to genuine lucas indicator switches and found them impossible to break in the same manner. Their plastic is tough and rubbery. |
#47 (permalink) | |
Member # 12499
Genuine Lucas indeed.
#48 (permalink) |
Texas by GOD
Member # 69765
britpart is CRAP as far as im concerned.
~ Kyle 1999 Land Rover Discovery II - Lift, Tires, Axles, Stuff. /forum/land-rover/924588-my-d2-axle-swap-thread.html 2006 Range Rover Urban Assault Vehicle |
#50 (permalink) | |
Member # 42753
I have just located a new genuine hazard switch for my 85. I'll try to find a date on that when it arrives. Last edited by Dougal; 05-26-2012 at 08:57 PM. |
