Member # 9428
Driveshaft for LT230 ???
Lame post...I know.....I will delete it when I get an answer.
For those of you that have swapped a BW for a LT230 by how much did you shorten the shaft. The driveshaft shop wants me to somehow compress the suspension fully and measure the distance. Not sure on how to do that. Maybe find a cattle gaurd and winch the vehicle down??? Trying to get the DS shortened tomorrow and wanting to give them an amount to shorten it. I have heard two inches. I obviously have no problem getting the extended length. Thanks Way |
Member # 9768
Well......since I am unemployed and sitting at home using up good air, I can crawl under my truck and measure it for yo. It'll cost you a
.-Jeff OK, flange to flange is 24 11/16". This is with the ome med susp. I was also able to see that it is extended 1/2" from the stock length.
All it needs is just a little luvin' Last edited by JSBriggs; 06-19-2003 at 01:18 PM. |
Member # 12499
Adam:
I can measure the flange to flange on a '93 Rangie versus an '88 if this would help any. The 93 has the BW, the '88 the 230. Paul
Wrenchin' to riches! If you want peace, prepare for war. |
Member # 8768
Range Rover Classic, SWB w/BW t-case, stock front driveshaft = 26 inches flange to flange
Discovery Series One w/LT-230 t-case, stock front driveshaft = 23.5 inches flange to flange Sorry it took a few minutes. I had to kill 3 cockroaches and a spider getting back to the corner they were stacked in tonight.
Michael |
Member # 12499
1988 Rangie
LT-230 Flange to flange: 24 3/8 1993 Rangie OME 761 Front OME 764 Rear BW Tcase 26 7/8" 1995 Disco Rover Tym 2" Rear CB Fronts 24 7/8" Flange to Flange
Member # 8768
The measurements I took were both driveshafts sitting next to each other on the garage floor. Both slip joints were fully compressed.
I thought he was just asking for the difference from the front driveshaft used with the LT-230 vs. BW. That was the best way I could think of. FWIW...
Michael |
