of Dizzy's and Timing Chains - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-18-2003, 07:21 AM   #1 (permalink)
redrangie's Avatar
Member # 11072
Does anyone know the advance range of the vacuum style distributors? I have been getting the dreaded out of time symptoms,(feels almost like 20deg off) and low and behold, if I pull the line off, it runs!
Just trying to get a guestimate before I panic. I could deal with 6 or so degrees of chain slack, but bunches, well thats bad.
j
forgings design dot com
metal furniture | fabrication | decor
new | rustic | recycled
redrangie is offline   Reply With Quote
Old 07-18-2003, 02:19 PM   #2 (permalink)
redrangie's Avatar
Member # 11072
buehler?!!!???
j
Old 07-18-2003, 09:31 PM   #3 (permalink)
Member # 13412
The only info I can give you is for the low and high CR 3.9's in the 94-95 Disco's...however, the specs should be the same as the 3.9 was used in the Disco's overseas since '90 (???)...
All vacuum disconnected, at idle:
2 deg BTDC - low CR
4-5 deg BTDC - high CR
Centrifugal advance between 1400-2200 rpm, vacuum disconnected:
6 - 8 deg advance
so timing should be:
8-10 deg BTDC - low CR
10-13 deg BTDC - high CR
And, of course, check to see if the vacuum diaphragm is working (and that the hose is on the "advance" side of the vacuum bell ). Sorry, I can't find any info on the range of advance via vacuum in my shop manual.
Elitist Know-It-All
DieLucas! is offline   Reply With Quote
Old 07-19-2003, 05:43 AM   #4 (permalink)
redrangie's Avatar
Member # 11072
Yeah,
I couldn't find it either.
thanks Paul.
I haven't even scoped it yet. I just find it amazing that the chain could have stretched so far in such short time.
j
Old 07-19-2003, 08:25 AM   #5 (permalink)
Member # 13412
Paul?
Sheesh...I'm not wanted anywhere...
Elitist Know-It-All
Old 07-19-2003, 01:08 PM   #6 (permalink)
Member # 12499
Originally posted by DieLucas!
Paul?
Neither am I!
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 07-21-2003, 11:27 AM   #7 (permalink)
redrangie's Avatar
Member # 11072
Originally posted by PTSchram
Neither am I!
As if you guys needed proof I am space cadet.
Well, i found that the timing was about 6 degrees off. But the moral of the story is NEVER assume.
I figured that there couldn't be anything wrong with the other ignition components since they were under a year old.
Well, I reset the timing and off I go to the mountains. Starts running worse under more load (19% grade). Pull cap-n-rotor in lot, and find that the rotor is scarred, and the contacts are all scarred. Not worn down mind you, just cheap ass arc material. Also found a arcing coil wire with my finger... (ouch) under load, (simulated by having cohort load up the torque converter).
Never ever assume....
j
