Arghhh...Lucas Can Eat It!!! :mad: - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-09-2003, 08:33 PM   #1 (permalink)
Member # 13412
Good grief...
got my replacement turn-signal/horn switch and figured the reinstall would be easy. Well, bolted it back in and reconnected the wires. Fiddled around with the turn-signal relay and got it working. Good.
Then went to fiddle with the hazard light switch and relay. Took some time, but finally got that working. Plugged the wiper switch back in, and nothing.
Then went to try out the turn signals...nothing
Hazards...still work
So I fiddle with the nightmare of nondescript wires under neath the dash figuring that the accessory lead must have been disconnected. Fiddled enough to get the wipers working again, but the wiper control box (the device that resets the wipers back to the down position when you turn 'em off) isn't working and the wipers will just stop in the middle of the windshield.
And the turn signals still don't work.
And the hazards quit working.
Whenever I finally meet Lucas, I'm gonna take a warm keg of Guiness and bash it over his frickin' head. What an @sshole.
Elitist Know-It-All
DieLucas! is offline   Reply With Quote
Old 10-09-2003, 09:12 PM   #2 (permalink)
Member # 1745
Send a message via AIM to 64rovr
And you're giving me advice on de-wiring my donor RRC?
I feel less confident now
64rovr is offline   Reply With Quote
Old 10-09-2003, 09:26 PM   #3 (permalink)
Member # 9768
Thats Ok Jason,
Your good enough......
Your smart enough.....
and dawg gone it people like you....
Oh and for the tech GO HERE
time to convert
-Jeff
All it needs is just a little luvin'
JSBriggs is offline   Reply With Quote
Old 10-09-2003, 11:07 PM   #4 (permalink)
Member # 13412
Believe me, the ECU was simple!!! It's the only thing that works!
Well, finally got it wired back up. The hazard switch is a major problem...contacts old and/or broken. Had to do a little splicing to get both the hazards working and my turn signals working (the accessory lead for the turn signals runs through the hazard switch)...
...also got the dimmer switch working...now I can see my guages (which don't work anyways).
The wipers are still a crap-shoot...they work, they just don't reset automatically. I don't know if there is a problem with the control box, or a loose lead. Who knows. I'll worry about it next year when it rains
And my wife tells me the brake lights don't work. but when I test them, they do. BTW, the supposed brake-light switch on the master cylinder with the two wires running out of it...it isn't the brake light switch. I disconnect it, and the brake lights still work (and nothing blows up, either). I don't know what that circuit is for or where the hell my brake light switch is. F'n A!
Adam, have faith. I can get your engine running with just the ECU and a car battery. I can't guarantee anything else will work. My '83 came with 3 fuses from the factory and 20 years of backyard fixes ready for me to enjoy!
Briggs, Painless is painful on my pocket book. I've got about 15 relays, a power distribution block, and Slade's old fuse-block from his '90...I'll slowly get around to cleaning up the nightmare under the dash.
Tonight I have won. Tomorrow that damn truck is for sale
Elitist Know-It-All
Old 10-10-2003, 06:05 AM   #5 (permalink)
Member # 13149
The wipers on my '79 RR sometime won't park and I fooled around with them for a long time trying to correct it. I found that dust gets into the switch and a good hosing down with WD40 or contact cleaner usually gets it working right again.
LRover is offline   Reply With Quote
Old 10-10-2003, 08:10 AM   #6 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
My heater switch works the wipers and my wiper switch runs the heater motor.
I switch the wires around and nothing works. So I switched em back. Then changed the dash labels.
People do think its funny when I push on the heater knob and water squirts on the window....yes window, only the passanger side works
aloharover is offline   Reply With Quote
Old 10-10-2003, 05:24 PM   #7 (permalink)
Member # 9768
It is now Tomorrow.....Ill give you $20.
-Jeff
Old 10-10-2003, 06:51 PM   #8 (permalink)
Member # 13412
SOLD!
Elitist Know-It-All
