Radiator update - RRC - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2003, 05:45 PM   #1 (permalink)
Serious One's Avatar
Member # 8768
Hey,
I had the radiator rodded out yesterday on the LWB I'm selling. It has 115K on it, and the guy at the rad. shop said it was 50% clogged.
I'm going to pull out the rad. on LWB #2, I'm guessing it'll be a similar story. It has 145K on it.
Just a heads up! Do with the info. what you want!
Michael
Serious One is offline   Reply With Quote
Old 12-03-2003, 05:46 PM   #2 (permalink)
Member # 1745
Send a message via AIM to 64rovr
Did you run distilled water?
64rovr is offline   Reply With Quote
Old 12-03-2003, 08:24 PM   #3 (permalink)
FAL
Member # 10162
RRC radiator
Mike,
If you decide to buy a new radiator, think about having one build.
The RRC radiators are 4 cores, and there is enough space left on the side tanks to have a five core installed.
That's what I did a few years ago, 5 cores instead of the factory 4 cores, and I paid only $460.00.
That even cheaper as a factory radiator, and I have better cooling.
fredd
PS : did you send that little package ?
FAL is offline   Reply With Quote
Old 12-03-2003, 08:57 PM   #4 (permalink)
Member # 8768
I talked to the rad. guy about doing a 5-core using the existing tanks and new header plates. Would cost me 340 dollars to have my old radiator upgraded to 5-core.
He said that he didn't think it needed it as the radiator was way overbuilt for the type of engine we run, but I still feel it would be a worthy upgrade and am considering doing it on the second radiator that I have.
I took your 'package' to the post office on Monday and was standing in line for about 30 minutes, then got to two people from the front and realized that I had all of your other 'goodies' and didn't have the switches!
Doh!
I was so pissed I swore at myself and huffed out, I swear everyone in line must have thought I was going to start shooting.
I am *trying* to sell my truck tomorrow, have a guy flying in from Edmonton. I'll see how much time I have and maybe I can swing by the post office on the way to the airport.
Sorry I've been such a slacker.
EDIT: Adam, I have not been religious about running distilled water in either of my RR's because I figure that the damage has already been done. Plus, with all of the thermostat changing, hose fixing, etc...I've been flushing the system too much to worry about using distilled water.
But, I am going to use it now that I've rodded out the radiators and am starting from scratch. I am using distilled water in the Ron Davis aluminum radiator in the CrewCab.
Michael
Old 12-03-2003, 10:37 PM   #5 (permalink)
Member # 24744
Send a message via Yahoo to thebird1080
These are the kinds of thing that I learn here: I should run distilled water in my radiator. The more and more I learn about my truck, the less I want to deal with the thing. I think I'll probably way overshoot my budget on my swap. If I need to get my radiator fixed, I might as well go with a custom that will drink "tap water"!! Friggin' amazing!!
thebird1080 is offline   Reply With Quote
Old 12-04-2003, 04:52 AM   #6 (permalink)
Member # 12499
One does not wish to use other than distilled or deionized water in an utomotive radiator. Without going into the physics/chemistry, the heat transfer into distilled or deionized water is far more efficient.
That said, while this likely won't work in Vegas, nor Aridzona, I use the water from my dehumidifier as it is more than suitable for our purposes.
Mike- I have picked up some bits to further the shock mount project.
Peace,
PT
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 12-04-2003, 12:42 PM   #7 (permalink)
Member # 17053
Never before heard of people using distilled water in radiators. Do you mix it 50-50 with antifreeze like we do?
Christer Wilsby
Range Rover 4.6 Vogue 2001 - still shiny
Defender 110 CSW Td5 2001 - expedition/radical family wheeling
Suzuki LJ80 1982 - "Standard" trialer
Volvo C304/Tgb 13 6X6, portals, on 35" - stocker
"Grammar is the body language of the internet."
The Pendy
wilsby is offline   Reply With Quote
Old 12-04-2003, 01:25 PM   #8 (permalink)
Member # 13412
Just use it in place of tap-water. 50-50 with antifreeze in colder climates.
Elitist Know-It-All
DieLucas! is offline   Reply With Quote
Old 12-05-2003, 11:10 AM   #9 (permalink)
Member # 17053
OK. I realize why it is better in theory. But does it really matter in real life?
Christer Wilsby
The Pendy
Old 12-05-2003, 11:29 AM   #10 (permalink)
Member # 9817
yes - there are measurable benefits both in the longevity of the radiator and in the performance of the coolant in extreme climates.
next time you flush the radiator try it out.
not sure about over there, but distilled water at the grocery store is inexpensive.
'97 Discovery
SeaRover is offline   Reply With Quote
Old 12-06-2003, 10:02 AM   #11 (permalink)
Member # 8768
LWB #2's radiator was also clogged to 50%.
Funny thing is, all of the sediment was in the bottom of the radiator. The guy asked me if the truck had sat for a long time, I said no, but that I had used a bottle of that Prestone radiator cleaner recently.
He said that is what did it.
The cleaner loosened up the deposits and then re-deposited them at the bottom of the rad.
He said if you use that stuff yearly it does a great job, but if you do it in a last ditch attempt to clean out an already clogged radiator, it just makes things worse.
Rad is installed and heading out for a test drive.
Get your rads rodded out at 100K weather you are overheating or not.
Oh yeah, and used aluminum safe coolant and distilled water - it really helps.
Michael
Old 12-06-2003, 06:55 PM   #12 (permalink)
Member # 8768
last update...
Hooked up the ChuckWagon to the LWB and headed up the mountain,
Climbed steadily up to 7600 feet and the temp guage didn't budge at all.
I think I have my cooling issue solved, finally.
What I did:
Replaced all hoses
Replaced expansion tank
Replaced expansion tank cap
Replaced thermostat
Cleaned out rad with off-the-shelf Prestone cleaner
Rodded out radiator
Rodding out the radiator is what finally solved the problem.
Michael
Old 12-06-2003, 09:38 PM   #13 (permalink)
Member # 21704
That is what I said to do two months ago. Glad things are working out, no overheating etc...
I may write a post about recoring radiators this week. Just to stir things up with PTS again. There are better ways to deal with this as well. Luckily your Radiators were not to far gone.
JP
legend in my own mind
"bigger on the internet"
pendy is offline   Reply With Quote
Old 12-06-2003, 10:20 PM   #14 (permalink)
Member # 8768
Pendy,
Yep, you were right.
I think the reason I put off pulling the radiator out quite honestly is because I was afraid of it.
I didn't know too many people who had actually yanked one out, and even though I sound stupid admitting it I don't care now.
The transmission cooler lines and engine oil cooler lines were what was freaking me out. I was afraid I could screw something up, make a big mess, and generally never get it back in again.
I know it sounds stupid, and now that I've done it twice in the past week, I feel like an idiot for not doing it sooner.
The second time I took the rad. out I did it in 10 minutes, so this is to encourage others that it's not bad at all, and you can do it quickly if you just decide you're going to fix your truck rather than wait to blow a head gasket.
So again, you were right, I was dumb for putting it off this long.
All you others pushing 110K on your truck, you'd better yank it out and get it rodded otherwise you're looking at at least 325 bucks for a re-core rather than less than 100 for a good rodding-out.
That's all for now.
Michael
Old 08-13-2004, 12:52 PM   #15 (permalink)
Member # 33517
Reviving this thread in the hope that someone may chime in (again)...I have not had any problems with my rad, '98 Rangie...I was going to change the coolant while a fix a hose connection, and was thinking of using some of that Prestone flush shit. Seems others have siad it makes matters worse. But if my drain plug is at the bottoom of the rad, wouldn't anything that is loosened come out the bottom. The drain plug is obviously the lowest point of the rad. Thanks in advance for any suggestions.
Agro1 is offline   Reply With Quote
Old 08-13-2004, 03:33 PM   #16 (permalink)
Member # 14136
Gravity causes sediments to accumulate in the lower parts of the radiator. In Rover radiators, being cross flow type, it is the lower horizontal tubes.
John
Bush65 is offline   Reply With Quote
Old 08-14-2004, 09:31 AM   #17 (permalink)
Member # 16284
Just about every manufacturer I am familiar with recommends distilled water with 50/50 coolant (preferably low phosphate coolant). I know Audi and VW have done this since the 70's.
You can pick up distilled water for cheap at your local grocery store or my local wal-mart sells it for $.59/gal.
When offroading some people carry a gal or two of 50/50 premix. I carry a gal of coolant and just fill my 5 gal personal use water can with distilled-that way I've got 5 gals for use in my radiator in case of an emergency.
GregH
SonarRover is offline   Reply With Quote
Old 08-16-2004, 06:54 AM   #18 (permalink)
Member # 17655
Certainly, if your home shower head has ANY buildup on it, you ought to think twice about using tap water.
I just use the water from the dehumidifier...and I change the coolant twice a year.
sachilles
-87 Range Rover
-61 Morris Mini
-97 Audi A4 1.8tq
and an 81 Cj-8 project
sachilles is offline   Reply With Quote
Old 08-16-2004, 10:38 AM   #19 (permalink)
Member # 9859
Send a message via Yahoo to alia176
You'll also find cast alum (sand) collecting on the bottom of some radiators as well. Can't remember who told me this but thought it might be worth passing on.
Later.
Ali
alia176 is offline   Reply With Quote
