Foers Vector winch? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-24-2004, 05:36 PM   #1 (permalink)
Member # 5326
Foers Vector winch?
Anyone use the system, seen it work, like it, hate it, whatever..
For those who don't get it, its a center mounted winch facing backwards that allows you to pull both front and back with only one winch, plus the weight is in the middle....
Old 01-24-2004, 05:51 PM   #2 (permalink)
Member # 16720
Here's a center mounted PTO on a BJ70 series land cruiser.
But I like the Foers setup above better, since I figured a winch set in the middle of the truck would get pretty gummed up. The Foers setup look pretty clean, other than having a winch sticking up in the middle of your truck.
GreenPig is offline   Reply With Quote Quick reply to this message
Old 01-24-2004, 05:53 PM   #3 (permalink)
Member # 5326
Now thats a puller!
I am wondering how they run the cable on these systems...
Old 01-25-2004, 03:53 AM   #4 (permalink)
Member # 14136
Originally posted by Mieser
Now thats a puller!
AFAIK rope runs from winch around a snatch block at the rear, then foward through a guide tube.
John
Bush65 is offline   Reply With Quote Quick reply to this message
Old 01-25-2004, 03:55 AM   #5 (permalink)
Member # 14136
To winch backward, pull the pin that anchors the snatch block and pull the snach and rope out through the fairlead.
Here's pic of the rope in tube at the front.
John
Old 01-25-2004, 04:36 AM   #6 (permalink)
Member # 15179
Re: Foers Vector winch?
Well as that is a picture of MY winch I guess I can answer the question
It works well to my mind, but you have to use plasma rope, as the 8274 is prone to overrun, thus birdsnesting the cable.
There are a few gotchas when using it, but nothing bad - we've done a few winch challenges with it, and it has performed great.
One winch which is kept out of the mud which pulls front and back is a winner IMO.
It puts huge compression loads on the chassis, just the mounting/pulley/reinforce on the Ibex is a $2000+ option
Andy
Red Ibex is offline   Reply With Quote Quick reply to this message
Old 01-25-2004, 04:37 AM   #7 (permalink)
DiscoDino's Avatar
Member # 15296
I think I still prefer a smart fore and aft dual winch location...I know its extra weight, but I kinda feel more comfy with that.
'83 D130: 54" TTCs or 42.5" Boggers, OEM RW2.5s, Stazworks, LQ4, Atlas, dual M8274-50s, mid-mounted 9.5xp-s, dual 16" ORIs, PRP seats, etc...
'91 D110: 36" Iroks, R380, 2wd conv, underdrive, ARBs, 30 spl front, Sal D60 rear, caged, Fox remote reservoirs, M8274-50, and P&P exo-cage, etc...
DiscoDino is offline   Reply With Quote Quick reply to this message
Old 01-25-2004, 12:27 PM   #8 (permalink)
Member # 5326
Red Ibex
Cool your on the board. This place always surprises me!
Do you have any pics of the tube that the cable runs through, specifically the forst section where the cable comes from the pulley into the tube?
I totally dug your site! It was great. Share a few thoughts on your ibex while your at it!
Old 01-25-2004, 01:28 PM   #9 (permalink)
Member # 15179
Red Ibex
Mieser - glad you like the site, I'm quite proud of my Ibex, I've 'borrowed' a lot of tech from the US, and Aus, so its quite a unique vehicle in England.
If anyone wants to know more than I've got on my site - then fire away - might be worth starting a thread for ?
Here are a couple of piccies, the rope is not spooled properly at the moment, it should go to the front, not be looped up and slung out the back. Long story which I'm not about to go into
[IMG]F:\DCIM\120CANON\img_2035.JPG[/IMG]
[IMG]F:\DCIM\120CANON\img_2034.JPG[/IMG]
Andy
Old 01-25-2004, 01:40 PM   #10 (permalink)
Member # 5326
red ibex
You have to attach the pics with the little box "attach file" below where you type the reply. You can't link from your hard drive.
Or you have to put them on your site, then link them.
Thanks for the pics when they get here...
Old 01-25-2004, 02:21 PM   #11 (permalink)
Member # 9817
how is the cable threaded through to the front of the vehicle? does it sit below the transmission/transfer case? only way i could see it working would be to mount a pully on a custom crossmember, and then run the cable through a section of pipe to the front. Hmmm . . .
'97 Discovery
SeaRover is offline   Reply With Quote Quick reply to this message
Old 01-25-2004, 03:23 PM   #12 (permalink)
Member # 15179
red ibex
Doh
Tried that - works for me on the test forum - but not here.
Oh well - plan 2, try Vector Winch Piccies
Andy
Old 01-25-2004, 03:32 PM   #13 (permalink)
Member # 5326
OHHHHHHHH....so that is how they do it....
they just run the cable right through the frame rail! Dang! Do you know if they smooth out the inside of the frame or anything?
Thanks for the pics...
Old 01-25-2004, 03:47 PM   #14 (permalink)
Serious One's Avatar
Member # 8768
Here, do it this way so we can be even more lazy and not have to go to your site.
Another..
Very interesting indeed.
Michael
Serious One is offline   Reply With Quote Quick reply to this message
Old 01-26-2004, 12:45 AM   #15 (permalink)
Member # 15179
There is a tube that runs through the frame rail, from the pulley, to front crossmember.
The Ibex is very strong anyway, being a steel spaceframe, but the compression loads (when modeled in CAD) were such, that lots of uprating/bracing/gussetting had to be done.
Just bear that in mind, if anyone thinks it a saturday job to reproduce. - Hell tracking is over-rated anyway
Andy
Old 01-26-2004, 11:55 AM   #16 (permalink)
Member # 5326
One thing I don't like is that is wastes a lot of space under the rear floor. Where is the fuel tank in an Ibex? under the seat?
Good concept though....I like it overall.
Old 01-26-2004, 02:10 PM   #17 (permalink)
Member # 15179
A SWB Ibex uses a 90 underseat tank, not sure about the longer ones.
Underfloor space isn't really comprimised, the cable runs share the same approx area as the a-frame, so thats a pretty useless area.
Keeping the cable runs away from the exhaust so the plasma doesn't melt needs some thinking about though, luckily the TDi doesn't need much silencing.
Andy
Old 01-26-2004, 03:57 PM   #18 (permalink)
Member # 5326
How big is your fuel tank?
On the US defenders the fuel tank is right where the pulleys are.
Old 01-26-2004, 05:13 PM   #19 (permalink)
Member # 20109
No it is not. The fuel tank is BEHIND the rear axle on newr and NAS 90s. There is basically no rear overhang on an Ibex, so no room for the tank. Look closer at the pictures.
red90rover is offline   Reply With Quote Quick reply to this message
Old 01-26-2004, 05:22 PM   #20 (permalink)
Member # 5326
yeah, I know, but if you tried to build this system into an american defender the gastank would still be in the way.
Old 01-26-2004, 05:31 PM   #21 (permalink)
Member # 1745
Send a message via AIM to 64rovr
yeah, thats why it's in an IBEX not an NAS defender
I'm a bigger fan of the underseat 90 tanks anyways.
64rovr is offline   Reply With Quote Quick reply to this message
Old 01-26-2004, 05:40 PM   #22 (permalink)
Member # 5326
How big are the underseat tanks? And do they hang down under the rocker?
Thanks...
Old 01-26-2004, 05:43 PM   #23 (permalink)
Member # 1745
They are just about even with the bottom of the rocker, and I believe that each one is somewhere in the neighborhood of 12gal.
Old 01-26-2004, 06:09 PM   #24 (permalink)
Buckon37s's Avatar
Member # 20394
They hang down below the bottom of the rocker by at least 3 or 4 inches and will hit everything. They are 12 gallon though.
[I]BUCK[/I] Wild Racing
Team 911
Thank you all for your support
Widia Cutting Tools
Sterling Autosport
PSC
Ruffstuff
Tom Woods Drive Shafts
Buckon37s is offline   Reply With Quote Quick reply to this message
Old 01-26-2004, 06:37 PM   #25 (permalink)
Member # 1745
The truck I am using for reference has some beefy rock sliders on it, that the tank only hangs down maybe 1" below that. And it has a nice skidplate on it. I would rather have the tank there than behind the rear axle though, if I had to pick.
