Member # 3547
Arrrggghg! Rangie going IFR/IFS
According to the Feb Fourwheeler, Rangie is going IFS/IFR in 2003.
Guess that makes the decision easy...it'll just have to be a G500 then ! man, this is truly sad. Way sadder than the Jeep guys bemoaning the move, since the KJ sucks with or withiout IFS, and others need upgraded axles anyway...but the Rangie was world class out of the box
it may be IS, but it is supposed to be the best IFS/IRS system ever produced. as much, if not more flex than the current edition. and dude, come awn! are you really going to wheel a $85k vehicle to the point where it NEEDS a solid axle?
#3 (permalink) | ||
Member # 3547
And, no - I wouldn't wheel it that hard off the lot.....but 15 years from now when I could afford a used one....I gues 02 will be the last year I'd look at. There are plenty of guys around with Rangies that do need the solid front, but probably took a few years to get there. |
#4 (permalink) | |
it will be the end of an era, but i think that its for the best. with the TJ Rubicon coming out next year, i think that LR will have some serious competition for the defender and will have to bring out a similar edition D90. |
#5 (permalink) | |
Member # 3547
I can only dream about a dual elctric locker 4:1 cased D110 from the factory....but it should have 4.56 and 33's to beat the Jeep Bill |
I am skeptical about the 4-wheel independant as well. I liked the solid axle design and I think they should keep it. However, this is good for the wheelers here because the last generation will now be much cheaper since they made so many changes to the new one! I had a 99 4.6 HSE for a little while and that thing rocked!! I was able to embarass many Heeps and discos and even stock D90s with the pushbutton lift and traction control. Hopefully someday I'll be able to afford another one. The only downside is that the electronics are so complicated and expensive that it's going to be a pain to modify or work on.
but, if you want it bad enough, it can be done!!! Oh yeah, and look at www.safarigard.com for the Kalahari edition Disco. If they do this, it'll be absolutely SWEET!!!! And once they realize there's a market for it, maybe they'll build a diecent new Defender!!! -J
"All the parts falling off this truck are of the finest british craftsmanship." |
