Member # 12499
causes of multiple misfires other than stuk valve?
Bad ticking noise, CEL on, random multiple misfires resulting in excess emissions, #4 & #8 cylinders specified, ticking noise coming from 1-7 side of engine. Pulled plug and replaced wire to #8, no dice.
Any ideas before I pull the heads?
Wrenchin' to riches! If you want peace, prepare for war. |
#3 (permalink) | |
Member # 12499
When the liners drop, is it as obvious as it sounds? Thanx Ron!
#5 (permalink) | |
Member # 12499
Member # 21704
Fix it the aviation way and charge them for a head job.
Aviation way: remove valve covers and rocker arm assemblies. use the compression tester witout its valve core hook up shop air to a cylinder use a rubber mallet and whack on the valve stem of the aired up cylinders valves repeat on all cylinders listen for escaping particle in the exhaust stream and intake reassemble cross fingers and start it up, higher RPM Go have a beer and set up your next scam All advice given freely JP
legend in my own mind "bigger on the internet" |
Member # 13683
Most likely gunked valves.
In case you wanted the advise. Use all the old parts. All you need to rebuild the heads in shop, will be an electric drill valve seat compound, a few hones and new vavle stem seals. Only replace the vavles if they have excessive wear, or are bent. First clean the head of all carbon. Remove all valves. Clean carbon off all valve stems with a bench wire wheel. Check for gauling. Next hone out all valve guides with proper hones for exhaust and intake. Then lightly oil valve stems and replace valves in head. Apply valve lapping compound to valve seat and valve. Use an electric drill or the like on the back of the valve stem to seat each valve. You will know whne it has seated. You may wish to seat the valve a little deeper past that point. Check for a consistent grey seat mark on the valve and head. Clean lapping compound off head and valve. Install valve stem seals with a small deep socket. You now have heads that will perform like new, and last for at least 50k or more. If valve seats are worn badly--------Replace heads If valve guides are worn badly-------Replace heads If you damage the deck on the head----Replace heads Sorry gotta say it, no machine work required to re build heads. If you think you need machine work, replace the heads. Minor warpage of heads is acceptable. Head bolts will easily re align the heads to the engien deck. The above procedure is exactly how we handled heads at rover. I have never had a Head job come back for repairs relating to the work we did. Heheeh he said head JOB
K.C. |
#9 (permalink) | |
Member # 12499
BTW-it only took me slightly more than two hours to disassemble. I'm closin' in!
Member # 23094
Dropped liners are not as obvious as they would seem. I have seen a few go for 10,000s of miles with a dropped liner and busted piston. CEL on, then CEL off, comes back on, goes off.
They are nasty at first but then the top of the piston/ring etc crap gets blown out the exhaust and it is just a mild miss, at high rpm they will actually fire! Lucky it seems like valves for you. Ron |
