Auto or Manual - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-12-2002, 04:54 AM   #1 (permalink)
Member # 7962
Auto or Manual
I currently run a manual box (LT95) but have got a TF727 and LT230 sitting in my shed. Should I swap.
This has probably been beat around many times before but Im just a dumb ass newbie so let me hear it (or is that have it)
I know that an auto is probably easier to drive, more controlable, easier on the drive train etc etc and going down hill isnt a worry cause I use my breaks anyway.
If i did swap will I be low enough geared or does the auto require lower diff gears all else being equal. (I also know I am not low enough geared as it is but I can manage with wat I have got. (I have 4.09 diffs and 36in tyres). If I did swap the auto will I have enough power to walk up vertical ledges or will the torque convertor just stall up, go nowhere and just sit there. (with the manual I just rev it a bit harded and ride the clutch or just pop it).
What about trying to launch real hard. With the manual I can be in 2nd or third low rev it to 3 or 4 grand and side step the clutch to get a real hard launch and spin the wheels (or take off like a rocket in the rocks). Its suprising how many times I need to do this so will I be able to launch this hard with the auto or not.
Anything else that should sway my decision or should I just try it anyway.
Thanks
Sam
Strange Rover is offline   Reply With Quote
Old 01-12-2002, 06:09 AM   #2 (permalink)
Jtisdale's Avatar
Member # 8122
sam I'd say your days of launching might be over with an auto
JT
Jtisdale is offline   Reply With Quote
Old 01-12-2002, 06:00 PM   #3 (permalink)
NIC
Member # 2150
Send a message via ICQ to NIC Send a message via Yahoo to NIC
why not swap it out for a toyota so you wouldnt have to ride around ormeau in your mates rover
NIC is offline   Reply With Quote
Old 01-12-2002, 11:17 PM   #4 (permalink)
Member # 7962
Yea right Carnt see how a toyota is gonna help me
You hear we one that night run
It was bloody easy though. Just shows how well a dirty old farm truck (series 3 hybred on a disco) on 32s can go.
Sam
Old 01-13-2002, 12:03 AM   #5 (permalink)
NIC
Member # 2150
you won keep dreamin
Old 01-13-2002, 12:07 AM   #6 (permalink)
Member # 8565
Nahh its true they won
www.outerlimits4x4.com
www.werockaustralia.com
SAVE THE HAMMERS Post #749
Do illiterate people get the full effect of Alphabet Soup?
If electricity comes from electrons, does morality come from morons?
RUFF is offline   Reply With Quote
Old 01-13-2002, 12:16 AM   #7 (permalink)
NIC
Member # 2150
there was money involved right????????
Old 01-13-2002, 11:03 AM   #8 (permalink)
Member # 7755
never used a 727tf but make sure you got the right LT230. The hi range in a 727 LT230 should be 1.003. The 727 has a rep for being indestructable. They put them behind hemis (500hp or so) in the US.
Ron
:evil:
evilfij is offline   Reply With Quote
Old 01-13-2002, 12:27 PM   #9 (permalink)
Member # 7962
Yea it was 1.003 except we swapted that into my buisness partners rangie when we swaped in a 3.9l Isuzu so I think we got a set of 1.22 (or something) left. The high range gearing dosent really worry me that much cause my rig is just getting more and more towards a trailer rig on anything over a 1 hour trip anyway. What I more concerned about is the low range gearing and wether or not I can get the same sort of torque to the wheels as with the manual riding the clutch.
Sam
Old 01-13-2002, 12:33 PM   #10 (permalink)
v6toy4x's Avatar
Member # 9154
manual trannies can be bump started
manual trannies have far greater compression braking for downhill
manual trannies can be started in gear
typ truck boxes have a rep for being indestructible
most backyard mechanics can rebuild a manual
GO MANUAL
v6toy4x is offline   Reply With Quote
Old 01-13-2002, 01:32 PM   #11 (permalink)
RockRover's Avatar
Member # 4101
*So can an auto
*What are breaks for?
*So can an auto
*Not Rovers!
*Not Rovers!
GO MANUAL...
Hendrix 'X' Chassis #006
http://www.hunt4steve.com/Doug.html
RockRover is offline   Reply With Quote
Old 01-14-2002, 01:47 PM   #12 (permalink)
Member # 4749
Send a message via AIM to Rover Addiction
Bump start an auto!! HAAH
I gotta see you try that! I've tried.. you have to be doing like 30 mph.
I've bump started my manual with the winch! Try that with a slushbox!!
-John
"All the parts falling off this truck are of the finest british craftsmanship."
Rover Addiction is offline   Reply With Quote
Old 01-15-2002, 01:24 PM   #13 (permalink)
Member # 7962
What about overall gearing how does my manual with a 4:1 first compare to the 727 with a 2.45:1 first (and a torque converter). With the wheels not moving can I get the same torque to the wheels with the auto as I can riding the clutch with the manual. What I am worried about is that with the auto and not enough gearing I will get stuck behind a rock and not be able to turn my wheels (like it was in high range).
Sam
Old 01-15-2002, 01:44 PM   #14 (permalink)
road1will's Avatar
Member # 8871
Send a message via AIM to road1will
i wouldnt worry about that aspect sam. the torque converter effectivle gives it almost a 5:1 first gear, and with the TC slipping, it is just like you slipping the clutch, except you dont have to worry about roasting it
you wouldnt be able to drop it into drive from high revs without damaging the transmission, though. if you arent afraid to give this up and want a lot more control and finesse, with better rock crawling ability, go with the auto. the TF727 is an awesome trans, and you can buy all sorts of cool parts for them, like a manual valvebody, probably some lower gearsets, shoftkits, etc. IMO, i would go auto.
road1will is offline   Reply With Quote
Old 01-20-2002, 10:54 AM   #15 (permalink)
Member # 9329
Send a message via Yahoo to brianbonner90
Most of it has been covered.
I don't know why you would want to "Launch" your vehicle. I have never had any reason to do that. but with an auto you can power brake it. thats what I did drag racing 25 years ago. Just hold the brake and punch the gas. the stall converter will let it run. then let off the brake.
an auto makes easing over obstacles very easy. as you won't stall.
i don't know how much but an auto suppossedly increases gearing due to the torque converter.
auto's make wheeling very easy. Kinda takes some of the fun out of it.
Thanks
Brian
http://www.lubedealer.com/brianbonner
Http://www.circle-b.com
brianbonner90 is offline   Reply With Quote
Old 01-20-2002, 10:56 AM   #16 (permalink)
Member # 9329
Oh yeah!
i almost forgot. if you do rocks and other serious wheeling, I huighly recommend installing a tranny temp guage and a good cooler with its own FAN! Or you will cook your pump
Thanks
Brian
Old 01-21-2002, 02:51 AM   #17 (permalink)
Member # 7962
WTF!!!! "why you would want to "Launch" "
Next time you carnt crawl over something put your thing in 2nd low get a few revs happening and GET IT AWN!!!! You will be amazed at what you can drive but hey I guess your banned
Sam
Oh yea if you did get it awn you may have broken a few rover parts by now.
Old 01-22-2002, 02:07 PM   #18 (permalink)
Member # 8843
Send a message via AIM to offroadr35
<---- "got it awn" once in a 95 D90` 2nd low, got the RPMs going...POP!! any loud breaking sound from a Rover drivetrain quickly turns into the sound of $$$$ cha-ching.
-Steve
offroadr35 is offline   Reply With Quote
Old 01-22-2002, 02:11 PM   #19 (permalink)
merv's Avatar
Member # 9396
-John
Try that with a milemerker
Merv.
Warning, spellchecker is switched off, gramma may be errotic.
merv is offline   Reply With Quote
Old 01-23-2002, 03:41 AM   #20 (permalink)
Member # 7962
-Steve
I guess thats the down side. But its amazing what a bit of momentum will do esp. when driving uphill. There is a lot stuff we drive (loose dirt and also solid rock) uphill that just carnt be driven in first but can be in second.
Sam
Old 01-23-2002, 06:53 PM   #21 (permalink)
Member # 9432
Sam,
Im new here, but most of the boys down in Melbourne who compete in the outback challenge/rainforest challenge use Lt95's cause it the strongest manual box LR has made.
My mates 101 has the LT95 and as it comes standard with 9.00x16 tyres I would think it would have to have lower gears.
See what you can find, with 4.7 diffs that should
John
200 Tdi is offline   Reply With Quote
Old 01-23-2002, 07:14 PM   #22 (permalink)
road1will's Avatar
Member # 8871
right... why should it with 4.7s? what does that change?
and besides, he is running f/r dana 44s. he has a lot more options than 3.54, 3.8, 4.1, and 4.7. if i were him id be running 5.38s... i will be!
Old 01-23-2002, 10:36 PM   #23 (permalink)
Member # 9432
stock 3.54 rangie diff to 4.7 = 33% increase
stock 29" rangie tyre to 39" = 34% increase
look like good numbers to me, so you wont have to trailer the truck everywhere
John
Old 01-23-2002, 11:46 PM   #24 (permalink)
Member # 7962
the 4.7s would give me the standard overall ratio although with 39.5in tyres I think that I will trailer. So I think that I will go as low as I can although availability of the gears may be a big consideration. 4.56s I can get cheep second hand (plenty of them) and 4.88s I can get new (some mob stocks them also). If I want to get some 5.38s then they have to import them specially. If they stocked them I would get em but they have to import so if I break one im in the shiat.
Hey MeenGreen63 how strong you reckon the 5.38s are. With stock axles could the pinion break or will the axle always break first. Cause if they are week (like a rover 4.7) then I will probably go for taller gearing.
Sam
