Castor Correction - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2002, 02:03 PM   #1 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Castor Correction
I thought I would run this by you guys and see if it's been done before.
I need to recover my lost caster from the 3" lift. My pinion angle is perfect for a DC drive shaft and the cut drop arms would just mess up the pinion angle.
I have a good buddy** that is a nuclear grade welder and he wants to just cut/turn and weld the swivel ball. I wanted to fill and re-drill the pattern. Anyone else done this ???
** MY buddy Greg is the chief process engineer for Lawrence Livermore Labs and this childs play for him.
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
http://www.pirate4x4.com/forum/misc-...e-history.html
Old Scout is offline   Reply With Quote
Old 01-16-2002, 03:15 PM   #2 (permalink)
Member # 4749
Send a message via AIM to Rover Addiction
Either one should work, but don't forget the panhard rod mounting to the front of the axle and also the steering linkages that will now be moved a bit in relation to the 3rd member. This could be an advantage or a disadvantage depending on what you're going to do with it.
-John
"All the parts falling off this truck are of the finest british craftsmanship."
Rover Addiction is offline   Reply With Quote
Old 01-16-2002, 07:48 PM   #3 (permalink)
Member # 3979
If you want to cut and then weld why not do the ends on the housing where they are pressed together.
If not I would do the weld and redrill method.
I thinkn welding the swivel ball is a bad idea.
roverhybrids is offline   Reply With Quote
Old 01-17-2002, 10:26 AM   #4 (permalink)
RockRover's Avatar
Member # 4101
Your ball's are cast ...Just keep that in mind.
My plan, when I was going to build a Rover/Dana 44 hybrid, was to cut the straight part (tube) off the swivel housing (similar to the line in your pic). It just so happens that with about .02 worth of lath work I could get an interference fit into a 44 axle tube (just past the knuckle). That way I would have a Rover/Dana hybrid and could choose any wms width I wanted and run cheap and easy 30 spliners, all while retaining the stock clearance. Total out-of-pocket cost $350 with axles (cut-respline). Add $525 for a Rover 30 spline ARB.
I've looked at the re-drill method too, but I never had significant caster issues (didn't care about a little wandering on my rig). That would be your best bet IMO.
--D
Hendrix 'X' Chassis #006
http://www.hunt4steve.com/Doug.html
RockRover is offline   Reply With Quote
Old 01-17-2002, 10:33 AM   #5 (permalink)
RockRover's Avatar
Member # 4101
--D
Old 01-17-2002, 01:23 PM   #6 (permalink)
Member # 7962
Being the rough bastard that I am I would just slot the holes in the swivel ball (I would guess that you would only have to slot them about 1/8 inch (this is based on a guessed measurements of a 3ft long arm,3in lift and the bolt PCD being 3in in) So the 1/8 in slot would be stuff all and easily done with a die grinder. Once the slots are done and the rig has been test driven and you are happy with it (with slots you can also change the amount af caster if you arnt happy) you can then drill a new hole and hammer in a dowl so that it dosent move.
I wouldnt weld anything cause it will crack and fall off for sure
Sam
I could be wrong with the calc of 1/8 in but hey WTF
Strange Rover is offline   Reply With Quote
