photos of sleeping arrangements in SWB? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-14-2004, 09:52 AM   #1 (permalink)
Member # 15546
Anyone out there with photos of some sort of temporary sleeping bunk in a 88 or 90? I've got several ideas running through my head but don't want to pass up on the ingeniuity (and lessons learned) of others in this forum.
ezzzzzzz is offline   Reply With Quote
Old 06-14-2004, 10:19 AM   #2 (permalink)
Member # 17655
I'd rig up a hammock from the roll cage.....if some one gives me a d-90, I'd gladly figure something out.
sachilles
-87 Range Rover
-61 Morris Mini
-97 Audi A4 1.8tq
and an 81 Cj-8 project
sachilles is offline   Reply With Quote
Old 06-14-2004, 10:37 AM   #3 (permalink)
Member # 21936
There are a couple of "solutions" on the d-90.com site under "custom mods" and they're labelled "Sleep & Store"
Keith Armstrong is offline   Reply With Quote
Old 06-14-2004, 07:39 PM   #4 (permalink)
redrangie's Avatar
Member # 11072
I don't know about inside, but my roof rack works!
forgings design dot com
metal furniture | fabrication | decor
new | rustic | recycled
redrangie is offline   Reply With Quote
Old 06-14-2004, 08:31 PM   #5 (permalink)
Member # 21704
I spend a lot of time sleeping underneath the trucks. With a creeper or an indian blanket.
Hope that helps. Jack Black makes most sleeping arangements comfy.
JP
legend in my own mind
"bigger on the internet"
pendy is offline   Reply With Quote
Old 06-14-2004, 09:12 PM   #6 (permalink)
Member # 10403
I built a fold-up bed that ran from across the PS rear fender well & over the 'laid forward' passenger seat & the center console. It worked well ... especially when used in the hardtop on those cold mornings camping when I'd just start the car & crank up the heat from my sleeping bag before getting out of bed. Makes those sub-freezing mornings a bit less of a shock to the system .
I don't think I've got any pics, though....
T
tbmcneill is offline   Reply With Quote
Old 06-15-2004, 10:18 AM   #7 (permalink)
chrisvonc's Avatar
Member # 9130
Here is a similar setup from a write up by David Gomes like Troy was describing:
http://www.d-90.com/mod/bed.html
[SIZE=1][B]Chris von C.[/B]
[url]www.d-90.com[/url] | [url]www.rovergirls.com[/url]
What do you mean there are TOO MANY bolts left over?"
[QUOTE=XtremeMarine]Go embalm something, preferably yourself.[/QUOTE][/SIZE]
chrisvonc is offline   Reply With Quote
Old 06-15-2004, 11:21 AM   #8 (permalink)
Member # 13704
Send a message via AIM to ABrooks
I tried running a hammock from one corner of the cage to the other and it sucked. Horribly. There just isnt' enough room in there to stretch a hammock out enough that it's long enough. Stick with a tent.
ABrooks is offline   Reply With Quote
Old 06-15-2004, 11:34 AM   #9 (permalink)
Member # 20109
Well the one shown on D-90.com is 6'5" long, which one would think would be OK for most. If you are taller than that, I pity you for trying to own a D90.....
1991 D90 ex-MOD
red90rover is online now   Reply With Quote
Old 06-15-2004, 12:27 PM   #10 (permalink)
Member # 17655
I've wondered about making something to support the hammock, like something mounted to the reciever in the rear bumper. Might give you the added distance to stretch out the hammock to your liking(might not). Rig up some mosquito netting to put over the open edge...and you are all set.
Could even work with a old military cott. Have the cott itself hang from chords or chains of some time. Assemble when needed.
sachilles
-87 Range Rover
-61 Morris Mini
-97 Audi A4 1.8tq
Old 06-15-2004, 06:18 PM   #11 (permalink)
Member # 13704
Yah, but that's a flat surface -- hammocks aren't. I'm not even close to 6'5" (by a lot) and with enough sag in the hammock that it could fit in the truck, I felt like my spine was at a right angle.
Old 06-15-2004, 08:11 PM   #12 (permalink)
Member # 20109
So don't use a hammock.
1991 D90 ex-MOD
Old 06-16-2004, 02:58 AM   #13 (permalink)
Member # 14136
Try a swag, if you can get them over there.
John
Bush65 is offline   Reply With Quote
