Disco Steering Probs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-29-2002, 07:19 AM   #1 (permalink)
Member # 7111
My buddy has a 97 Disco (Series I) and it is having steering problems. Whenever he turns to the left or right, the steering wheel sticks, any clues as to what it might be?
Thanks
nah
lush is offline   Reply With Quote
Old 01-29-2002, 07:24 AM   #2 (permalink)
RockRover's Avatar
Member # 4101
Could be a bad pump, although failures are rare...Most likely the problem is the box and worn seals...Probably blowing by at full lock.
Hendrix 'X' Chassis #006
http://www.hunt4steve.com/Doug.html
RockRover is offline   Reply With Quote
Old 01-29-2002, 07:26 AM   #3 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
How the PS fluid? Sounds like the box shot and or the pump is out.
These guys have rebuilt units at ~50% less than the dealer.
http://www.meridianautoparts.com/
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
http://www.pirate4x4.com/forum/misc-...e-history.html
Old Scout is offline   Reply With Quote
Old 01-29-2002, 08:07 AM   #4 (permalink)
Member # 7111
the steering fluid is full
nah
Old 01-29-2002, 08:59 AM   #5 (permalink)
Member # 9055
When you say sticks what do you mean? Does it just not come back to center or does it not move at all even if you try to move it back to center? Just wondering has he replaced the steering damper or checked it recently?
GRNRVR is offline   Reply With Quote
Old 01-29-2002, 09:25 AM   #6 (permalink)
Member # 7111
when he turns it to the right (for instance) finishes the turn, the wheel sticks. It can be moved, but it doesn't center itself. Haven't replaced anything yet. Everything else seems to be doing fine
nah
Old 01-29-2002, 10:00 AM   #7 (permalink)
Serious One's Avatar
Member # 8768
might be a long shot, but maybe the steering stabilizer got dinged up?
I'm betting on the pump being shot/belt being loose.
M
Serious One is offline   Reply With Quote
Old 01-29-2002, 01:09 PM   #8 (permalink)
Member # 9055
I was just wondering.. I have heard that this has happend when people have replaced their dampner with a Bilstien one.
Old 01-29-2002, 08:05 PM   #9 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
OHH BOY here we go again!
For the record I use a Rancho stabilizer!
BUY MY BOAT
Old 01-30-2002, 02:50 AM   #10 (permalink)
Member # 7962
Could be a lot of things be really do need more information.
Does it only stick when he gets to full lock and then trys to return or does it stick at any position when he trys to return to centre.
Does the wheel only get sticky at the one steering position or does it randomly change.
Im thinking that it could be a siezed steering u-joint. When these things begin to seize they give some funny reactions.
Sam
Land Rover SIIa, 302W, NP435, NP205, MOG404s, 42in Swamper TSLs, 112in WB
"An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing."
Outerlimits4x4.com - home of aussie rock crawling.
Strange Rover is offline   Reply With Quote
Old 01-30-2002, 05:36 AM   #11 (permalink)
Member # 7755
Highly unlikely it is the box or pump. More likely the dented stabilizer (replace) or the steering U-joint (lube/replace).
But I have been wrong before
Ron
:evil:
evilfij is offline   Reply With Quote
Old 01-30-2002, 09:05 AM   #12 (permalink)
Member # 4749
Send a message via AIM to Rover Addiction
Another couple possibilities..
Steering wheel rubbing on the steering column. My 90 does this and it can be annoying sometimes.
Also, bearing going in the steering shaft somewhere, possibly in the steering column.. Any noises evident there?
-J
"All the parts falling off this truck are of the finest british craftsmanship."
Rover Addiction is offline   Reply With Quote
Old 01-30-2002, 09:44 AM   #13 (permalink)
Jtisdale's Avatar
Member # 8122
I agree, check the steering stabalizer. This also happened to me once when I bent my drag link, check that too.
Johnathan
Jtisdale is offline   Reply With Quote
Old 01-31-2002, 05:07 AM   #14 (permalink)
Member # 7111
Thumbs up
well, it was the stabilizer, checked into it and it was dented. Drives like a champ now. We replaced it with an OME stab
Thanks for the help
nah
