Rebuilding an R380- G*d d**m flaming POS! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2002, 10:10 PM   #1 (permalink)
Member # 7755
Ok so there is NO way I am getting around using some of the special tools.
Anyone attempted this? It looks like I might have a shot at either finding the tools through the dealer or just changing the mainshaft and layshaft bearings if I can find the oil seal puller.
I don't know exactly what is wrong with the tranny, but the splines on the output are A-Okay so what are my other likely canidates? It was pulled when relatively new and replaced (it is out of a 300Tdi 110, date stamped late 98 and was pulled in 99). It spins and shifts ok (not installed so this means little) Which synchros usually go bad? Which bearings should I look at as being a possible issue?
My main concern at this point is the oil seal and collar around the output. Aparantly this is a PITA and I don't have the tool to pull it.
What would you do to rebuild it?
Ron
:evil:
evilfij is offline   Reply With Quote
Old 02-08-2002, 10:02 PM   #2 (permalink)
Member # 7755
Ok so NO ONE has ever even attempted this? I am sure the V8 R380 is similar.
Ron
:evil:
