Member # 37526
Spring-over conversion has begun.
I'm past the point of no return, having cut off the front frame horns this morning. By this weekend I'll have the front framework complete and can then slip the Dana 60 under the truck to get a feel for how the pinion angle and kingpin angles will need to be changed. I'm using some 88 rear springs, the lighter duty version that still have some life in them, so it'll be interesting to see how the truck sits after I get the winch reinstalled. I'm hoping that I get a decent ride height with them, otherwise I'll be having Alcan make custom springs. I want to end up with a ride height very close to what it was with new parabolics installed.
I know that there has been some interest in spring-overs on the board in the past so I'll post up when I get some pictures loaded. Lonn
'67 ex-military 109, 350/NV4500/LT230T |
Spring Over
I think you will be pleased with the end result. I think it will be hard to get your ride height down to an inch of lift without a negative arch to the springs . . .
-Ike PS: how well does your truck cool with that high mounted 8274 in front of the relatively small SIIA grill?
I am what I am - Popeye |
#3 (permalink) | |
Member # 11072
j
forgings design dot com metal furniture | fabrication | decor new | rustic | recycled |
#4 (permalink) | |
Member # 37526
Member # 27975
Lonn, I'm getting ready to do the same thing. Probably start after Christmas. I don't have a DANA 60 front though. I'd love to see some pics. What gearing are you using in the diffs?
Dan |
lets go Squatchen
Member # 14561
Lonn,
can't wait to see the results. Good luck with it. Pete
Want to know how I lost 25lbs in 9 weeks? Try INSANITYŽ. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
#7 (permalink) | |
Member # 37526
Member # 37526
SOA Mockup
This photo is after extending the frame using 3x4x1/8 tube. The extension will be finished with 1/8 inch plate as original. The 2x4 is approximating the final position of the rear of the springs after the civvy shackles are installed. I'm using the military front mounting position. The spring in the photo is installed without the bottom two leaves. I'll probably have to use the full spring pack to compensate for the weight of the 8274. As it is now it lifts the truck two inches over the military parabolic height. I can live with that. I extended the front mounts by 7 inches to move the axle forward by 1 inch, so I'm now a 110. It was the only way to run 37s without interferring with the front rollcage outriggers. With the addition of cutting brakes I should still get around in the tight spots just as well as I ever did.
![]() I'll post up a link to the in-process photos when I finally get them all up.
'67 ex-military 109, 350/NV4500/LT230T Last edited by NEVROVR; 12-06-2004 at 10:32 AM. |
#9 (permalink) | |
Member # 11072
I found that IH front pickup springs are 48" no weight, and are 2.5 width. 1 plus four height. They were spring over stock, and give about 4~5 inches arch from the locator pin to the eye when on my 1 ton IH, which has about 1.5k on the front axle. Oh, and they are military wrap, and 30.00 each at a yard I know. Just fyi j
#10 (permalink) | |
Member # 37526
Lonn
#12 (permalink) |
Member # 37526
Just a few photos to detail the process I used to extend the frame horns. It's still not finished, as a wrap of 1/8" plate will be added.
#13 (permalink) |
Member # 27975
I'm interested in seeing how the Dana 60 fits. I'm getting started on similar mod but the problem I have is I've got full width axles. The right side spring mount is right on the side of the pumpkin. How are you handling that? Are you narrowing the axle by just cutting down the long side a bit so you don't have to shift the springs to the outside of the frame?
Dan |
#14 (permalink) | |
Member # 37526
If you only cut down the long side you'd have to nearly center the pumpkin to keep the track width close to stock. I didn't want the clearance issues with a centered pumpkin. By using the cast-in spring perch the pinion and LT230T align nearly perfectly on my rig and the driveline doesn't interfere with the sump. Lonn
#15 (permalink) |
Member # 37526
1/8th inch plating
These are the finish steps of the frame extension. In the first two photos you can see the bottom strap tacked in place.
![]() ![]() And with the plate on the sides I'm all but finished. I know my welds may look like crap but I've never had one fail. Knock on wood...
#16 (permalink) |
Member # 20394
Looks really good but arn't you worried about the hangers being that far foreword and hanging so low?
BUCK Wild Racing Team 911 Thank you all for your support Widia Cutting Tools www.widia.com PSC www.pscmotorsports.com/ Ruffstuff Specialties www.ruffstuffspecialties.com Artec Industries www.artecindustries.com Tom Woods Drive Shafts www.4xshaft.com www.facebook.com/buckwildracing |
#17 (permalink) |
lets go Squatchen
Member # 14561
Looking good Lonn.
As to hanger location, with a leaf the hanger isn't low/hi. Where ever it is, the spring attaches. By 'lowering' the hanger you lift the vehicle. With the stock short front leafs and 36" tires you cant hardly see the front hangers. Almost 90* approach angle with out the bumper. The longer front springs do mean you need to put the perches further out front, but the benifits will far outway any problems.
#18 (permalink) | |
Member # 27975
Dan |
#19 (permalink) | |
Member # 37526
#20 (permalink) | |
Member # 27975
Dan |
#21 (permalink) | |
lets go Squatchen
Member # 14561
I sleep in the 88 already so any extra is all good. ![]() Pete
#22 (permalink) |
Member # 27975
I know of someone who found a creative way of sleeping in a D90. He lays a cot front to back from the dash over the passenger seat, which gets folded down, and on to the back of the tub.
Dan |
#23 (permalink) |
Member # 37255
You can gain an additional 5 or more degrees of departure angle on a 109 without losing rear tub length by cutting and rewelding the rear crossmember back on at an angle of 45 degrees from vertical.
Bill. |
#24 (permalink) | |
Member # 27975
Dan |
#25 (permalink) | |
Member # 19454
Now back to the post, i am planning the a similar project but i will stop at fitting the rear springs to the front, soa is not a viable option for me. I am planning of using rear paras in the front and maybe mount a set of revolver shakles...... but that will come at a later stage, i will make longer shock mounts up into the mudgaurds or fenders to use all the available travel the rear springs will provide. I am following this post with great interest...... Keep up the good work. Grem
S3 1974 tdi power.The evolution of a series 3 |
