Rover TF727 vs Chrysler TF727 ???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-21-2005, 10:40 AM   #1 (permalink)
cybersniper's Avatar
Member # 18822
I need to know the output of the Rover 727 ??
I need to attach it to a NP231 and I wonder about the similarities between it and the Chrysler 727....
They should be very similar BUT as I have not leyed my hands on the Rover unit (without the transfer attached) I am not sure of the type of output.
Can you help me???
Thanks
Eduardo
91´YJ:Rover 4.2V8+TF727+NP231+crawler box/ XCL coilover 4-link/ 4.88+ARB/D30-superiorCrMo-F8.8/ 2xSAFARI/ 37" COOPER SST/9x17 W.Evans beadlocks/ COMM+NAV/ H2O proof electrics.
07´ JK 2.8CRD: 3" OME springs/ ProFender 2.5 adj rem-res/AEV snorkel Daily driver/280/75-17 COOPER STTMAXX
cybersniper is offline   Reply With Quote
Old 04-21-2005, 11:00 AM   #2 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
/forum/general-4x4-discussion/255772-rover-tf727-vs-dodge-jeep-tf727-differences.html
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
http://www.pirate4x4.com/forum/misc-...e-history.html
Old Scout is offline   Reply With Quote
Old 04-21-2005, 11:10 PM   #3 (permalink)
Member # 18822
Thank you and sorry
Thank you for the information and sorry for being so stupid of losing track OF MY OWN POST.
I was on vacations and had a lot of past email when I returned home.... so much.... that I have not read it yet.
I thought nobody had answered.
Where can I buy the output shart to convert the Rover 727 to jeep output and attach it to my NP231?
Thansk
Thanks
Eduardo
Old 04-22-2005, 05:51 AM   #4 (permalink)
Member # 30670
TF 727 vs Chrysler 727
Can't help on the back end but be aware the 727 lies in the rover rotated clockwise to clear the front prop. This could? cause the Chrysler T box to
be rotated. Check!!.
Regards
In Cog Nito
in_cog_nito is offline   Reply With Quote
Old 04-22-2005, 07:15 AM   #5 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Regards
In Cog Nito
Do they use a special oil pan in the Rover then? Or pickup/filter?
aloharover is offline   Reply With Quote
Old 04-22-2005, 09:36 AM   #6 (permalink)
LR Max's Avatar
Member # 20396
Send a message via AIM to LR Max
Gentleman, please educate me.
I thought the Rover automatic transmission had 4 gears, and the Chrysler 727 only has three??? A buddy of mine said that there was a bolt-on overdrive for the 727, is that what the rover auto has??
Thanks.
LR Max is offline   Reply With Quote
Old 04-22-2005, 10:17 AM   #7 (permalink)
Greg Davis's Avatar
Member # 11066
Max, from what I remember, the 727 was in early Rangies. The 4sp auto you are referring to is the ZF unit. Two completely different animals.
"Wrinkles Only Go Where The Smiles Have Been" - Jimmy Buffett
Greg Davis is offline   Reply With Quote
Old 04-22-2005, 02:48 PM   #8 (permalink)
LR Max's Avatar
Member # 20396
Oh....well then....
Old 04-25-2005, 12:50 AM   #9 (permalink)
Member # 30670
the Rover TF727 and the ZF (also rotated) both have special pans and pickup assemblies to suit this application, the ZF in particular has a very deep pan and pick up pipe.
Regards In Cog Nito
Old 04-26-2005, 01:58 PM   #10 (permalink)
Member # 18822
I have the Rover 727 on hand.....
I went today to pick up the Rover 727 and check what I had learnt in this post:
That the Rover 727 was basically a Chrysler 727 with an adaptor in the output.... and YES it is just that way.
I could not fit it in my truck , because it had the transfer in it.....(same price two units 727+LT230...) so I will have to return tomorrow with a larger truck and pick it up. Then I will disassemble it and post some pictures.
Thansk to all.
All I wish is that after retiring the adapter I find a 21 or 23 spline shaft that I can attach to my NP231.....
Eduardo
Old 04-26-2005, 03:31 PM   #11 (permalink)
Member # 1745
Send a message via AIM to 64rovr
You will find a 10 spline male output shaft. Doesn't mean that you couldn't disassemble the trans and rebuild it with the proper output shaft to suit though. If you do this please let me know as I would buy the rover 727 output from you.
64rovr is offline   Reply With Quote
Old 05-01-2005, 05:33 PM   #12 (permalink)
Member # 18822
We can exchange outputs ???
I can send you the rOVER and you find a 23 spline output for me in the US.
Deal??
Eduardo
Old 05-02-2005, 03:07 PM   #13 (permalink)
Member # 1745
Sounds like it might work-- If I can get you all the stuff to adapt the tail end of the 727 to the 231, you will send me all the parts needed to adapt the 727 to the LT230? I'll do some digging.
Old 06-03-2005, 03:49 PM   #14 (permalink)
Member # 18822
Have you found the parts ??
I have tyhe LT230 stuff in the garage waiting...........
Eduardo
Old 06-03-2005, 09:16 PM   #15 (permalink)
RPR
RPR's Avatar
Member # 23613
64rovr,
If this doesn't work out, Ashcrofts in the UK have the Rover tailhousing for mating it (any) 727 to the LT230 and have fixed the lubrication problem that plagued the Land Rover OEM application.
"The Tonka"
SIII 88" SSW
Rover 3.5 V8 efi
Parabolic/C303 Portal Axle Suspension
...and a F/A '99 D1
RPR is offline   Reply With Quote
Old 06-24-2005, 09:16 AM   #16 (permalink)
Member # 18822
Have you found the Chrysler parts??? I have the Rover parts in the garage waiting. Saludos
Eduardo
