Member # 10313
Rancho RS9009
Anybody ever try RS9009's on stock LR front ends (I.E. no hinged arms or 3-links) ? Looks like about 2" longer travel then Emu's with compressed length of only 15.7" (vs 14.5 for Emu).
I really don't like Rancho shocks but it's a cheap alternative until I find the best way to get the front shocks outside the spring on my Disco I. When that happens, I'll go short body B-steins... keith discosaurus |
IH/Rover Moderator
welcome newbie
I run Rancho 9234 on my RTE 3" I needed to make a simple adapter for the eye style end. The adapter is only 2.00 per side! My front Ranchos are just fine. the rear is a different story.
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
Member # 9428
I am not sure why you would want to move your shock outside of the spring, if you do not want to go with a better articulating front suspension set-up (e.g. 3-link/hinged arms/etc). If you move the shock outside, it is likely that you will be needing to retain the front springs. I still run the shock inside of the spring, with a hinge on the lower mount and have more articulation (with 3-link) than any other rover out there IMHO.
Regardless, MJLee offers the best set up. Rockware offers a replacement shock tower (not on website as to my knowledge) have to ask for it, Rubicon express offers stud to eye converters that you can bolt into your vehicle for cheap and then run eye to eye shocks. Safarigard makes a bolt on tube thing that moves the shock outside just like the MJlee, but it has been known to break a LOT. KC Carpenter makes some nice mounts as well. His web site is never summer off road, or something close to that. You could also go to a weld/fab shop and get a more standard hoop style shock mount with two flanges on the end with a 90 degree bend and mount the flanges to the side of the frame rail. The MJlee has a lower mount in the kit and allows you to run a shock inside and out (progressive shock set up). This is the best mount by far IMHO. The difficulty you will face is making a lower external shock mount. There is a website called www.aa-mfg.com that makes over 400 brackets that will fit a variety of radius bends etc. You could order a 3 dollar bracket and have a shop weld it for a lower mount prior to mounting your shocks, drive home and them bolt on your new upper mounts. Just a thought. Hope this helps. I can send a few pics of my front internal shock mounts if you are interested. Send me your email address. Adam Way P.S. Good luck with the mod. |
Member # 10313
hehehe - just like old times on Discoweb, 'eh Scout
Adam, yes, I know it wouldn't make sense with the stock front suspension. I'm still holding out hope that John at RT will have a new front system one of these days. For various reasons, I don't want to run either the current 3-link design or hinged arms. I'm simply looking for a little more front articulation. I'm pretty much OME shock limited right now on drop with the older (longer?)OME764 front springs. I'm going to transition to the RT SP2 front springs which will bottom the shocks even more. The issue with stud v ring on the springs is minor. Thanks all - nice to see a Rover board where one can discuss more 'out there' mods without getting flamed ! keith discosaurus |
IH/Rover Moderator
Way is right on about AA MFG for parts. I use a shit load of there stuff !
Three of there shock mounts here: One more for the upper rear mount: and one more for the lower rear mount! There only 1.65 ea!
#9 (permalink) | |
IH/Rover Moderator
Got excel?
#11 (permalink) | |
IH/Rover Moderator
#12 (permalink) |
Member # 11072
So what Rancho shock would you all recommend then for a Non 3-Link, stock front end on a Rangie with +2 springs? I have the stud to eye converstion down, but I don't know if I want to use retainers in the front. I have the Rockware cones in the back, and I am only really looking do get the front droop back after the heavier spring install.
Thanks in advance for all y'alls help!
forgings design dot com metal furniture | fabrication | decor new | rustic | recycled |
#13 (permalink) |
Member # 9428
How about you cycle your suspension. Every rig is different and by cycling the suspension you will know exactly how to maximize you travel. Do you want the shock to limit travel? If so get a shcok the will fully extend just prior to the spring getting loose. If you are willing to run limiting straps, have the shock collapse where you need it to and then strap the front end.
Way |
