Member # 22182
Weekend Update -- Those Who Were At The Badlands
So, Darkstar et al, how was the weekend? Any tweaking of the toy diffs necessary?
Quemadmoeum gladis nemeinum occidit, occidentis telum est |
Member # 13047
Gotta rotate the rear axle up. that low pinion is a ROCK PLOW. Needless to say, nothing broke, but I stopped pushing hard after I realized what I was doing with that rear pinion flange. Also, I was able to crawl up stuff easier than before thanks to the lower gearing (4.88 instead of 4.1) and the front ARB (instead of truetrac). Hopefully when I shorten the trailing arms my tires won't get into my rear doors. I've trimmed the doors pretty much as short as possible already. If I have to move the axle back, it will have to wait, and just let the tires rub for now (they won't get cut, I wrapped the door skin around, so there is a nice rounded edge there. I swore to myself that the next suspension will be coilovers, and that is just not in the budget now.
Surplus industrial supplies for sale. Lots of good stuff for your rig, cheap: fasteners, automotive electrical supplies, etc: CLICK HERE. |
Member # 24981
"Hopefully when I shorten the trailing arms my tires won't get into my rear doors. I've trimmed the doors pretty much as short as possible already. " Shortening arms will pull axle closer to doors. I took a RTE A arm extension a redrilled it. The new holes rotated the diff up without moving wheels forward in wheel well. JP
#4 (permalink) | |
Larry [url]www.columbiaoverland.com[/url] |
Member # 13047
I imagine if I was running 37s, I may put it off a while also
that extra inch of ground clearance would make all the difference here...As far as the a-arm extension--you say you made yours out of box and angle--do you think the box is sufficiently strong in this application? it looks like rovertym is machining theirs from solid steel. It is a super simple design though...Do you know the size off hand? Its 6:30 AM and I don't feel much like measuring anything right now.
#6 (permalink) | |
Member # 10313
The road to nowhere ...leads to me. |
Member # 15296
I installed the RTE extension on Thursday. It was drilled in two places so that we can adjust accordingly, the most straight of positions for the pinion resulted in the rear springs arching somewhat and therefore they were rubbing extensively on the cones, so it had to go to the less setting, the pinion is MUCH better nevertheless.
I'm going 4 link front and rear in September, also 90% chance that i'll be taking the whole body off and tube the truck fully - sick of trashing about body panels
'92 Land Rover Disco truggy: Beadlocked 42" Iroks, V8, ZF, dual cases, ARBs, Longfielded, M8274-50s with ropes, etc... '98 Land Rover Discovery: 29" BFG ATs '02 D90 TD5 ST: 33" BFG ATs '91 Defender 110: Build in progress '07 BMW G650X Challange: Interco Terraflex 29" rear tire |
Member # 13047
is the top part made out of solid steel, or box? how much extension is it made for? wanna part with it?
#9 (permalink) | |
Member # 10313
* 3/4" extension * no - it's gotta go on the truck if I ever want it to leave my driveway again
Member # 13047
Well, I went ahead and spent more $$$ and ordered the extension, as well as some wedge shaped spring spacers from Rovertym. That should allow plenty of rotation of the rear axle, and my springs should still be vertical, instead of arc shaped. Its only money I guess.
#11 (permalink) | |
Member # 10313
I told your wife that your truck would soon be riding on Mog axles
