Chile Challenge Carnage Picts Vol. 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-17-2002, 05:52 PM   #1 (permalink)
Registered - Active
Member # 9461
These picts are supplements to the Chile Challenge Carnage picts posted by John P. They show the fubar innards of the Detroit locker after a halfshaft break. And some picts of the twisted (720 degrees, not greater than 1000 degrees as previously posted) halfshaft. Look carefully at the end of the shaft and you can easily see the twisted material. Also note the shaft broke right at the line of the heat treatment (interesting). Hope someone is interested in seeing these. The take home message here is: If you have a rear Detroit in a LR, do not break a halfshaft.
Blister
FrankenRover is offline   Reply With Quote
Old 03-17-2002, 05:56 PM   #2 (permalink)
Registered - Active
Member # 9461
More Detroit breakage:
Old 03-17-2002, 05:58 PM   #3 (permalink)
Registered - Active
Member # 9461
Even More Detroit breakage:
Old 03-17-2002, 05:58 PM   #4 (permalink)
Registered - Active
Member # 9461
More breakage:
Old 03-17-2002, 05:59 PM   #5 (permalink)
Registered - Active
Member # 9461
Twisted broken axle:
Old 03-17-2002, 06:00 PM   #6 (permalink)
Registered - Active
Member # 9461
More twisted broken axle:
Old 03-17-2002, 06:01 PM   #7 (permalink)
Registered - Active
Member # 9461
Final twisted broken axle
Old 03-17-2002, 06:11 PM   #8 (permalink)
road1will's Avatar
Member # 8871
Send a message via AIM to road1will
yowch but if you look at the busted axle, you can see it didnt break where the heat treating ends it broke where it is thinnest. physics rule again! be like me go D70 rear and dont break for the rest of yer life
road1will is offline   Reply With Quote
Old 03-17-2002, 06:25 PM   #9 (permalink)
Registered - Active
Member # 9461
Nani, nani booboo. Mine is bigger than yours is.....
You cannot really see from the pict that there is another sharp black line of the heat treatment right at the breaking point. I would be interested to see if a D70 diff. would fit in the stock location in the rear of a NAS spec D90 and still clear the gas tank. This interference would be even worse if you move the axle back like Doug M. is doing. I think he is going to use a fuel cell in the bed instead?
Blister
Old 03-18-2002, 11:33 PM   #10 (permalink)
merv's Avatar
Member # 9396
Originally posted by BillnSandi
More breakage:
OUCH!
First thing Damien and I did when we got home was to check our rear shafts (We have detroits + ashcrofts also). Perfect. Whew! Ivor painted a line down mine for future reference.
Where to from here Bill? More Detroit or over to ARB?
Merv.
Warning, spellchecker is switched off, gramma may be errotic.
merv is offline   Reply With Quote
Old 03-19-2002, 10:19 AM   #11 (permalink)
Member # 4749
Send a message via AIM to Rover Addiction
Last I heard, he was going over to the darkside and getting an ARB. Especially after that superfast 1 hour ARB install!!!
-John
"All the parts falling off this truck are of the finest british craftsmanship."
Rover Addiction is offline   Reply With Quote
