Member # 4101
Cuppala' progress pics...Finally
Okay...Not the best pics, but at least there here...Here's the frame rail carnage...
Hendrix 'X' Chassis #006 http://www.hunt4steve.com/Doug.html |
#10 (permalink) | |
they already made it through one season of punishment, but can they go another?
#11 (permalink) | |
Member # 4101
Finished the grind and prime on the frame-rails this a.m. Looks stock now (which btw, was the idea with keeping the same sized frame-rails)... Then I (gulp) cut one side of the bed off (like SR's), and did a test fit to the new rails...Fit a little tight, but made it like a dream. I've decided I'm going to bring the tub-cap's together like this \_/ looking at it from the top...I think it will clean up the back end and make it a little more unique. Everybody, and I mean everybody has the straight cut rear tub...I think the straight cut WITH the taper is gonna' be trick...And I can keep the bed outa' the rocks too. Sorry, I didn't have the cam today...Today was a big day...I'll get it goin' on more pics next weekend, when I'll finish cutting the bed, yank the tail-gate, cut the rear fender-wells' all the way out, and push the 70 under it for a wheel-base measurement. BTW, rough measurements show that I can EASILY get 114" out of it...If I want to get...Er...silly...I could push 123" and still have the axle under the end of the rear x-member. Of course only the WMS boy's run that much wb...But think of the ledge climbing possibilities!
#12 (permalink) |
Member # 4101
O'yea...Almost forgot...Many thanks to Mr. Mike for the welding and camera help this weekend...The man is an artist with a mig. 38 deg, 20mph gusting winds...Nice beads....What else could a guy' ask for?
--D
#13 (permalink) |
Member # 7962
Absolutely fawking sensational.
Jeez Doug your rig is gonna be the shit How far in front of the rear of the rig are you gonna run the rear axle. Also how far is the front going to be behind the front of the front fenders. Im just curious as to where your gonna run the axles compared to mine. Sam
Land Rover SIIa, 302W, NP435, NP205, MOG404s, 42in Swamper TSLs, 112in WB "An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing." Outerlimits4x4.com - home of aussie rock crawling. |
#14 (permalink) | |
Member # 7962
Went for a drive on some trails today and the grip the 42s have is incredible. On a couple of ledges and step ups where I previously had to use a fair bit of momentum (say 3000rpm in first) I just idled (and I mean idled - I couldnt go slow enough). Doug, you are gonna love them 42s. Sam
#18 (permalink) | |
Member # 4101
Still haven't decided on the the WB I'm going to run...Like I said in the previous post I can easily get away with 113" wb. That would mean that the front tires would be out approx. 6" and the rear out the same. I think I'm going to shoot for 107 - 110". To be honest the 113" "looks" right front to rear. The tires stick out (sides) about 10" each...With the added track I'm effectivly reducing my CG by 4". I can't wait to get her rolling! --D
#19 (permalink) |
Looking awesome Doug!!!
Can't wait to see that thing together and on the trail! Are you going to cut your existing rear tub to fit over the new rails or ditch it in favor of a tube set-up with just separate panels hung on the outside? Also, since you're ditching the steering gear to go full hydro are you going to just mount an orbital valve where the current steering box is? That thing is going to kick some serious butt by the time you get it done!!! -John
"All the parts falling off this truck are of the finest british craftsmanship." |
#20 (permalink) | |
Member # 4101
I don't have the orbital valve yet...Should have it this week or next....Then I'll decide were it goes. Probably right under the master cylinder.
