Now this is something new... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-30-2005, 06:15 AM   #1 (permalink)
Member # 35099
Send a message via MSN to one_bad_rover
96 D1- This is one I havent seen or heard of yet... any suggestions appreciated...
So the temps have finally dropped out here. Yesterday, on the way to work I noticed that my temp gauge was not in its usual position. In fact it was hovering between "damn cold" and "running temp". Not that I mind the engine being cool, the heater and defrost work as they should but Im curious if this is an indicator of a bigger problem. Or maybe just a temp sensor or gauge?? Item of note. Since this is playing mainly on road, I recently removed the factory air box and dropped a cone filter on. (bumped my mileage up about 2mpg!!)
Anyone seen this or have any input?? Thanks!!
Corey Shuman
www.goldrushexpeditions.com
one_bad_rover is offline   Reply With Quote
Old 11-30-2005, 06:39 AM   #2 (permalink)
Member # 12499
When this happened to me, it was due to the radiator being frozen solid.
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 11-30-2005, 06:46 AM   #3 (permalink)
Member # 35099
Yeah, I was thinking about something like that, but everything seems to be flowing correctly, gets warm underneath, and the behavior continues even after driving for over an hour...Wouldnt a frozen radiator cause an overheat and send that gauge through the roof??
Corey Shuman
Old 11-30-2005, 06:47 AM   #4 (permalink)
Member # 17585
Send a message via Yahoo to Dave_Lucas
one_bad_rover
Maybe your thermostat is missing or stuck open?
How odd. Every radiator that I have seen frozen makes the motor overheat not run cold
Dave_Lucas is offline   Reply With Quote
Old 11-30-2005, 06:49 AM   #5 (permalink)
Member # 21936
I'm with Dave. I've had one Disco t-stat fail open and one closed (!?).
The open one didn't allow warm up during cold weather .... how's your heater output? Still cool too, or normally warm?
KAA
Keith Armstrong is offline   Reply With Quote
Old 11-30-2005, 06:55 AM   #6 (permalink)
Member # 62071
sender unit are a "known fault" on D1's as are thermostats.
ibex is offline   Reply With Quote
Old 11-30-2005, 07:09 AM   #7 (permalink)
Member # 35099
Nice warm and toasty.. thats what throws me off and makes me think its a sending unit, or the gauge itself...
Corey Shuman
Old 11-30-2005, 07:46 AM   #8 (permalink)
Member # 21936
Given that, I'd agree. Are both original? As long as you're in the neighborhood you might consider changing them at the same time.
I don't know the resistance specs on the sender .... anyone, anyone
Old 11-30-2005, 08:07 AM   #9 (permalink)
Member # 12499
I can't believe that anyone who has owned a Rover for any length of time considers the temp gauge to be anything more than a cute dashboard decoration
I think I might wait a while before doing anything at all. If the heater is working, the engine is warming up and the coolant is flowing (I went back and read the original post!). When mine froze up, there was no heat. Yes, bad things happened!
Old 11-30-2005, 08:27 AM   #10 (permalink)
Member # 9817
<< I can't believe that anyone who has owned a Rover for any length of time considers the temp gauge to be anything more than a cute dashboard decoration >>
mine hasn't worked for the last 18mos. i'd like to get a VDO set and be cool like mike
'97 Discovery
SeaRover is offline   Reply With Quote
Old 11-30-2005, 08:41 AM   #11 (permalink)
Member # 12499
There are brand new Autometer oil pressure and coolant temp gauges on the bench for the Disco. They've only been allowed to "Age" for a coupla months, it's too soon to install them yet
Old 11-30-2005, 08:49 AM   #12 (permalink)
Member # 35099
Alright... I may get ambitious and swap thermostats tonite...depends on how the garage heater works... let you know if that makes any difference..
Corey Shuman
Old 11-30-2005, 10:33 AM   #13 (permalink)
Member # 21936
When you do, you'll want to "glue" the gasket to the thermostat housing with a dab of grease / sealant so it stays in place while starting the bolts.
Otherwise its a PITA to hold in place and get the bits all lined up.
KAA
Old 11-30-2005, 10:40 AM   #14 (permalink)
Member # 12499
KAA
High-tack!!!
Old 11-30-2005, 08:04 PM   #15 (permalink)
Member # 15710
PT... Are you sure those are your gauges? I have the same set sitting on my bench awaiting installation. Ahhh but the three link is going in this weekend and the new trailing arms tooo..
Priorities you know..
Karen's nagging me about heated seats too...
Keith
[url]www.rovertracks.com[/url]
[FONT="Arial Black"][I][COLOR="Red"]"in this case your best best is to put in first, floor it and hold on"[/COLOR][/I][/FONT]
revor is offline   Reply With Quote
Old 11-30-2005, 10:41 PM   #16 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Heat, what a novel concept.
keith, the photos of an adjustable panhard or the upper link of the three link?
Pete
Want to know how I lost 25lbs in 9 weeks? Try INSANITYŽ.
www.beachbodycoach.com/petermhope
I love it when a plan comes together
Colorado Springs, CO Based FFL-07/SOT
aloharover is offline   Reply With Quote
Old 12-02-2005, 02:10 PM   #17 (permalink)
Member # 42753
Get thee an infrared thermometer.
Dougal is offline   Reply With Quote
Old 12-03-2005, 01:34 PM   #18 (permalink)
Serious One's Avatar
Member # 8768
You talkin' 'bout me? Just because I have VDO guages doesn't make me cool.
But, the VDO guages themselves are very cool. Mostly because they work well.
Michael
Serious One is offline   Reply With Quote
Old 12-05-2005, 10:21 AM   #19 (permalink)
Member # 35099
Okay, new tstat in this weekend. Same damn thing.. except the gauge sits a little lower, so I found a good dash unit, $45 with a good temp gauge in it, and its on the way. Until then, does anyone have any input as to where the sensor is that controls this gauge? How about a price for the little bastard.. Thanks!!!
--Corey
"If you want to bitch you can come out and fix it yourself.... now get me another beer..."
Corey Shuman
Old 12-05-2005, 10:55 AM   #20 (permalink)
Member # 20109
I think it is a single wire connection near the thermostat.
1991 D90 ex-MOD
red90rover is offline   Reply With Quote
Old 12-05-2005, 12:43 PM   #21 (permalink)
Member # 21936
Two similar senders near the t-stat housing.
One is for the EFI, one is for the gauge......can't recall just now
Suppose you could unplug 'em one at a time and see what effect there is on the gauge "reading"
KAA
Old 12-08-2005, 12:37 PM   #22 (permalink)
Member # 35099
Well, the coolant temp sensor fixed the problem.. $20 or so. And as an FYI, the coolant sensor is a single wire unit, directly behind (if you are looking at the front of the truck) the ECU temp sensor, which is a dual wire.
Thanks for all the help and harrassment!!!
--Corey
Corey Shuman
