Member # 13047
new trailing links
On topic with the Carnage and a question thread, I am putting on some new traling arms that Keith a-la Rovertracks built for me. Nothing real special about them, other than the mounts--they are designed to give the ultimate in wheelbase adjustability. They are bolt on (after all factory mounts are cut off, and new holes are drilled). When I need to lengthen the wheelbase more than the thread at the heim joints will allow, I just unbolt, move a couple of notches, drill new holes, and there it is. Granted, it would have been a lot less time consuming to just weld the mounts to the frame, but oh well. Still a fun project.
The material is 1.75 .25 wall DOM, with a bend for clearance.
Surplus industrial supplies for sale. Lots of good stuff for your rig, cheap: fasteners, automotive electrical supplies, etc: CLICK HERE. |
Member # 13047
Frame prepped--the only thing not done here is the sleeve for the 3/4" bolt that holds the heim joint. The sleeve was made from 1" thin wall tubing and welded into the frame. The large hole that is vertically centered was there--it is on the outside only.
Member # 13047
the frame bracket
Member # 13047
drilling a pilot hole for the through bolt on the inside of the frame, with a neat setup from Keith.
Member # 13047
I expected it to be pretty easy to drill the 3/8" holes through the frame, but it turned out to be a bitch. I broke a bunch of drill bits!! I don't think it would have been possible without a body lift. it was tight.
Member # 13047
complete.
Member # 14944
I really like the idea of moving the arm mounts up and out of the way, mine are getting beat up. How thick is the plate section that makes up the outer part of the bracket?
2001 DII "The parts falling off this vehicle are of the finest British craftsmanship." |
Member # 13047
the bracket is 3/16". the through bolt is 3/4" mounted in double sheer
#9 (permalink) | |
Petty Amm Flipper
Member # 14561
Is there a plate on the indise of the frame? Do the bracket bolts go all the way through the frame? Did you sleave the bracket bolts also? Pete
Want to know how I lost 35lbs? Try INSANITYŽ. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT Last edited by aloharover; 02-05-2006 at 03:47 PM. |
#10 (permalink) | |
Member # 13047
edit--another factor is the top row of holes is right where the weld bead for the factory bracket was, making the metal much harder. I'm sure you've tried to drill through a weld before, so you know how much it sucks.
Surplus industrial supplies for sale. Lots of good stuff for your rig, cheap: fasteners, automotive electrical supplies, etc: CLICK HERE. Last edited by darkstar; 02-05-2006 at 08:26 PM. |
Member # 15296
When I chopped my rear section of the chassis (check out the thread "chopped"), I noticed a "zig-zagging" 3mm run across the WHOLE chassis - I think I'll dice up the lost section to reveal exactly what I am talking about. FWIW, I've never cut or drilled at the chassis, so this coule be the reason why the Rover chassis are so known to be strong...
'92 Land Rover Disco truggy: Beadlocked 42" Iroks, V8, ZF, dual cases, ARBs, Longfielded, M8274-50s with ropes, etc... '98 Land Rover Discovery: 29" BFG ATs '02 D90 TD5 ST: 33" BFG ATs '91 Defender 110: Build in progress '07 BMW G650X Challange: Interco Terraflex 29" rear tire |
#12 (permalink) | |
Member # 14136
This is what I believe you are referring to.
John Last edited by Bush65; 02-06-2006 at 02:50 AM. |
#13 (permalink) | |
Member # 17316
Cheers, Ben. Last edited by ISUZUROVER; 02-06-2006 at 04:18 AM. |
#15 (permalink) |
Member # 13047
I'm going to sell them, but I want to see if I can sell them locally first. I would rather not ship them.
#17 (permalink) | |
Petty Amm Flipper
Member # 14561
Want to know how I lost 35lbs? Try INSANITYŽ. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
#18 (permalink) |
Member # 50744
Dig the mounts. The first one's that Keith ever built were for my old D90. However, they did not have the bend, they were much longer, and we used a different mounts. I beat the crap out of them for two years and the only damage was few scratches
.Might pick up a set of front and rear for my project.
#19 (permalink) |
Member # 20080
i love the end product, but Alex, why not just weld?
do you really think you'll need that much adjustability? i mean once it's setup correctly, wouldn't the heim have enough length to fine tune? or you thinking that belt and suspenders on spandex pants will give you more warm fuzzies?
#21 (permalink) |
Member # 63449
Dan:
How many miles do you have on those joints? When you set them up did you set the preload with 1, or 2 washers? Just curious as to how the races hold up after they get some use.
Greg "Walk a mans mile in boots that don't fit, that's about all I can do about it" SYB |
#22 (permalink) |
Banned
Member # 21405
Not sure what you mean by washers.....On the inside of the C-clip, I have two washers, if that's what you mean. One on each side of the bushings.
As of now, I have about 15,000 miles on them. I grease them with every oil change, and so far I'm not getting any "slop". |
#25 (permalink) | |
Member # 63449
