Double CV driveshafts and t/box bearings? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-08-2002, 04:38 AM   #1 (permalink)
Diesel Jim's Avatar
Member # 9426
Having just (well, in the last couple of months) fitted my double CV drive shafts front and back, i've now got 2 knackered pinion output shaft bearings on my transfer box.
the front one has a <little> play in the bearing, but the rear one now makes the vehicle vibrate badly above 50mph, if you grab the handbrake drum you can wiggle it a few millimeters (as if the rear nut was loose that holds the drive flange on.... but it ain't loose!)
what i'm wondering.... is this just an 'unfortunate coincidence' that my bearings were a little on the tired side anyway, and the extra weight of the double cardon unit (and rear shaft adaptor) just tipped them over the edge (and hopefully 2 new bearings will sort the problem period) or do i have to put up with the bearings not lasting more than 6000 miles between changing
cheers guys
Jamie
Diesel Jim is offline   Reply With Quote Quick reply to this message
Old 04-08-2002, 08:50 AM   #2 (permalink)
Diesel Jim's Avatar
Member # 9426
Re: Re: Double CV driveshafts and t/box bearings?
Originally posted by FroadALicious
No way jaime, are you serious?
are you male or female?
way!.........
and last time i looked i had 'meat and 2 veg' down there.....
Jamie........Mr Jamie......
Old 04-08-2002, 09:04 AM   #3 (permalink)
Member # 4101
fuck you
No...Fuck YOU you fin' peice of shieat!!! What the FUCKS the problem man! Why don't you get your bloody anal puss wart fixed so you can start fucking your dog again, and get off this board...
Your doomed man...
--D
Hendrix 'X' Chassis #006
http://www.hunt4steve.com/Doug.html
RockRover is offline   Reply With Quote Quick reply to this message
Old 04-08-2002, 10:12 AM   #4 (permalink)
Diesel Jim's Avatar
Member # 9426
err..... i think someones got their lines crossed here
anyway, thanks rockrover, i think it's just a 'coincindence' that the bearings have gone. thinking about it... the disco S2 has the double Cv shaft up front (admitidly not has heavy as my one) and that just has the same output bearing as mine.
cheers
Jamie
Old 04-08-2002, 10:52 AM   #5 (permalink)
Member # 4101
Yea, I hope your right...Make sure you mic the housing were the race sit's too. I'd be afraid of the casing becoming deformed at the same time.
-D
P.S.: No it's not wires being crossed...That Froad guy' is an internet terrorist that's declared war on this board...Fin' 19 year old Canadian punk really...Anyway looks like he's gone now. I think Old Scout has intercepted his posts before even we did!
Old 04-08-2002, 10:56 AM   #6 (permalink)
IH/Rover Moderator
Old Scout's Avatar
Member # 17
Send a message via ICQ to Old Scout
Jamie
Froud has been causing problems allover POR. I delete all of his crap. I missed your reply.
http://www.pirate4x4.com/forum/showt...threadid=45878
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working."
BUY MY BOAT
Old Scout is offline   Reply With Quote Quick reply to this message
Old 04-08-2002, 11:16 AM   #7 (permalink)
Member # 9859
Send a message via Yahoo to alia176
Jamie,
I thought the double CV driveshaft is for a compound angle situation; like angle whacked out on X AND Y axis. Or did you go with this due to the extra lift and a single Double Cardon CV wasn't cutting it? I assume you still had UJ vibes too with teh single unit?
alia176 is offline   Reply With Quote Quick reply to this message
Old 04-09-2002, 02:13 AM   #8 (permalink)
Diesel Jim's Avatar
Member # 9426
Originally posted by alia176
Jamie,
well, they're just 'single double CV shafts'... just a stock UJ at the axle end, and the cardon joint at the gearbox end.
i did a write up for the rear one that i built and havn't got it on my website at the moment, but you can read it at :
http://www.d-90.com/tech/cv1.html
although i feel i need to get the shaft properly balanced with the flange adaptor, also i'm fabbing up an 'A' frame unit to tip the axle back slightly to make the differential flange point at the transfer box a bit more, i think this will cure the last remains of vibration (which was brought on, like you said, due to extra lift)
Jamie
Old 04-09-2002, 07:47 AM   #9 (permalink)
Member # 10335
"fabbing up an 'A' frame unit to tip the axle back slightly to make the differential flange point at the transfer box a bit more"
A bit more?
wheres it pointing?
the single uj side needs to have a angle under load of less then 2 degrees to live a happy life
The Land Rover Forum Peanut Gallery
muskyman is offline   Reply With Quote Quick reply to this message
Old 04-09-2002, 08:12 AM   #10 (permalink)
Diesel Jim's Avatar
Member # 9426
mine is 'sort of' pointing in the general direction of the t/box, but not enough.
a mate of mine who has exactly the same springs and propshaft suffered from a bit of vibration still, so he made a unit up to tip the axle back slightly (like the RoverTym thing) and it cured all of his vib's, so i figured i'd try it.
Jamie
