abs conversion - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-11-2006, 08:35 PM   #1 (permalink)
Member # 6298
Send a message via AIM to trent troy
abs conversion
I'm about to rip out all my abs on my 93 RR and wonder if I'm gonna F***up the ECU. Does the brake ECU feed the Main ECU? Thanks, -Trent
trent troy is offline   Reply With Quote
Old 09-12-2006, 06:44 AM   #2 (permalink)
Member # 12499
No, it is completley stand alone.
Make damned sure you post up what you've done, many will be curious about this.
edit-lemme back up. The ABS does talk to EAS ECU. If you ahve air suspension, it may cause some problems, but nothing that can't eb ovecome by converting to coils
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 09-12-2006, 10:11 AM   #3 (permalink)
Member # 6298
Thanks PTSchram, I will post. Best, - Trent
Old 09-12-2006, 11:00 AM   #4 (permalink)
Member # 12499
Trent:
Do you know Matt Boddiford? He is more than capable of helping you out. Tell him I referred you.
PT
Old 09-17-2006, 07:41 AM   #5 (permalink)
FAL
Member # 10162
Paul,
What is it that you're curious for ?
You need the parts list or ... ?
It's such a simple job.
FAL is offline   Reply With Quote
Old 09-17-2006, 09:50 AM   #6 (permalink)
Member # 12499
Originally Posted by FAL
Paul,
Well, if it were so easy, we wouldn't have so many folks asking for info on how to re-drill calipers, what master cylinder to use, etc.
I have a pile of master cylinders and intend to take advantage of some good pricing on '93-'95 RRC calipers to allow me to run vented rotors on my trail rig. Eventually, I'll get enough time and a coupla dolalrs and will rip the ABS modulator/pump out of my Disco and go directly to the calipers instead og having that abortion of an ABS system. Until then, I wanna see what other guys are doing and how they do it. I might learn something.
