shock travel v. wheel travel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2002, 05:47 PM   #1 (permalink)
Member # 10403
Anyone know how to calculate how much a given amount of shock travel will translate into actual wheel travel in a set-up with the shock mounted vertically? Specifically, the front axle set-up of a 90.
Troy
tbmcneill is offline   Reply With Quote
Old 05-26-2002, 12:13 AM   #2 (permalink)
Member # 7962
Measure the distance between the two shocks, then measure the distance between the two tyres (the points where you want to measure the wheel travel) then the wheel travel is the shock travel times the ratio on the two distances.
eg. if the shocks are 6feet apart and the wheels are 8feet and you got 10in travel shocks then the maximum possible wheel travel is 10x8/6 = 13.33333in of wheel travel.
Have fun!!
Sam
Land Rover SIIa, 302W, NP435, NP205, MOG404s, 42in Swamper TSLs, 112in WB
"An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing."
Outerlimits4x4.com - home of aussie rock crawling.
Strange Rover is offline   Reply With Quote
Old 05-26-2002, 12:05 PM   #3 (permalink)
Member # 10403
Sam,
Thanks --- that's exactly what I was looking for-
Troy
Old 05-28-2002, 04:55 PM   #4 (permalink)
RockRover's Avatar
Member # 4101
Okay smartie-pants...Now rake the shock forward 10 deg, AND towards centerline (inward) 4 deg...Now how much wheel travel do you have?
Assume a 14" travel shock on a 69" wide axle...Shocks 60" apart....
Hmmmmmm?
--D
Hendrix 'X' Chassis #006
http://www.hunt4steve.com/Doug.html
RockRover is offline   Reply With Quote
Old 05-28-2002, 05:53 PM   #5 (permalink)
redrangie's Avatar
Member # 11072
I think it's called a tape measure....
lol
johnny
forgings design dot com
metal furniture | fabrication | decor
new | rustic | recycled
redrangie is offline   Reply With Quote
Old 05-28-2002, 09:16 PM   #6 (permalink)
Member # 10403
uhhhh .... Rich?
Troy
Old 05-29-2002, 08:01 AM   #7 (permalink)
Member # 4749
Send a message via AIM to Rover Addiction
Hmmmmmm?
--D
Trying to get someone else to do your work for you, huh?
"All the parts falling off this truck are of the finest british craftsmanship."
Rover Addiction is offline   Reply With Quote
Old 05-29-2002, 02:38 PM   #8 (permalink)
Member # 7962
Hmmmmmm?
--D
Easy
With the shock angled to work out the effective vertical travel is just 14 x cos(10) x cos(4) which works out to be 13.75in.
so the wheel travel will be 13.75 x 69 / 60 = 15.8inches.
Although if you are going to start to worry about the effect of the small angle of the shock then doing the ratio thing isnt going to be all that accurate. You would have to work out the actual geometry and stuff cause the ratio thing assumes everything moves vertically etc.
But I figure it is accurate enough.
Shiat, now doug you should be able to work out how far you will be able to drive up a ramp!!!!!
Sam
Old 05-30-2002, 09:17 PM   #9 (permalink)
RockRover's Avatar
Member # 4101
Ahhhhh....So you DO know your Trig then....Goood Grasshopper....Good.
Actually it's the 4 degree inwards that had me stumped...Not that it really means anything in the real world. Guess that's why I damn near flunked out of Statics in skool...
--D
