Member # 48136
Ah, more DII projects. The DII is finally seeing it's day.
MORE !
[QUOTE=TigerToy;6264675]Hell, we make fun of economists all the time in social sciences. [/QUOTE] |
Member # 59532
neat...an axle sitting behind a truck.....'cummon lad you've got to come up w/something better than that
![]() get the torch out....
Matt Browne Dedicated to the resurrection of junk through engineering? '61 88" IIA 2.5na "Soiled" '89 RRC 300 Tdi 5spd "Swampslut" '95 RRC LWB 300 Tdi auto www.overlandengineering.com.....expansion complete. Now, the only Rover shop in Eliot Maine....is also the biggest. |
Member # 15710
Matt!!! Who let you out of your cage!!!!!
Keith [url]www.rovertracks.com[/url] [FONT="Arial Black"][I][COLOR="Red"]"in this case your best best is to put in first, floor it and hold on"[/COLOR][/I][/FONT] |
Member # 87571
im trying to make a bolt on convertion axle,so that i can sell them to other d2 owners , the idea is that you can swap your standard crap for one of these and some 40s with no messing about just a few hours labour, you would just drive your d2 into my shop in the morning and drive out the same day on portals with 40s that are fully lockable.
Member # 59532
ahhhh....now I get it.
directions to the shop please. Never mind the wet bit I'll just get a snorkle (for me as the slut already has one). ![]() nah, seriously good for you mate. Great idea. Sort of a "drive through" axle swap shop.
Matt Browne Dedicated to the resurrection of junk through engineering? '61 88" IIA 2.5na "Soiled" '89 RRC 300 Tdi 5spd "Swampslut" '95 RRC LWB 300 Tdi auto www.overlandengineering.com.....expansion complete. Now, the only Rover shop in Eliot Maine....is also the biggest. Last edited by Junkyddog11; 06-29-2007 at 04:48 AM. |
#12 (permalink) |
Member # 59532
Ahhh shite...I guess you may as well know....I have internet IN my cage
#14 (permalink) | |
Member # 14944
dooooooooooooooh. I to think I sold my DII.
2001 DII "The parts falling off this vehicle are of the finest British craftsmanship." |
#15 (permalink) |
Member # 48136
c'mon Chuck-- you know you miss the DII
![]() What ever happened to those Ashcroft CVs?
#16 (permalink) |
Member # 16003
what are you going to do about the electronics? NAS D2's need input from the abs to operate without throwing all kinds of codes and kicking up all kinds of problems...
2001 D2 FZJ80 Front/ARB Ruffstuff axle housing rear w/ fjzj80 stuff, Detroit, 37" creepy's, 14" 9100 Coilovers (F) 14" FOA coilovers (R) 1.6 lt230 w/Ashcroft Under Drive PSC hydro steering Hellfire Hi Steer Knuckles...a lot of revisions and a lot of weldin' 1983 110 RHD Pick-up |
#17 (permalink) | |
Member # 87571
#18 (permalink) |
Member # 16003
so to make this clear: you had custom tone rings made for the axle? I'm not familar with the mog axle, but how are you mounting the sensor so it read the tone ring? Also, I looked on that site and didn't see anything like you mentioned....more info
2001 D2 FZJ80 Front/ARB Ruffstuff axle housing rear w/ fjzj80 stuff, Detroit, 37" creepy's, 14" 9100 Coilovers (F) 14" FOA coilovers (R) 1.6 lt230 w/Ashcroft Under Drive PSC hydro steering Hellfire Hi Steer Knuckles...a lot of revisions and a lot of weldin' 1983 110 RHD Pick-up Last edited by mongosd2; 06-29-2007 at 12:59 PM. |
#19 (permalink) |
Member # 87571
thats right , the axle is cut and a lower plate is fitted above the ring that is fixed to the shaft, the ring is in two halves that bolt together , the standard abs sensor is used. if you contact mark at disco parts by email just say you want to correct the speed after fitting bigger wheels he will give you more info on this part.
#22 (permalink) |
Member # 16003
so you can set the mog axle up with abs calipers? Anways, don't give a shit about tc/hdc/abs, I'm using hard lockers, and I'm not even that concerned about the speedo. I'm just need to have proper input from the abs sensors so the truck doesn't start throwing rough road codes. I have something cobbed up now, but it's based on the LR sensor and tone ring, not a Toyota...
Good idea about the custom sensor/axle set-up...Greg, this is exactly what you need for your swap, lucky you... I could probably do the same with the toy axles, but I want to be able to use stock stuff for spares...
#23 (permalink) |
Member # 14944
Every time someone cuts me off in the VW. I would not mind an 04 if the mileage was not suckish. The Classic is almost back on the road.
#24 (permalink) | |
Member # 87571
thats right the abs wiill work along with everthing else , also mog axles have lockers built in . |
#25 (permalink) |
Member # 16003
can you post some pic's of the axle with the ring, and the housing mod? I'm really curious to see what you've done...
