d60/14 axle build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-11-2007, 08:41 PM   #1 (permalink)
Member # 34849
d60/14 axle build
The build begins!
Want to put bets on if this will be done by Sept 21?? Front and rear, oh and don't forget the atlas
stock links won't work... probably going with what Mongo and Aaron have done.
krazz1e is offline   Reply With Quote
Old 09-11-2007, 08:57 PM   #2 (permalink)
aaron t's Avatar
Member # 10086
Send a message via AIM to aaron t Send a message via Skype™ to aaron t
the brackets you need are in stock or can be cut to order at ballistic. if you choose to call ballistic, ask for jeff and tell him i sent you.
i don't work there nor do i get any kick backs if you order. jeff, i just a very good friend and i like to push his product.
it is good quality and it works...plus its a good deal.
most of what you will need for brackets and links will be off the shelf stuff there.
meh.
aaron t is offline   Reply With Quote
Old 09-11-2007, 09:02 PM   #3 (permalink)
Banned
DChapman's Avatar
Member # 21405
What are the specs on the 60? You go wider? Same? What's it out of, chevy?
DChapman is offline   Reply With Quote
Old 09-11-2007, 09:05 PM   #4 (permalink)
aaron t's Avatar
Member # 10086
that is a chevy, it most likely is 69.5" wms. that is i believe the factory single wheel chevy set up. not much variation in the chevy's. it is the dodge that is shorter. so unless justin has swapped on chevy hubs onto a dodge housing. it is full width one ton chevy as noted above.
the dually fronts are like 73".
meh.
Old 09-11-2007, 10:47 PM   #5 (permalink)
Buckon37s's Avatar
Member # 20394
kingpin or cheeseball?
BUCK Wild Racing
Team 911
Thank you all for your support
Widia Cutting Tools www.widia.com
PSC www.pscmotorsports.com/
Ruffstuff Specialties www.ruffstuffspecialties.com
Artec Industries www.artecindustries.com
Tom Woods Drive Shafts www.4xshaft.com
www.facebook.com/buckwildracing
Buckon37s is offline   Reply With Quote
Old 09-11-2007, 11:55 PM   #6 (permalink)
aaron t's Avatar
Member # 10086
that is a kingpin. chevy never made a balljoint 60, they went gayfs, dodge did but i believe that was late model, and only drivers side drop? could be wrong on that, but i think i can see the kingpin bearing caps on the knuckles in those shit ass pics....
meh.
Old 09-12-2007, 06:07 AM   #7 (permalink)
Banned
DChapman's Avatar
Member # 21405
So what are you doing? Adding the axles, full width without cutting them, and installing a 700R4 with Atlas?
Old 09-12-2007, 07:27 AM   #8 (permalink)
Member # 13395
Yah until 1993 Dodge was kingpin 60 front end, but narrower, 67.5 I think. The 1993 CTD I parted for my 109 had that axle. The 1994 have coilsprung 60s with weenie little shafts and balljoints. They are driver's drop (at least in NA!). The Chevys are a safer bet as they didn't use 61s. A lot of early CTDs had balljoint 61s with 3.07 gears. I hear they are workable but it sounds like a PITA.
TDI FZJ80 and Misc LR junk
HandBuilt is offline   Reply With Quote
Old 09-12-2007, 07:42 AM   #9 (permalink)
mongosd2's Avatar
Member # 16003
I was pimping your set-up to him last night Aaron... I sent him ballistic's way for his rear shock towers, so hopefully he'll go that way for the rest of his brackets...
2001 D2 FZJ80 Front/ARB Ruffstuff axle housing rear w/ fjzj80 stuff, Detroit, 37" creepy's, 14" 9100 Coilovers (F) 14" FOA coilovers (R) 1.6 lt230 w/Ashcroft Under Drive PSC hydro steering Hellfire Hi Steer Knuckles...a lot of revisions and a lot of weldin'
1983 110 RHD Pick-up
mongosd2 is offline   Reply With Quote
Old 09-12-2007, 07:48 AM   #10 (permalink)
Member # 34849
yeah full width chevy kingpin with highsteer arm. it's still has 30 outters. It's setup with 5.13 yukon's and a detriot up front. The rear is a 14 bolt w/ 5.13s and a spool, it has discs conversions though. Keeping the full width they will be matched to a true 37" maxxis creepy crawler (comp tread ) on 16x10 rims.
The Atlas is going behind the ZF. Have a conversion kit being made right now, price TBA. Expecting it to be ready this weekend.
I'm calling Ballistic this morning.
Old 09-12-2007, 07:49 AM   #11 (permalink)
Member # 30376
What is the Atlas going to be connected to? Are you going to change the transmission also?
rock90 is offline   Reply With Quote
Old 09-12-2007, 07:59 AM   #12 (permalink)
Member # 58412
Originally Posted by HandBuilt View Post
Yah until 1993 Dodge was Balljoint 60 front end
Is that why my 92 Dodge D60 has kingpins and internal hubs? I guess you meant to say kingpin until 93?
More pics of the build please
olivesta500 is offline   Reply With Quote
Old 09-12-2007, 08:46 AM   #13 (permalink)
Member # 13395
Whatchu talking about? My post says kingpin
(Edited due to lack of coffee this morning)
Old 09-12-2007, 09:33 AM   #14 (permalink)
Member # 34849
stock d1 zf auto tranny.
Old 09-12-2007, 09:43 AM   #15 (permalink)
Member # 75068
Justin; how close are your overall widths front to rear? Are you using a true Detroit in the front, or a trutrac? Considering some people have stated concerns/problems with steering on detroit locker in front, I would like to know which way you are going. I am considering going true detroit locker in the front on my off-road only SIIa. But I have a trutrac in the front on my DII; so I haven't made a final decision yet. Please take off the L-R oval on the front grille, man. It's embarrasing. Hell, I'll give you a payoff if you remove it, just so the truck doesn't embarrass anymore of the Dweb crowd. LOL!
XtremeMarine is offline   Reply With Quote
Old 09-12-2007, 10:49 AM   #16 (permalink)
mongosd2's Avatar
Member # 16003
goes deeper than just a detroit, he's got a atlas t-case...do a little research and you'll see why he can run it...
Old 09-12-2007, 11:22 AM   #17 (permalink)
lwg
lwg's Avatar
Member # 12044
Send a message via MSN to lwg
My guess is he'll either go Ram assist or full hydro up front. If he doesn't he eventually will!
Larry
[url]www.columbiaoverland.com[/url]
lwg is offline   Reply With Quote
Old 09-12-2007, 01:57 PM   #18 (permalink)
Member # 34849
I wouldn't recommend a full DT in any DD rig especially one without manual lock outs. It's true you can't turn worth shit on any high surface traction with it locked. On loose dirt roads it's fine though.
This 60 i picked up just happen to have a DT in it. If it had not it would of got welded. For me they are the same thing, the DT does give me a stronger carrier so it's a plus.
I may consider d60 longs after I break my 30 outters, but then again the warranty may not cover a DT up front.....
Old 09-12-2007, 02:06 PM   #19 (permalink)
Member # 34849
full hyrdro yes. next phase, probably be oct-nov.
Well updates are this:
Ballastic Fabs is working on my brackets should have the here by next Tues. I have not received word yet on my Atlas kit, eta was this weekend or early next. I am going to have a shitload to do next week. But that does free up some time for me to work on my cage. Safety i guess right?
Old 09-12-2007, 04:54 PM   #20 (permalink)
Member # 75068
Well, my guess was that he Was going to run a twin stick Atlas, and be able to go 2wd when he wants. Hence my query. Since my IIa will have the Warn locking hubs, and I will be able to run 2wd whenever I want. That's why I was asking. I figured, it was more apples to apples than comparing his fuggy to a normal DD DII.
Old 09-12-2007, 05:33 PM   #21 (permalink)
aaron t's Avatar
Member # 10086
justin, just talked to frank...
you might be able to get away with not cutting the knuckles, now that i think about it...i have never cut and turned my knuckles on my buggy or on my rover, but the rover is a little twitchy due to <3* pos castor.
on the 60 the pinion angle is fine, but on my rover, it sucks. i don't know if the castor is different on a 44 than a 60?
meh.
Old 09-12-2007, 10:27 PM   #22 (permalink)
Member # 34849
day 2:
waiting for parts on the front moved to the rear. It's was basic just need to add the truss and convert the ball joint to a heim.
Old 09-13-2007, 08:55 AM   #23 (permalink)
Member # 34849
ahhh not concerned with castor more with pinion angle. One of many advantages of being a trailer queen.
Old 09-13-2007, 08:56 AM   #24 (permalink)
mongosd2's Avatar
Member # 16003
Why not a true triangulated 4 Link? You have the room and with the axle truss it would be a easy (well nothings' easy) install...
Old 09-13-2007, 09:38 AM   #25 (permalink)
Member # 34849
Yeah thought about it...problem is $ right now. Front links were higher than I had originally planned. So I have to make with what's there.
