Member # 26828
Huge white clouds coming out of the exhaust, help is need ASAP
Hi there all,
My 110 TDI300 started lately to take out extra white smoke from the exhaust, at the last few days it becomes unbearable. It comes especially when I first start the engine in the morning and at drive time it is mentioned mostly when I take the foot off the throttle while the gear is still shifted & the engine slows down the vehicle. The white smoke is so huge that you cannot see anything & no one can see me also. It seems to me that it's something from the fuel system such a bad injector or maybe lift pump (or who knows maybe the injection pump or timing went off). Does anyone here have a history of such big white clouds coming out of the exhaust? How van I check if its an injector or lift pump or maybe even valve clearance? Thanks, Gali |
Member # 21704
Water in fuel-maybe
Check the impellor on the turbo-seals Is the breather to the valve cover restricted? Belt timing like Red said. Sticking injection pump inards-from corrosion damage. I'll think on it some more and I am sure others will have something to add. JP
legend in my own mind "bigger on the internet" |
Member # 26828
I started the day by disconnecting the breather & checking the return hoses of the diesel fuel.
All seems O.K. the breather is leaking a bit of oil to the turbo inlet but it doesn't seem to be the problem. Later on I checked the inlet of the turbo, there is a slight of movement of the compressor side up & down but not so significant. No bubbles at the water tank, the oil is good (not milky) so I guess no big chances for head gasket. I didn’t checked the timing today but I will do it within a day or two, at the mean time the vehicle is resting at the garage. Is it by any good to check the valve clearance before the timing or should I jump to the water with the timing first? |
Member # 12499
While I admit to being pretty ignorant W/R/T oil burners, isn't white smoke most often due to coolant being burned? Are you losing any coolant?
Wrenchin' to riches! If you want peace, prepare for war. |
#10 (permalink) | |
Member # 101210
2nd pendy's advice. we run veg oil and white smoke is common when water mixes with the fuel. |
#12 (permalink) |
Member # 9615
I don't run a TDI but I've run a few 2.5na rover diesels and white smoke on start up and over run is usually the timing being retarded. Could be the pump bolts are loose or the belt is getting ready to let go. I assume the white smoke smells like unburnt diesel, if not then disreguard what I've said
#13 (permalink) | |
Member # 10313
The road to nowhere ...leads to me. |
#14 (permalink) |
Member # 26828
Hi all,
I just finished with the timing. Seems that the timing belt "jumped" one step, the reason is that the master pulley bolt (27mm) been damaged also the woodruff key at the master crankshaft was damaged so all this pulley wasn’t balanced. Since there been a freedom at the woodruff key the inside pulley of the timing belt suffered few impacts and then jumped one tooth. I finished already with the timing & valve clearance (the master bolt was a bitch, more then an hour to open), I started the engine (with no master belt) for 5 to 10 seconds & the engine works like a clock – round & steady. Now I should get a used pulley & I hope that the spot of the woodruff key at the crank wasn’t damaged so I can fit a new one with no problems, along with a pulley & a bolt (also damaged thread). Thank you all, I really appreciate all your help, gave me the feeling that I'm not alone. I'll keep you all posted. Gali. |
#17 (permalink) |
Member # 17378
Whoever thought of putting a rubber timing belt on a collision motor should be punched in the face.
Lucas trucks are usually dead simple to figure out, there aren't many things to go wrong with them. |
#18 (permalink) | |
Member # 10313
All my modern vehicles (all with non-clearance engines) use stinking flexible belts. Funny - all my OLDER vehicles use chains...wonder ($$$$$$$$$$$) why.
#19 (permalink) |
Member # 17378
True enough.
Here's a picture of what happens when you hit a deer with your Subaru: /forum/general-chit-chat/612342-what-happens-when-you-hit-deer-your-subaru.html jim
#20 (permalink) | |
Member # 12499
Subarus are such great vehicles-yeah right!
#21 (permalink) | |
Member # 26828
Kind of to the Detroit Diesel engine I once work with. |
#22 (permalink) |
Member # 21704
Zues gear suck. They have been breaking all over the planet for years. Id rather have the belt then their product. Its to bad cause the engine could use a good gearset instead. but it is not Zues IMEO.
JP
#23 (permalink) | |
Member # 12499
(says the man with 225K on a Rover V-8 and original timing chain-no, I don't like living on the edge!)
