Member # 94122
Fitting High output steering pump to Rover V8?
I have a 4.2 Rover V8 (pre serpentine belt) to be fitted in a new build challenge truck. I will run Hydro assist steering (as I do now) but need to get a pump fitted up to the engine. I am at present running a ZF high output pump on the diesel but the size, shape and orientation of input and output don't lend themselves to being fitted to the V8 nicely. There are ways I can fit it but nothing that looks right.
So has anyone done anything similar? What pump did you use? How/where did you mount it? Cheers. Steve. |
I scouted round the scrapyard till I found something that looked about right, and fabbed a bracket and modified a pulley to fit. The stock Rover pump is as camp as a row of pink tents, so almost anything you find at the scrapyard will be better.
I later had it pointed out to me by a chap in an anorak that it was the PAS pump from a TDV6 LR3 - it's actually from a BMW that'd been stacked into a ditch, but they could well be the same part. I just picked something with ZF written on it that looked easy enough to mount.
[url]www.FlyingSpanners.net[/url] - The House Of Flying Spanners |
#6 (permalink) | |
Member # 12499
That's a fine setup and better write-up, but it's for a serpentine engine, not vee belt.
Wrenchin' to riches! If you want peace, prepare for war. |
Member # 10335
the pump dosent know what kind of pulley is driving it.
with companies like March that will get you just about any size or offset pulley you ever want I dont see the issue. I would just swap over and select the pulleys that makes it work.
The Land Rover Forum Peanut Gallery |
Member # 10335
here check out this page
http://www.marchperf.com/pg50.html by using the mount from alex's build he could then measure the location of the valley of the crank and water pump pulleys and then select the offset of the pulley needed to run them in line.
Member # 12499
Summit makes a really nice, albeit expensive, nearly universal mounting bracket that looks like it has a lot of potential.
The problem with the Vee belt engine, which you'll learn soon enough on the '94 RRC you're working on, the power steering pump bracket is really, really tightly tucked up in there and saying it's difficult to deal with is an understatement. If you get a chance, give me a call. I don't have your new number. PT
Member # 8122
This is what I ended up with on my 3.9l in my 90. Pendy made the bracket you see and it was modified slightly to move the pump further from the steering box which may not be an issue if your rig is right hand drive. Sorry I couldn't locate any finished pics in the truck.
Pump is a PSC TC style. Pendy may still have the template.
"All men die; few men ever really live." -Braveheart |
#13 (permalink) |
Member # 13047
Hmm. looks like that bracket setup could be modified to run two TC pumps. now there's a good way to get some strong steering.
Surplus industrial supplies for sale. Lots of good stuff for your rig, cheap: fasteners, automotive electrical supplies, etc: CLICK HERE. |
#14 (permalink) | |
Member # 12499
Muskyman has done it, Will Tillery has done it, all the cool kids are doing it (that's why I haven't done it! )
#15 (permalink) |
Member # 21704
They do make the PSC pumps in clockwise and counter clockwise rotation. For your dual pumps darkstar. If I remeber correct there is no room though.
I'll make another bracket if the original poster wants to do this. But I will not be happy about it. After Tis' broken motor mount did in the original and caused me to redo the bracket even tighter I have no love for the idea anymore. LWG has a version of this he accomplished as well. Maybe his is more straight forward. JP
legend in my own mind "bigger on the internet" |
