PanHard Mod? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-16-2002, 09:54 AM   #1 (permalink)
Member # 12313
Send a message via AIM to WBDISCO
PanHard Mod?
It is my understanding that the panhard rod controls the up and down movement of the front axle (correct me if I am wrong). Could lengthening or moving the mounting increase front axle drop, in conjuction with modified radius arms? Has anyone ever removed it? Just a few base questions before i continue on with some front end mods. Peace
Brad (not tall Brad)
It don't have to look good, we ain't building a Rolex.
1996 Disco on 35s
1982 Yota Pickup on 35s (I did a bad thing)
WBDISCO is offline   Reply With Quote
Old 09-16-2002, 10:01 AM   #2 (permalink)
redrangie's Avatar
Member # 11072
Re: PanHard Mod?
The purpose of a PHB on a live axle car is to center the differential/rear under the car. The PHB mounts to a fixed location on the chassis/frame above the differential/rear and attaches to the differential using rubber bushings at both ends.
j
forgings design dot com
metal furniture | fabrication | decor
new | rustic | recycled
redrangie is offline   Reply With Quote
Old 09-16-2002, 10:11 AM   #3 (permalink)
Member # 12718
DO NOT REMOVE AND TRY TO DRIVE ON THE ROAD.
when removed it makes it verry hard to steer
even with modified radius arms (off set arms) they will still be your limiting factor
Drew
green rover is offline   Reply With Quote
Old 09-16-2002, 11:05 AM   #4 (permalink)
RockRover's Avatar
Member # 4101
Don't listen to Green Rover. Remove the thing and see what happens! Make sure you have your friends doing some video as you go around the first turn...O' and make sure your on a deserted street!.
Kidding.
IMO, learn just a tinny little bit more about how your suspension works prior to asking a question like that (much less attempting a mod).
--D
Hendrix 'X' Chassis #006
http://www.hunt4steve.com/Doug.html
RockRover is offline   Reply With Quote
Old 09-16-2002, 05:36 PM   #5 (permalink)
lew
Member # 9081
With a three link front would you need a panhard rod? would the middle link center the axle?
lew is offline   Reply With Quote
Old 09-16-2002, 05:46 PM   #6 (permalink)
Registered - Active
Member # 9461
It would sorta work, but the side to side stability would chew right into the center link poly's, and you would have some side to side motion with this setup.
Billster
FrankenRover is offline   Reply With Quote
Old 09-16-2002, 06:54 PM   #7 (permalink)
redrangie's Avatar
Member # 11072
Rockrover:
Clean out your pm box dude.
j
Old 09-16-2002, 07:55 PM   #8 (permalink)
lew
Member # 9081
Thanks I guess there is a lot more side to side force on a front axle compared to a rear due to steering
Old 09-16-2002, 08:05 PM   #9 (permalink)
RockRover's Avatar
Member # 4101
Originally posted by redrangie
Rockrover:
j
It's been clean! More so now though...Try again.
--D
Old 09-16-2002, 08:12 PM   #10 (permalink)
RockRover's Avatar
Member # 4101
Puuuuleaze...This has got to be the STOOPEDEST thread I've seen in...Well...Ever!
The pan-hard does NOTHING more than locate the axle latteraly....The only disadvantage to having one is the side to side movement when the axle drops out vertically...And even that's minimal. It has NOTHING to do with articulation, max droop etc. If you want to try it go for it...Just don't do it were anyone is going to get hurt.
Steering has nothing to do with why the pan-hard is there either. Look at your rear suspension...It's a 3-link (wish-bone) configuration. The axle CAN'T move latteraly because the link is triangulated. Now look at the front. See any triangulation? Nope. The axle is free to move laterally all it want's too. W/O the pan-hard the axle would probably move 6+" left or right depending on load...You would tweak your radius arm mounts, and probably loose a u-joint (drive-line) in the process...
Yea...Go for it. Then let us all know how much more articulation you get.
--D
Old 09-17-2002, 08:36 AM   #11 (permalink)
Member # 13683
the panhard rod is by all means necessary in locating the front axle, and very much reduces travel on one side of the axle.
Basically, your steering will be so delayed by the axle moving side to side, you could not control the truck while turning at speeds above 15 mph. try taking off your track rod (panhard rod), and steer while the truck is sitting still. the axle will move far more than you think, and any movement is not good minus bushing give.. As for travel, it reduces the travel of the passenger side (or the driver side on your suspension doug due to changing the frame mount to the other side). Most trucks can force the travel anyway. when doing a lift on a stock jeep, the Driver side spring drops in, but the passenger side has to be pryed in, but if you remove the track rod, the passenger side spring goes in just like the driver side.
Note you can drive a coil sprung truck without a track rod, but you must drive well under 5mph, a leaf sprung truck with a removed track rod is a different beast, and can be driven at top speed.
by all means follow Dougs suggestion learn more about your suspension before you go tinkering with stuff, but at least you got help first this time.
save your skin, and keep that track rod on the truck.
P.S. the SG 3 link will not hold without a track rod.
K.C. Carpenter
K.C.
Puffdragon is offline   Reply With Quote
Old 09-17-2002, 08:47 AM   #12 (permalink)
redrangie's Avatar
Member # 11072
K.C. Carpenter
And with a prb/track rod, it still FEELS loose to me......
j
Old 09-17-2002, 09:38 AM   #13 (permalink)
RockRover's Avatar
Member # 4101
a prb/track rod,
j
