OM617 Diesel swap.. - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2010, 08:39 PM   #51 (permalink)
Member # 135332
now i just have to figure out what to use for a flywheel. a 300gd flywheel is too expensive and a 240 only has a 8ish inch disc. i have a chevy small block flywheel but the bolt pattern isnt close enuff. i want to use the 10.5 inch disc the truck already has. suggestions?
rat-boy is offline   Reply With Quote
Old 03-23-2010, 09:35 PM   #52 (permalink)
Archimedean
rustywagoneersdotcom's Avatar
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
I'm just throwing this up against the wall - don't hate me if it sounds stupid...
What about adapting the GM flywheel onto the MBZ flywheel? Or making a plain flywheel surface that would mount to the MBZ flywheel the way the pressure plate would?
IIRC, the MBZ flywheel has a fairly deep section, no?
Someone sort of local sell me a Dodge NP435, or the mainshaft/tailhousing from one.
Or, sell me a Ford NP208 input gear...
rustywagoneersdotcom is offline   Reply With Quote
Old 03-25-2010, 06:01 PM   #53 (permalink)
Member # 135332
that would make the whole mess too tall.
Old 03-25-2010, 07:48 PM   #54 (permalink)
Archimedean
Member # 65100
Yes...
BUT - does a later-model GM SBC (one-piece ream-main seal) leave you enough material to re-work it for the MBZ?
I know the bolt pattern is somewhat smaller than the old 2-piece rear-main engines. Just don't know by how much.
And another 'OR' - GM 60 degree V-6's (2.8 / 3.1 / 3.4) like from an S-10. Would that give you a decent compromise?
Old 03-26-2010, 09:46 AM   #55 (permalink)
Member # 12758
Here the flywheel from 4x4Labs. It is drilled for 10.5" and 11" GM clutch (your choice). It uses a $110 Ford V8/V10 swap (search 2000 E-350 V10 for the app) and it is just awesome.
Writeup of the kit here:
/forum/toyota-truck-4runner/868339-4x4labs-com-om617-mercedes-diesel-adapter.html
And full writeup of installing it on the engine and what it takes to balance it (I just got it back balanced yesterday):
http://www.expeditionportal.com/foru...253#post589253
Large aluminum flywheel with replaceable center steel section:
dieselcruiserhead is offline   Reply With Quote
Old 03-31-2010, 08:08 PM   #56 (permalink)
Member # 135332
http://www.pirate4x4.com/forum/showthread.php?t=868339
that looks expensive. i was hoping for a cheaper solution and i found it. time for some wrench spinning.....
Old 03-31-2010, 08:39 PM   #57 (permalink)
Archimedean
Member # 65100
Share with the class!
Please?
Pretty please?
Old 04-02-2010, 08:01 PM   #58 (permalink)
Member # 135332
soon grasshopper. i must first make sure it works. by mid next week i should know...... have to gather the rest of the pieces.
Old 04-07-2010, 11:29 AM   #59 (permalink)
Archimedean
Member # 65100
It's mid next week, maaaaaannnnnn....
Old 04-08-2010, 10:41 AM   #60 (permalink)
Member # 114940
I'm following this one with interest as well, and I'm really curious about the kit to bolt it to the LR auto box
ArmyRover is offline   Reply With Quote
Old 04-11-2010, 05:51 PM   #61 (permalink)
Member # 135332
86-91 5.0 mustang flywheel will work with minor mods(one hole needs elongated and rebalanced). uses a 10.5 disc. 1/4 inch spacer between flywheel and crank makes the stack height correct if using a 1/2 inch plate for adapter plate. i will be taking donations so i can quit my job to have the time to finish up the swap.
Old 04-11-2010, 06:10 PM   #62 (permalink)
Archimedean
Member # 65100
Freakin' Sweeet.
What's the starter situation in this scenario?
Old 04-12-2010, 06:09 PM   #63 (permalink)
Member # 135332
Freakin' Sweeet.
i dont need no fawkin starter.
i plan on using a race 5.0 starter but i havent tried it yet. i guess we'll see.
Old 04-12-2010, 08:06 PM   #64 (permalink)
Archimedean
Member # 65100
I expected an SBF gear-reduction starter. Cool.
Old 04-12-2010, 08:49 PM   #65 (permalink)
Member # 135332
you gots a better idea?
Old 04-13-2010, 05:43 AM   #66 (permalink)
Archimedean
Member # 65100
No sir. I think that's the logical choice.
Old 05-06-2010, 12:08 PM   #67 (permalink)
Member # 49032
Well I guess I should show pics of my progress, its slow but we are doing this from scratch so what do you accept.
And since no one has really built an adapter for this, I had to do this on my own,with the help of Chester who is doing all the fab work.
I did get the bell housing adapter plate from Robert Davis. But Chester had to fab up a torque converter for the Land Rover Disco Trans to mercedes .
Here you can see the adapter plate from Robert Davis.
And this is the one Chester made from scratch.
franko is offline   Reply With Quote
Old 05-06-2010, 02:20 PM   #68 (permalink)
Archimedean
Member # 65100
Can I have the Mercedes?
Old 05-06-2010, 03:42 PM   #69 (permalink)
Texas by GOD
Member # 69765
I need this.
~ Kyle
1999 Land Rover Discovery II - Lift, Tires, Axles, Stuff. /forum/land-rover/924588-my-d2-axle-swap-thread.html
2006 Range Rover Urban Assault Vehicle
Kyle_T is offline   Reply With Quote
Old 05-06-2010, 04:56 PM   #70 (permalink)
Member # 49032
Right I'll just have it shipped out to you.
Old 05-06-2010, 08:19 PM   #71 (permalink)
Archimedean
Member # 65100
Not to overly hijack - but if that body is nearly as nice as it looks, I'd do a fair bit of driving to get a hold of that.
Old 05-07-2010, 08:46 AM   #72 (permalink)
Member # 49032
What you guys don't have clean 80's Mercedes cars over there. Anyway I am pretty sure its already spoken for .
Old 05-07-2010, 12:41 PM   #73 (permalink)
Member # 114940
So is there any word on Roberts kits being near completion for sale? Do you have any plans on offering the TC adaptor?
Old 05-17-2010, 02:30 PM   #74 (permalink)
Member # 12758
Did you guys compensate for the external balance on the OEM mercedes flywheel? They are externally balanced to they have to be reinstalled on the engine the same as they were otherwise you get a little vibration...
Old 05-18-2010, 03:23 AM   #75 (permalink)
Member # 17378
Like Cruiser said, mark the flywheel how it came off the engine and have it spun by someone who balances flywheels. Many are neutral but some are not. If you're flywheel isn't neutral you'll want to have your new adapter balanced to match it.
By the way, nice work on that. You're not worried about the aluminum fatiguing and cracking?
Are you going to set that in there crooked? I hate how that looks. Ghetto. I'd re-index that adapter and cut the oil pan. Or install a Chrysler Slant-Six.
Lucas trucks are usually dead simple to figure out, there aren't many things to go wrong with them.
Mercedesrover is offline   Reply With Quote
