#26 (permalink) |
Member # 20394
Haters throw hate like rice at a wedding.
BUCK Wild Racing Team 911 Thank you all for your support Widia Cutting Tools www.widia.com PSC www.pscmotorsports.com/ Ruffstuff Specialties www.ruffstuffspecialties.com Artec Industries www.artecindustries.com Tom Woods Drive Shafts www.4xshaft.com www.facebook.com/buckwildracing |
#27 (permalink) |
Texas by GOD
Member # 69765
got the caster set (cut and turn. pain in the butt...pipe cutter wouldnt fit... so had to carefully use a grinder cutoff wheel... ) 4* caster with the pinion at 16*.
got one front shock, spring seat done, it got to dark to snap a pic so ill grab one tomorrow.
~ Kyle 1999 Land Rover Discovery II - Lift, Tires, Axles, Stuff. /forum/land-rover/924588-my-d2-axle-swap-thread.html 2006 Range Rover Urban Assault Vehicle |
#29 (permalink) |
Texas by GOD
Member # 69765
~ Kyle 1999 Land Rover Discovery II - Lift, Tires, Axles, Stuff. http://www.pirate4x4.com/forum/showthread.php?t=924588 2006 Range Rover Urban Assault Vehicle |
#30 (permalink) |
Texas by GOD
Member # 69765
got it driving. Need to get the ABS sensor harness made, rear drive shaft isnt hooked up (flange issue) and i need to adjust the front a little more forward and get the pinion angle right, then do some trimming. also need to get the steering damper hooked up.
drives good, leans a little in the corners, but rides nice and smooth. swaybars might be in the future. for some reason it sits a ton higher than before... more than just the tires... brakes work a ton better, even with the D2 MC and booster. Exhaust is jankafied at the moment though. Ideas on how to retain the front springs? (with the shock in the middle....)
~ Kyle 1999 Land Rover Discovery II - Lift, Tires, Axles, Stuff. http://www.pirate4x4.com/forum/showthread.php?t=924588 2006 Range Rover Urban Assault Vehicle Last edited by Kyle_T; 11-15-2010 at 06:15 AM. |
#31 (permalink) | |
Member # 13683
You wont believe me when I tell you, but two high quality hardware store hose clamps is all you need to retain the front springs. Just replace them every year or so if you wheel it hard. I ran these on my D-90 out of desperation, and never changed it. They work great.
K.C. |
#32 (permalink) |
Texas by GOD
Member # 69765
wow, never thought of that. ill look for some next time im out at hd or someplace.
#33 (permalink) | |
Member # 26821
Serg |
#34 (permalink) |
Member # 13683
That's one of the better ways to mod the radius arms. I've done that setup on a few trucks to date. There are a few other options to. My d-90 had a hinged radius arm with removable pin.
K.C. Last edited by Puffdragon; 11-15-2010 at 08:30 PM. |
#35 (permalink) | |
Member # 20394
#36 (permalink) |
Member # 13683
Surprisingly, they were "bulletproof" for me on 12-13" shocks. I only used them up front. Pretty impressive what those little cheezy clamps can do. Again, everybody though I was crazy and though they would rip apart on every trail we hit, but they lasted a long time. Without them, my springs would unseat about 4" or more.
YOUR RESULTS MAY VARY!!!!! ALSO, GHETO GAYNESS FACTOR ONLY APPLIES IF YOU SHOW THEM OFF TO YOUR BRAH!!
K.C. Last edited by Puffdragon; 11-15-2010 at 09:43 PM. |
#37 (permalink) | |
Member # 26821
any pass on of forces that wouldnt show up with stock arms? any noticable difference because potentially the axle roll axis was different from the remaining stock arm to modded? cheers, Serg |
#38 (permalink) |
Texas by GOD
Member # 69765
i am planning on running straps to keep the shocks from stopping travel.
#39 (permalink) | |
Member # 13683
When pinned, it drove stock. Everything was basically in stock form at this point. When unpinned, I got horrible understeer, and funky floaty body movement that you would expect from a slinky crawler. Unpinned on the street was not dangerous, but certainly was not optimal for inexperienced drivers. Thats why it has the pin though. Offroad, the hinged arm was excellent. It did have a few funky characteristics while climbing under power. This did require slightly different lines to keep her stable. The hinged arm is a good all around mod that is uber cheap and makes for a very capable little wheeler Now to the modified bushing radius arm Well, in my opinion, this was a sweet setup. Travel was very controlled and smooth. The increase in travel was fairly large. On road manners were excellent with proper spring rates and valving. Almost unnoticeable to even seasoned LR drivers. Offroad, you could use the truck like a rally truck, or a fairly serious crawler. In my test track, it proved to be much more stable than the hinged arm, and didn't require crawling under the truck to remove a pin. It does require more loading to flex the truck, and would benefit from a rear axle sway bar. The fab work to do this is fairly minimal, but certainly more involved than the hinged arm. If I had a daily driver/Crawler LR, this would be my first choice to mod the suspension.
K.C. |
#41 (permalink) |
Texas by GOD
Member # 69765
Me? Yes. Lc tre at axle chevy at box. Panhard is Lc at the axle a slee adjuster and the disco end at the frame.
#42 (permalink) |
Member # 20109
With all of these were you only using the later wide, three shell bushings or did you ever try the earlier narrow bushings? Not that I've measured, but I'm guessing from seeing trucks drive the same lines that the narrow bushings allow double the articulation to the wide ones.
1991 D90 ex-MOD |
#45 (permalink) |
Texas by GOD
Member # 69765
my RA's are for sale...
well used and super flexy.Got 3 of 4 abs sensors wired and good, 4th I goofed up the splicing or something because it has a fault for just that one sensor (wiring OHM too high or low fault) so I need to redo it. they are crimped right now, but since it worked, i am going to go back and solder, shrink wrap them. have a few parts from ballistic coming to make it more adjustable and push the axle farther forward. somehow my lower link is about 2" too short and I dont want to run too much thread out on the joint.(other end was notched and welded bushing) swapping that for a insert and threaded ballistic bushing housing.
#46 (permalink) |
Member # 13683
Stock frame side, but the axle side mounts changed, as well as one arm had the bushing separation changed dramatically. This is what increases travel. I have also done with with two heavily modded RA's but the axle wrap presents an issue and was a bit more complicated.
K.C. |
#47 (permalink) |
Member # 47968
I've got a set of narrow QT arms. I need to adjust the axle end to fit the narrower arms. I can't decide how I'm going to do it yet. Especially considering the return on time investment.
Hijack temporarily off. |
#48 (permalink) | |
Member # 26821
#49 (permalink) |
Texas by GOD
Member # 69765
No he means you get 8" instead of 4"...
#50 (permalink) |
Member # 20109
Pretty much.... The narrow ones will use the full stock 8" shock in articulation, and a bit more. The wide ones come nowhere close to using even the stock shocks. YMMV...
1991 D90 ex-MOD |
