#401 (permalink) |
Phobohomic
Member # 55687
Scott, where is that published?
Dale RUBICON ROCK HEADS ______________________________________________ R.I.P. Dennis Mayer. W2DWM. Rubicon Rock Head & Pirate of the Rubicon. |
#406 (permalink) |
flamethrower
The SlickRock I know is in Stanislaus National Forest.
What's all the Hub-bub about Blue Stars??? Click Here Haulin the Groceries AND Haulin the MAIL
#407 (permalink) | |
Member # 17870
As stated above Slickrock off of Hyw 4 is in the Stanislaus Nat. Forest. The other popular trail up Hyw 4 Deer Valley Trail is in either Stanislaus, or Carson Iceberg NF. Possibly neither since it is in a corridor, not sure how that works. The only National Forest affected by this is Eldorado.
Arguing with a inspector is like wrestling with a pig in the mud. After a while you realize the PIG is enjoying himself! |
#409 (permalink) |
flamethrower
The last section of Deer Valley is in Stanislaus (HWY 4).
#410 (permalink) | |
Member # 17870
I want to correct my mistake. Deer Valley Trail is in either Stanislaus, or Mokelumne Wilderness! Is what I ment to say. But upon looking at this map http://www.gentryoffroad.com/php/map...oradoblank.jpg it gets even more confusing. It looks like a very small part of the trail does touch Eldorado NF. The rest of it is in Toiyabe NF or the Mokelumne Wilderness. I still dont understand how it works when the trail is in a wilderness corridor. Bebe, maybe you can explain? ![]()
#411 (permalink) |
flamethrower
Click on this link, it will open a PDF Map in Stanislaus NF and show the different boundaries.
http://www.fs.usda.gov/Internet/FSE_...rdb5112671.pdf I can put it up as a map tomorrow. This map shows the portion of the route that is unjustly and unnecessarily closed http://www.fs.usda.gov/Internet/FSE_...rdb5364201.pdf
#412 (permalink) | |
Member # 62884
The only part affected is on the Eldorado side. Naturaly, none of the trail is in the Mokelume Wilderness, it is a cherry stem between the wilderness boundry. regardless, no matter what part of the trail is affected, it will be impossable to travel from Blue Lakes to highway 4, unless the judge decides that the trail can remain open while the suplimental study is done
Friend of Eldorado National Forest |
#413 (permalink) |
Member # 12908
so it appears one may leave hermit valley and climb up the deer valley trail to just about the southern water crossing, then turn back. Some of the better obstacles are in this area anyway. Maybe camp at the old shingle mill site and return to Hwy 4. If true, its going to be busy and crowded up there this summer.
Who is John Galt? Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore '81 CJ8 '01 2500 HD 8.1/Ali Life Member BRC Cal 4 Wheel. ECV #3691 www.HillsAngels4x4.com www.reno4x4.com |
#414 (permalink) |
Member # 83913
Has there been any word about when the Judge is going to make his decision regarding this summer? (ie. trail open/closure of the wetlands areas only/complete trail closure)
'85 Xtra Cab 3rz,Duals, D60/14b, Detroit front/rear, 35spline chromos,rears/chevys, bad temper |
#416 (permalink) | |
Member # 200856
As a fellow wheeler, it's encouraged to abide by the law -- If you see people entering or leaving on CLOSED Trails, then kindly inform them of the status. In need of contacting enforcement -- CALL the Forrest Service as they have the jurisdiction. Local law likely will not lift a finger unless the "attitude" is quite flagrant, again as described to us. http://www.fs.usda.gov/eldorado Last edited by Wh1t3NuKle; 05-17-2012 at 08:42 PM. Reason: Removed Synopsis, overly brief and context sensitive. |
#417 (permalink) | ||
flamethrower
Hmmmm...
This is where I think most folks miss the details. Taken from the JUDGES ORDER: Quote:
One of these things is not like the others, One of these things just doesn't belong, Can you tell which thing is not like the others By the time I finish my song? [/Sesame Street Song off]
#418 (permalink) |
Dent'n Soup Cans
I'm still lost on why the judge ruled to close the trails. The "study" could have been made with the trails open.
Is there anyway a group of users (not .orgs) sit down with these idiots and discuss the closures?
N-06177...N-06178... and 63 more to go. KEEP OUR PUBLIC LANDS OPEN TO THE PUBLIC Last edited by 71BRONCO71; 05-21-2012 at 11:47 AM. |
#419 (permalink) |
AF6 OD
Member # 46467
Hey I got a response to my e-mail
Dear Mr. Ervin, Thank you for contacting me regarding the closure of routes in the Eldorado National Forest. I appreciate the opportunity to learn of your views. According to the U.S. Department of Agriculture (USDA) Forest Service, on May 26, 2011, U.S. District Judge Lawrence Karlton found that the Forest Service failed to comply with the National Forest Management Act (NFMA) when it designated 42 existing wheeled motorized vehicle routes that cross portions of meadows. The court found that the routes failed to meet standards and guidelines for meadow management contained in both Eldorado National Forest Land and Resource Management Plan (LRMP) and the Sierra Nevada Forest Plan Amendment (SNFPA). The primary concern was segments of the routes that may affect meadows. On February 14, 2012, the court directed the Forest Service to submit a proposed order that will set aside the decision that designates the 42 routes to the degree they go through meadows, and not affecting the sections of those same roads that do not go through meadows, unless they cannot otherwise be reached. The Forest Service submitted the proposed order on March 14. The court also directed that the current seasonal closure for those routes remain in effect until the court order is issued. Judge Karlton is currently reviewing the Forest Service's proposed order and the response by the plaintiffs. The Eldorado National Forest will begin the Supplemental Environmental Impact Statement after the Judge's final ruling. An updated, free-of-charge motor vehicle use map that shows the routes that are open to wheeled motor vehicle use will be available at all Eldorado National Forest offices in June 2012. While I support the protection of our National Parks, wilderness areas and public lands, in my view, it is essential to consider all factors, including recreation use, when making decisions as to the best use of public lands. Although I am committed to the preservation of our nation's land, it is my belief that the American people should also be able to enjoy these resources. The lands are owned by the people. Our policy should balance the protection and enjoyment of our public lands. If our public lands are well managed both wildlife habitat and outdoor recreation should be able to be accommodated. Please be assured that I will keep your views in mind should OHV related legislation come to the House floor. Again, thank you for taking the time to share your views with me. Since no legislation is on the house floor, its in the courts. The different groups ( there are many) will continue to tie things up in court as it works for them. The F.S. is waiting to see what the ruling will be, ( i.e how they need to close the routes) as one side wants permanent gates, while the FS likes whats cheap and easy, like Carsonite's Since it will take at least a year for the EIS and then there will be a lot of back an forth for several months. But in the end, I don't think I will see DV reopened to 4x4's in my life time. Even with the FS wanting to open the routes.
73 IH Scout |
#421 (permalink) |
Dent'n Soup Cans
Deer Valley/Strawberry Closed?
That response seems to be researched. Like he/she does not want to offend any sides.
But I'm still saying that we the people have been proven guilty before innocent. Jerry McNerney still hasn't responded to my letter.
N-06177...N-06178... and 63 more to go. KEEP OUR PUBLIC LANDS OPEN TO THE PUBLIC Last edited by 71BRONCO71; 05-21-2012 at 11:59 PM. |
#422 (permalink) |
Member # 118129
I may have missed this somewhere in the thread, but is there a definitive answer that the part of the Deer Valley trail that's in the Stanislaus National Forest will remain open? Short of installing another gate where the two forests meet I am not sure how they'd regulate people running in and back out to the Highway 4 side.
I am hoping to at least run the Stanislaus side of the trail this year... I feel like that trail owes me something after I broke real bad last year there! Nice little trail, great camping and scenery, sad to see it closed (even if temporary). |
#423 (permalink) |
flamethrower
You'd need to call Stanislaus NF for that info.
And, to Craig and Ryan...I give up. I don't know how many ways I can explain it. You both should read the Court orders. There were no orders that the meadows were "bad", he (Karlton) said they didn't do their due diligence for the Riparian Conservation Objectives I and II in the study. It's a paperwork thing...period. That's how CBD and Karen always screw us. The FS doesn't hear anything except what they want to hear. So they are using this opportunity to hurt us. Because well, their goal is to shut down Off Roading. I only know (personally) 3 people in all of Region 5 that are not evil. 3
#424 (permalink) | |
Dent'n Soup Cans
I will not lay down any time. Like Kurt says, "I will fight tooth and nail for every INCH OF TRAIL!" "offroading" is much more than big tires and suspension. I really wish "they" would understand it is really taking a car/suv/truck/station wagon/hybrid off of the pavement and driving to a lake, driving to clearing to spend the night, driving to the stream to cool off, driving to go out doors and live life the way it was meant to be lived.
N-06177...N-06178... and 63 more to go. KEEP OUR PUBLIC LANDS OPEN TO THE PUBLIC |
#425 (permalink) |
AF6 OD
Member # 46467
Dan Lungren.
Ok so its a paper work snafu. I've been talking to anybody that will listen. I bring the topic up slowly, maybe about going green. Like going green is transferring money from my pocket to the government or environmental groups. I talked with my dentist and mention that you can't drive your car into camping places I know they have been too. I've posted on other forums, where readers still think the CBD is a good org that plays a balancing role with "offroaders" Once I post up a map of 50,000,000 acre's they want classified as critical habitat for the Mexican Jaguar in there home state. I did not hear back. Well it covers 2 states. But once classified all federal land will be impacted within the 2 state area. http://www.biologicaldiversity.org/s...al_habitat.jpg
73 IH Scout Last edited by R290; 05-22-2012 at 09:28 AM. |
