20kw Gas turbine powered military generator TRADE (hayward. CA) - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Misc. Stuff For Sale
Old 11-17-2011, 05:32 PM   #1 (permalink)
Member # 111947
was thinking about using the engine in a old flat fender jeep project and running a hydrostatic pump off of it as others have done but have way to many projects lately. Interested in all kinds of trades from guns to tools to toyota parts, good running 22re, coilovers, tools, honda generator, dirtbikes, atvs you name it i'll consider it. i value the generator at $1200.00 USD cash offers are welcome aswell. Know somebody who just might have to have it? e-mail your buddy a link to my listing and if he buys it i'll send you a case of beer of your choice
contact info: thewhitestjamal@gmail.com or call/text message 7O7-48O-8695
SPECS:BELOW
EMU-12 Gas Turbine Generator
Notes: 20kw at 400Hz, 3ph, 120/208VAC power, compact skid mounted, portable, self-contained electrical power unit. The generator is driven by a gas turbine engine, enclosed in a lightweight aluminum enclosure. May operate on JP4, JP5, kerosene, or diesel fuel
Physical Properties:
25" wide X 28" high X 60" long , Weight - 545 lbs
Specs on the engine below
GTP 30-67 GAS TURBINE ENGINE
Model and Type
GTP 30-67 Turboshaft, 1- stage centrifugal compressor, 1 combustion chamber, 1-stage turbine.
Compressor
Radial air intake between compressor and reduction gearbox. Single-entry impeller mounted back-to-back with turbine wheel on main shaft.
Combustor
Reverse air flow. 1 duplex fuel burner.
Turbine
Radial inflow type. Turbine wheel with integral shaft supported in 2 ball bearings ahead of wheel. Exhaust temperature 1325 F (718C)
Exhaust
Fixed area single exhaust outlet.
Power outlet
Reduction gearbox at front of unit. Output shaft 8,000 rpm.
Control System
Electro-pneumatic type. Automatic starting. Acceleration, load and speed controls. Pneumatic exhaust temperature limiter.
Fuel System
AiResearch integral fuel system. Pump, 230 psi, governor, internal relief valve, and flow control with filter.
Ignition System
Bendix-Seintilla or G.L.A. ignition. 1 igniter.
Lubrication
system, 32-37 psi air cooled, tank.
Width and height
18.63. in and 16.80in.
Length
25.80in.
Weight
87lb.
Fuel specification
Gasoline, Kerosene, JP-4,8 JP-5
Power/Weight
0.68shp/lb.
Oil specification
Mil -L-23699, L-7808
Oil Consumption
0.15 phr.
Rating Max cont
60shp/52,870 rppm/sea level.
(others have claimed this is more like 100shp since the military derates all their engines)
Generator is complete (minus the gas cap) and has a recently overhauled 24V starter. The engine will spin up with ease but will not light off. This engine was running 2 years ago so i know its a runner. I believe it will not light off due to a faulty ignitor box (common for these engines of this vintage) These are still available from a comapany called http://www.avonaero.com/index.html he quoted me 250 dollars for a new igniter box. or there are ways to covert the igniter box to a HID automotive style as well. It is a project and i was never able to verify that the generator portion is still working. But it is all there. call 7O7 48O 8695 or e-mail if interested. I am willing to ship as well but this generator weighs around 550 pounds so it will most likely be very expensive. may be willing to work out a deal if all you want is the motor but price will go up since i will have to remove it. Heres a link to my first startup attempt with this engine garret gtp30-67 emu12/e troubleshooting - YouTube
it is currently located at hayward executive airport heres some links to others projects using this engine
http://www.popsci.com/diy/article/20...et-powered-atv
http://www.turbinefun.com/TurbinePoweredHondaCRX.asp
http://gizmodo.com/5637686/a-jet+pow...-rule-them-all
thewhitestjamal is offline   Reply With Quote Quick reply to this message
Old 11-17-2011, 08:33 PM   #2 (permalink)
Member # 111947
Just think about that nosey neighbor who scoffs at you for running the grinder late at night. This thing is guaranteed to make every barbara walters on the block shit their dapends when you fire up the ol' jet engine in the front yard
Old 11-17-2011, 08:45 PM   #3 (permalink)
nate379's Avatar
Member # 20099
Looks to be similar to the A/M32A-60s that we use now a days. I can hear them going inside my office which is about 1/4 mile from the flightline.
nate379 is offline   Reply With Quote Quick reply to this message
Old 11-18-2011, 08:33 PM   #4 (permalink)
Member # 111947
I'm a aircraft mechanic by trade and honestly I have come to hate the sound of APU's screaming next to me all day while I work. But the sound a jet engine makes as it starts is such a sweet harmony of metal and fuel that it always seems to put a smile on my face.
Old 11-19-2011, 02:10 PM   #5 (permalink)
Member # 111947
Smile
Did I mention I was open to any offers including trades?
Old 11-19-2011, 08:52 PM   #6 (permalink)
Member # 111947
new price 1100obo really looking for a good running 22re
Old 11-22-2011, 09:58 PM   #7 (permalink)
Member # 111947
1000 obo
Old 11-27-2011, 10:23 PM   #8 (permalink)
Member # 111947
sunday bump
Old 12-01-2011, 11:58 PM   #9 (permalink)
Member # 111947
Will trade for rims and tires for a dodge 2500 4x4 or will take 900 cash
Old 12-06-2011, 04:23 PM   #10 (permalink)
Member # 111947
SOLD Traded for a Mercedes diesel 300td. SOLD
