Member # 164533
Moon buggy part out, 5.3, 350 trans, axles more
All parts for $14,000.00
Make offer on parts you want If I can get buys for the axles, driveline I will part it all out. axles are both passenger drop, all the way to the passenger side 1.5" DOM chassis built by Adam Carter, 3/8 plastic belly skid(slippery type) 2007 GM 5.3 with Howell computer, aftermarket intake, fuel rails TH350 Atlas 4.3 transfer case 1350 driveline with ubolts in everything front Spidertrax 9" with Solid 60 knuckles and inner C's, CTM ujoints, Yukon shafts, Yukon center Spool, new ball joints, bearings gone thru recently Fully Hydro steering with dual ended ram, ram just rebuilt, added new PSC pump, Howe trophy truck cooler and all new hoses rear Spidertrax 9" with Yukon center Detroit Lower links are Aluminum(have a spare), uppers are DOM 14" Fox coil overs all just gone thru by Sonny at Down South Motorsports, added reservoirs to fronts 9K Bulldog comp winch with Viking line 17" Allied Rockmonster wheels 40" Maxxis Creepy Crawlers 50% left no plugs or patches B&M carbon fiber shifter Cutting brakes All new Autometer gauges for oil pressure, engine temp, transmission temp Griffin radiator with New Spal fan 16 gallon fuel cell New Odyssey battery Axles are 65 WMS Rear pinion support needs replacement, had a bearing fail and fixed it out on trail, kept wheeling all weekend. Works good, just not enough preload on bearing. Still Works great, was planning on getting one more weekend wheeling trip then gonna replace pinion support, pinion. Axle seals have leaked since I have owned it, was gonna go thru axles this summer but got new car and don't have time
07 cummins 6.7 mega cab 4X4 mall crawler 37"s Cambell Moon Buggy, LS1,350,red labels Valencia Custom Shower doors Token No Limit Crew guy Last edited by BJLOVER; 06-02-2012 at 09:41 PM. |
noob
Member # 66544
What pattern are the wheels?
Info on radiator please
El Destructo! I void warranty's!!! Team Rock Limo F-Toy #F002 Yukon gear/Randy's Ring & Pinion, Trail Gear, BFGoodrich Tires, RuffStuff, 12 Volt Guy |
Member # 96153
Do you still have that long (5ft?) heat sinked tube with a bend in it? Would you like to sell it?
DD:09' V8 Colorado Toy:The Blazer Build Ultra4 #818 Old tow:92' Dodge Build Sold ![]() New tow:05' Dodge Crew 4x4 CTD (stock for now) 18th at Glen Helen 13' ![]() Complete 465/203/205 For Sale |
Member # 164533
I never installed that in the car, 75.00 for you. Can get measurements for you. Comes with AN fittings. ( still trying to find you a 42" spare also)
07 cummins 6.7 mega cab 4X4 mall crawler 37"s Cambell Moon Buggy, LS1,350,red labels Valencia Custom Shower doors Token No Limit Crew guy |
Member # 164533
Will only start the part out if I can find someone to buy the axles complete. Steering cylinder will be part of front axle assembly
