I've got a used Danfoss orbital valve. It came from Sean (station) at POS. It's load reactive and 4.8 cu.in/rev. I'll include the lines and column adapter. The adapter is 3/4''x36 spline. I shaved down the threads some to work with a 36 splined u-joint. Obviously the lines may or may not work with your set-up.
volume of a 2.5x8 cylinder is 25.12 in^3. 25.12/4.3=5.84 turns lock to lock.
2.25x8 is 23.86 in^3 =>5.5 turns L-to-L
take the volume and divide it by 8 then multiply that number by 6 and it will give you the volume for a 6" cylinder.
