-This will easily support a 40" tire/wheel
-1/4” rectangular tubing construction throughout---not weaker formed steel
-Boxed and sealed
-Strong spring loaded latch mechanism
-Powder-coated black
-Huge grease-able bolt at the pivot point
-Hi-Lift Jack tabs (2)
-D-ring tabs go through both bumper faces and are welded front and rear!
-Tire mount is adjustable for use with different wheel offsets
-Mounts to the frame and rear cross-member at 10 points!
-Easily pivots open for easy access to trunk area
This is the nicest/sturdiest Jeep tire carrier I’ve seen, the only thing I’ve seen that is close to this are the Bulletproof Bumpers which use slightly weaker materials and cost over $1,100+shipping.
$595 obo
Located in Dallas, Texas
