1978-1979 Ford Power Steering Box - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Misc. Stuff For Sale
Old 09-13-2010, 07:27 PM   #1 (permalink)
Ho Shorts's Avatar
Member # 109328
I have a good power steering box for the 78-79 Ford F150. This baby is fresh from the junkyard and hasn't been molested yet. Was going on my rock crawler but I decided to go full hydro. I gave $75.00 for it and spent an hour pulling the S.O.B. I'm asking $100.00 shipped to your location. I've even cleaned it up since I got it. Let me know......
Thanks,
Derek
Ho Shorts is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 11:57 AM   #2 (permalink)
Ho Shorts's Avatar
Member # 109328
This is a 4wd box, NOT the big goofy 2wd rear steer box Ford used in those years.
DK
Old 09-14-2010, 06:55 PM   #3 (permalink)
Pissing Excellence
Sillyneck's Avatar
Member # 517
Send a message via ICQ to Sillyneck
I'm about 90% sure on this...
the f150 p/s box of those years was shared by the 78-79 bronco 100% sure.... however the 250 and 350 had at least 1 other box. 4 bolt push pull style rather than cross over.
so I guess the $21k question is...... is it a 3 bolt front swing pitman box.. or a 4 bolt side swinger?
If it's the 3 bolt box.. it has more value.
You can also swap the worm gear over to make it swing backside standard.
4457 Team DMR
Poly Performance
Ruffstuff
Barnes Welding Supply Sacramento
RADFLO
Shock tuning..... I only work with underdogs.
Sillyneck is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 07:58 PM   #4 (permalink)
Ho Shorts's Avatar
Member # 109328
It's the 3 bolt style. I pulled it off a 79 F150, here is a pic of it:
Sorry about the confusion guys, I was told it will fit all models but I KNOW it will fit the F150 as I pulled it myself
DK
Old 09-16-2010, 11:01 AM   #5 (permalink)
Ho Shorts's Avatar
Member # 109328
btt, still have this availaible.
DK
Old 09-17-2010, 10:21 PM   #6 (permalink)
Pissing Excellence
Sillyneck's Avatar
Member # 517
yep... that's the winner! smokin price. the core is 170 at napa.
4457 Team DMR
Poly Performance
Ruffstuff
RADFLO
Old 09-19-2010, 11:11 AM   #7 (permalink)
Ho Shorts's Avatar
Member # 109328
Yeah, It will make someone a bargain. Still have this available.
DK
Old 09-20-2010, 01:21 PM   #8 (permalink)
Ho Shorts's Avatar
Member # 109328
btt
Old 09-21-2010, 09:09 PM   #9 (permalink)
Ho Shorts's Avatar
Member # 109328
this item is still available.
Old 09-23-2010, 01:18 PM   #10 (permalink)
1962 YellowSubmarine
YellowSub1962's Avatar
Member # 1494
I'm pretty interested in this, but I'm a total Ford Steering Newb.
I have an early bronco Frame under my Jeepster and once I get the D44 in it, I need to do the p/s and brakes.
Do I need to swap the guts in this box to make it turn the right way with a rear facing pitman arm? Or will it work as is? This is a street rig, so not worried about hydro assist porting or anything, just a stock pump and 35" tires.
Thanks,
Peter
Peter S. Di Primo - Waterjet, laser, metal forming, CNC work, Fiberglass and Carbon work, patterns and molds. No job too small.
Prototyping and small production is our specialty, but we have the network to handle large jobs as well.
Email me if you need something cut, bent, formed, milled, machined, etc.
Help Fight Global Warming- turn your A/C on high and open all your windows.
Alcohol, Tobacco, and Firearms should be a convenience store - NOT a government agency!!!!
YellowSub1962 is offline   Reply With Quote Quick reply to this message
Old 09-23-2010, 01:51 PM   #11 (permalink)
Ho Shorts's Avatar
Member # 109328
If the pitman arm needs to swing from the back of the box (ie. the side the steering shaft comes in on) then yes the guts will have to be swapped. Basically this consists of finding an early 80's 2wd F150 box and putting the guts from that box into this one.
This box will however bolt right to your frame in place of the older style push-pull system Ford had in the 60's and early 70's. There is an article on excatly how to do the gut swap somewhere on Pirate. I have read over it before and it is very informative. I would search for it before I attempted it. Hope this helps.
DK
Old 09-24-2010, 12:08 AM   #12 (permalink)
Member # 1494
Ok I had a feeling I needed to find another box. Let me look around a bit for the 2wd box and if you still have this one when I find one, I'll prob take it off your hands. Money's tight being unemployed at the moment or I'd take this now and just sit on it, but I have to make sure I can afford both
Thanks
Old 09-25-2010, 03:18 PM   #13 (permalink)
Pissing Excellence
Sillyneck's Avatar
Member # 517
I mount them up all the time w/ the pitman arm forward (obviously not in the stock location). you can move the front end out a ways w/ out interference and offset the coil mounts on the axle rather than moving anything on the frame. it's also nice having a stock replacement box available anywhere.
4457 Team DMR
Poly Performance
Ruffstuff
RADFLO
Old 09-27-2010, 09:24 AM   #14 (permalink)
78FORD4x4's Avatar
Member # 125311
Location: Sittin' here doin' my part to make sure the welfare checks cash.
How much play does it have?
F-the haters. Build it beef and beat it like a red-headed step-child.
78FORD4x4 is offline   Reply With Quote Quick reply to this message
Old 09-27-2010, 01:44 PM   #15 (permalink)
Ho Shorts's Avatar
Member # 109328
From my experience with these boxes i'd say it's on the lower end of average. I've definatley seen ALOT worse. Odometer was showing 91,000 miles and judging from the box I'd say that was probably original. I'd bolt this guy on and run it on anything without fear if I had a use for it.
Derek
Old 09-27-2010, 08:34 PM   #16 (permalink)
Member # 169726
i'll take it pm sent
strokers is offline   Reply With Quote Quick reply to this message
Old 09-28-2010, 10:02 AM   #17 (permalink)
Ho Shorts's Avatar
Member # 109328
Sale pending 09/28/2010
dk
Old 09-28-2010, 08:04 PM   #18 (permalink)
Ho Shorts's Avatar
Member # 109328
I received a $100.00 payment in my Paypal account today from a gentleman who I haven't spoken with. I can only assume it was someone on Pirate due to the exact amount. Please post up and let me know who you are, if you sent the money on behalf of the party who has already pledged to buy it or what is happening as I have emailed the person who sent the money and they never responded to me.
Thanks,
Derek
Old 09-29-2010, 06:26 AM   #19 (permalink)
Ho Shorts's Avatar
Member # 109328
It's all worked out now, item is Sold.
DK
