7/8" Clocking ring!! D300 6 bolt - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 09-26-2011, 02:06 PM   #1 (permalink)
CNC Machine Shop
4WHEELSUPPLY's Avatar
Member # 180013
Well I finally had enough time to make a few of these for you guys to try. Had a bunch of people asking about them so here they are. 6 bolt clocking ring that will work with D300's and other 6 bolt pattern NP cases. 7/8" thick for spacing on a few applications. No guarantees this will work for your application. $75 each to your door. Hardware is included! In stock ready to ship. See my other post for other products also.
THIS RING WILL NOT FLIP YOUR STOCK DANA 300 TO A DRIVER SIDE OUTPUT!!!! YOU WILL NEED MY FLIP RING TO DO SO.
DRIVER SIDE CLOCKING WORKS ON FACTORY DRIVER SIDE OUTPUT CASES WITH THE SAME 6 BOLT ROUND PATTERN AS D300 i.e NP208 241 AND MANY OTHERS
4WHEELSUPPLY is offline   Reply With Quote Quick reply to this message
Old 09-27-2011, 03:14 PM   #2 (permalink)
jkl
Member # 142189
Payment sent!
[SIZE="3"]
LJ on 35s[/SIZE]
jkl is offline   Reply With Quote Quick reply to this message
Old 09-27-2011, 07:15 PM   #3 (permalink)
CNC Machine Shop
Member # 180013
Thanks for the order!!!
Old 10-12-2011, 11:22 PM   #4 (permalink)
937Comanche's Avatar
Member # 197170
Order Sent via Paypal to fourwheelsupply@yahoo.com
937Comanche is offline   Reply With Quote Quick reply to this message
Old 10-13-2011, 06:41 AM   #5 (permalink)
CNC Machine Shop
Member # 180013
Got it!!! Ring Will ship today!@!!
Old 10-20-2011, 05:21 PM   #6 (permalink)
cincinnatijeeper's Avatar
Member # 19582
Payment sent. Thanks!!!
93 yj 4.0 aw4 dana 300, 60 14 bolt 38tsl hummer beadlocks
cincinnatijeeper is offline   Reply With Quote Quick reply to this message
Old 10-25-2011, 11:19 AM   #7 (permalink)
Member # 168481
mi xj is offline   Reply With Quote Quick reply to this message
Old 10-30-2011, 08:21 AM   #8 (permalink)
CNC Machine Shop
Member # 180013
Thanks for all orders!
Old 11-24-2011, 07:29 AM   #9 (permalink)
CNC Machine Shop
Member # 180013
ttt
Old 11-29-2011, 08:56 PM   #10 (permalink)
FOURX4TRUX's Avatar
Member # 61228
Money sent
MECHANICALLY INCLINED......... I SCREW UP EVERYTHING
FOURX4TRUX is offline   Reply With Quote Quick reply to this message
Old 11-30-2011, 06:28 AM   #11 (permalink)
CNC Machine Shop
Member # 180013
Originally Posted by FOURX4TRUX View Post
Money sent
Got it! Ships today Thanks
Old 12-18-2011, 06:08 PM   #12 (permalink)
CNC Machine Shop
Member # 180013
btt
Old 12-28-2011, 12:40 PM   #13 (permalink)
Member # 157429
money sent!!
03 TJ, 5.3L
jjeeper03 is offline   Reply With Quote Quick reply to this message
Old 12-28-2011, 07:16 PM   #14 (permalink)
CNC Machine Shop
Member # 180013
Got it! Shipped! Thanks
Old 01-22-2012, 01:45 PM   #15 (permalink)
Member # 208357
What's the verdict on the 7/8 clocking ring ? Any issues ?
CTYJ is offline   Reply With Quote Quick reply to this message
Old 01-22-2012, 06:11 PM   #16 (permalink)
CNC Machine Shop
Member # 180013
Sold a bunch with no issues. Thanks
Old 01-22-2012, 10:51 PM   #17 (permalink)
oldrivers's Avatar
Member # 28570
Is it possible to get one with only the 6 countersunk holes without the others drilled and tapped?
oldrivers is offline   Reply With Quote Quick reply to this message
Old 01-23-2012, 06:36 AM   #18 (permalink)
CNC Machine Shop
Member # 180013
It is possible, I could do a couple like that on my next run. But, excuse my ignorance, But I dont understand why you would only need the countersunk thru holes?
Old 01-23-2012, 11:38 AM   #19 (permalink)
oldrivers's Avatar
Member # 28570
because i want to use it with a "dd machine box 4 rocks kit" and the other holes are drilled in a different spot so id have to have them drilled out later .
his ring is 1/4 inch and im pretty sure i need a 7/8ths to fit a ford 205 to clear the idle shaft and nut wich sticks up about 7/8ths ..
Old 01-24-2012, 09:30 AM   #20 (permalink)
Member # 208357
Nice. Order on the way. Thanks
Old 01-24-2012, 09:43 AM   #21 (permalink)
Member # 208357
Old 01-24-2012, 10:00 AM   #22 (permalink)
CNC Machine Shop
Member # 180013
got it thanks
Old 01-25-2012, 09:14 PM   #23 (permalink)
oldrivers's Avatar
Member # 28570
If its not to late hold off on this for now, need to do more research .
but if you already are into it let me know dont want to leave you holding something i requested.
Old 01-29-2012, 01:46 AM   #24 (permalink)
gtxracer's Avatar
Member # 25303
Does this allow for both passenger and driver drop dana 300 applications like your 3/8" ring?
97 TJ 4500 wannabe Build Thread:
Instagram: @DukeEngineeringSolutions
Builds, Swaps, Axles, Engines, Turbos, Diesels, Suspensions, Fab, and more!
gtxracer is offline   Reply With Quote Quick reply to this message
Old 01-31-2012, 08:37 PM   #25 (permalink)
Member # 208216
Noob question here.
Would these clocking rings work on an NP231 to a 4l60e? Both are 6 bolt. I'll be doing an engine swap, and will 99.9% likely be needing a clocking ring.
JustAHumbleJeeper is offline   Reply With Quote Quick reply to this message
