Ford HEI's for small blocks CHEAP! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 02-08-2005, 01:08 PM   #1 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
HEI unit for Ford small blocks
50,000 V coil!!! Premium hi-dielectric cap with brass terminals, both upper and lower bushings for added durability, a low-saturation ignition module, and no voltage-reducing ballast resistors. These units offer calibrated advance curves that are optimized for maximum combustion efficiency, and the elimination of detonation damage and throttle ping. The distributors offer longer-term durability and a higher voltage spark that permits a bigger spark plug gap, resulting in more power and reduced plug fouling. By eliminating the stock Ford ballast resistor, you'll get more ignition voltage, resulting in an improved spark. Another advantage to switching to HEI is access to easily-found HEI replacement parts. The Ford units are also assembled with upper and lower bushings, an upgrade from stock distributors that only have a single bushing. They're easy to install by connecting one 12 V hot wire to the distributor, making them a quick performance upgrade. Every unit is tested!
Comes with distributor and cap no wires
$175 shipped!!
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-257-7917
MC is offline   Reply With Quote
Old 02-08-2005, 11:15 PM   #2 (permalink)
Member # 7472
Send a message via AIM to Bratcher@Crawltech
crawltech.com
Bratcher@Crawltech is offline   Reply With Quote
Old 03-03-2005, 05:20 PM   #3 (permalink)
MC
MC's Avatar
Member # 21997
For those who were askign me via pm's this replaces your coil, ignition control module and only takes one hot wire to run...also has a provision for tachometer
1-651-257-7917
