Trail-Gear 6.5 Samurai Transfer Case Gears - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Motor/Tranny/T-Case Performance
Old 12-11-2006, 02:10 PM   #1 (permalink)
Member # 26
Trail-Gear is proud to announce our new 6.5 low range gear set for Suzuki Samurai's.
Trail-Creeper Low Range gear reduction is 6.5 to 1. High Range reduction is 20% under stock. No welded or second rate, gears here. Our low range gear kit is the highest quality gears available on the market. Trail Creeper gears are are strong, run quiet and take a huge amount of abuse. This complete kit includes four new precision cut gears, counter shaft, needle bearings, shims, o-ring, gaskets, and input/output seals. Minor grinding of case is necessary for installation. Fits 1986-1995 Suzuki Samurai's. Complete Kit $499.
http://www.trail-gear.com/zuk-tcasegears.html
Chris Geiger is offline   Reply With Quote
Old 02-01-2007, 05:17 PM   #2 (permalink)
moveaside's Avatar
Member # 11983
soon very very soon
My crappy build
[url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url]
moveaside is offline   Reply With Quote
Old 04-15-2007, 10:47 PM   #3 (permalink)
Newbie
Member # 89478
hey hey whats up just seein bout the gears are they still in stock and the price is it still the same?
thanks
Rhinocon06 is offline   Reply With Quote
Old 04-15-2007, 10:50 PM   #4 (permalink)
Member # 26
Yep, plenty in stock, price has not changed, $499 a set.
Old 06-09-2007, 10:23 PM   #5 (permalink)
moveaside's Avatar
Member # 11983
Just got done installing them I've never seen easier directions then your website pics. It was funny as well to watch those outputs spin so much faster than the input shaft on the table. The grinding of the case was actually very minimal especially if you remember to put the countershaft shim in for the temporary install of the gears to mark for clearancing issues. I put a HD front output in while I was at it. I had a buddy bust three pre 90 ones before he bought that and hasn't broke one.
My crappy build
